Results 1 to 4 of 4
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    DIY: Accordian hose upgrade
    For those that keep wondering how to plug or where to put the extra hose going to the accordian here ya go.
    I originally capped my hose off but the center valve broke, so i deleted the old hose and ran a new one.
    Parts needed:
    191611933F Check valve (I just noticed you can use the one that you cap off! so you dont actually have to but a new one)
    N0203901 Hose, only 6 inches but it comes in 3 meters, so if anyone needs some PM me.
    2x clamps, Bently said N90561801 but they are longer than needed but still work.
    Here is the old hose:
    Using a razor blade slice the plastic hose and remove the part that goes to the manifold. You can also remove the check valve if you didnt buy a new one. (you can see that the new one is the same as the one i had capped off)
    New shorter hose assembled:
    Hose in the car:
    Another Shot:
    Senior Member Four Rings Vinchenzo51's Avatar
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Did the same thing myself when mine cracked a few months ago.
    Active Member Three Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    This works well too. The check valve that goes into the accordian was bad so I had to get creative.
    These are the hoses and valve that go from the n80 to the tee that continues to the inlets, the mani connector, and the one that normally goes to the brake booster.
    Really turned out nice with the bends that it has.
    Forum Moderator Four Rings Gumby's Avatar
    Sep 06 2008
    01 allroad, 01.5 A4 TQM
    Bellingham, WA
    -Matt-
    B5 S4, C5 A6 Moderator
    Murdered out and coilovered 2001 allroad stage 2+ on a diet
    Brilliant black 2001 A4 1.8t quattro sport -Build thread
    Low cars are faster than high cars. It's science. -8520
