Results 1 to 32 of 32
    Active Member Three Rings patastinky's Avatar
    Apr 07 2011
    2011 Jeep Wrangler Sahara Unlimited
    EARTH
    JHM Equipped Avants..? Where ya'll at..?
    Hey Guys... As some of you might already know I have a B7 2006 S4 manual Avant. Just curious to see how many of are out there. What products do you have and how do you feel about them? I recently sent out my ECU to get chipped and I also have the JHM Solid shifter. I'm looking forward to the chip since i've read so many positive reviews on it. It would be nice to close the gap a little with our heavy Avants. I had to replace the shifter in my Avant, it was aftermarket Stratosphere. The plastic ball that the shifter goes through fell apart. JHM's shifter is complete so it was the obvious choice.
    JHM 93 tune * JHM Solid Short Shifter * Custom Catless downpipes * Milltek non resonated cat-back exhaust * H&R Sport Springs * VMR 708 RS4 replica's 19x8.5 *
    Jul 21 2009
    04 S4 Avant
    Aurora, CO
    JHM tune and piggie pipes here, shortly to add the intake manifold and light weight rotors f/r. If I get lucky and win the lotto then I will definitely be adding the s/c, unless someone wants to donate the money to me.
    Apr 07 2011
    EARTH
    Quote Originally Posted by mmayhem View Post
    when did you get your tune and how do you like it? I can't wait to get mine. I'm actually going the catless route with my dp's.. How do you like the piggies?
    Jul 21 2009
    04 S4 Avant
    Aurora, CO
    Got the tune this past June, butt dyno said it was an improvement but a real dyno showed no real gains or losses after having switched over from GIAC. Went with the tune mostly for update availability they have with each "power" mod you do. As for the piggie pipes they really helped open the car up and bring out some more power, I got an extra 13whp after doing this, (relatively speaking) the only constant factor was the dyno as they were done on different days. If it wasn't for emissions/smog where I live I would have gone with the JHM headers instead of the piggies, I need those main cats.
    Feb 02 2005
    '04 S4 Avant, '05 A4 Avant
    You need the cats yes and no. Once you pass you're good for two years and can probably pass via the rapid pass mobile vans without the cats. I currently have a Milltek full set up, but the cats were bad in the Milltek downpipes. I gutted them, but will be putting cats in where the stock main cats go.
    I'll be getting a JHM tune shortly, I am curious, there was no power difference between it and the GIAC tune?
    Active Member Four Rings Axel-'s Avatar
    Jan 29 2011
    Toronto, CA
    See my sig...
    Sprint Blue B7 S4 Avant 6MT - Dynos
    JHM Stage 1 Supercharger - Stern Motor mounts - JHM IM - JHM Stage 4 clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - Apikol Rear Diff Mount - JHM "Trio" shifter - Trexturk DP - Magnaflow CB - Hotchkis 29mm RSB - JHM Intake Spacers - Apikol snub mount - RS4 Pedals - TT-RS MFSW - Dectane LED tails - 19" O.Z. Ultraleggera - 35% Huper Optik tint - Zada Tech Gauges - Dynavin D99 Android
    Veteran Member Three Rings d.p's Avatar
    Nov 08 2006
    S4 Avant
    Annapolis MD
    JHM tune and LWP, and SS here. FI downpipes and exhaust as well..amongst other things.
    Apr 07 2011
    EARTH
    Nice there are a lot of JHM Avants here.. :)
    Jul 21 2009
    04 S4 Avant
    Aurora, CO
    Quote Originally Posted by Docwyte View Post
    I ran catless with my last car and I don't want to have to go through the headache of having to swap cats in and out since the only other thing I would do are the headers.
    There was/is a power difference between GIAC and JHM, but as I stated since I didn't do the pulls on the same day the results can't really be compared evenly. Back on April it was an 80* day (GIAC) and when I did my most recent pulls (9/17/11) it was a 72* day (JHM).
    With that said the difference between the two:
    GIAC 224/221
    JHM 217/227
    Both were STP Corrected numbers
    Senior Member Three Rings bangoman's Avatar
    Jan 05 2010
    JHM piggies here. There's a tune in my future, just need to find a time window to get tuned.
    B6 S4 Avant | JHM 93 tune/JHM piggies/Magnaflow 2.5" catback/JHM clutch+LWFW | 13.42 @ 103.95
    Apr 07 2011
    EARTH
    GIAC 224/221
    JHM 217/227
    GIAC... Wasn't that one of the very 1st tunes available for our cars? Asides from APR? I wish i would have done some kind of testing prior to getting the chip + catless DP's, but i guess the butt dyno will have to do.
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    JHM Tune - stage 4 clutch LW Flywheel and JHM headers here.
    Current setup last dynoed at 310 WHP and 300 WTQ
    2005 Audi S4 Avant 6 Speed - JHM Headers, Magnaflow exhaust w/ X Pipe, JHM Lighweight Flywheel, Stage 4 clutch, JHM 93 Tune , H&R CO's, Stern Motor Mounts
    Buy my motor! http://www.audizine.com/forum/showth...-Audi-S4-Motor
    Apr 07 2011
    EARTH
    Quote Originally Posted by SuperAvant View Post
    JHM headers? Awesome! Do you have any sound clips of startup and perhaps a spirited run!?
    May 30 2007
    MA
    Need to get some more videos but in the meantime, here yah go
    Apr 07 2011
    EARTH
    Wow! that sounds unbelievably amazing! Where did you get the headers installed? Did you DIY!?
    Jan 05 2010
    Sounds filthy. Love it!
    Senior Member Four Rings kneel's Avatar
    Dec 01 2007
    Atlas Gray Revo Stg.3 Avant, MK5 GLI
    Orange County, NY 10918
    wow will be looking forward to that sound on Saturday!
    Neil_
    2003 Atlas Gray Avant w/ REVO STG.3
    PSi Concepts 20g Turbo..... Baby Recaro Seats!
    PODI
    Dubs on Defrost 5 - April 7th, 2012 - Westport, CT
    Apr 07 2011
    EARTH
    Just installed my JHM tune (ECU). Couldn't be happier. Waiting on the turk dp's to arrive :), should be here by Oct 5th :)
    Jan 29 2011
    Toronto, CA
    Boring 5 minute video (don't know how to edit/trim) of my tail-pipe while driving in city traffic. If you're looking for action, this isn't for you. If you're looking for sounds, it might.
    JHM Supercharged B7 S4 Avant with B&B catless downpipes and Magnaflow resonated catback.
    Edit: I added time stamps in the description to skip the boring stuff. Makes it a lot easier to browse (i.e., just click on the timestamps in the description http://youtu.be/VSMPlllw5kM)
    Active Member Two Rings jumpinj's Avatar
    Sep 25 2010
    1975 Bug
    Midwest
    Red face
    see sig....
    love it
    JHM 93 Tune
    FI DPs (w/ cats) and Catback (14" res)
    intake spacers/LWCP
    snub, motor, tranny & rear diff mount
    Hotchkis Front & Rear Sway bars.
    Walking isn't a lost art - one must, by some means, get to the garage. ~Evan Esar
    Jan 29 2011
    Toronto, CA
    It's really not much but I guess it's better than nothing.
    Senior Member Three Rings Kem's Avatar
    Aug 30 2004
    09 A4 Avant, 04 S4 Avant 6MT
    Oakland, CA
    6MT Avant with piggies and JHM tune here.
    '04 S4 Avant : Dolphin Grey : 6MT : Alcantara & Alum interior : JHM Tune : Piggie Pipes : Magnaflow cat-back : 19x8.5 BBS LM Rep (ST8) : RNS-E
    Active Member Three Rings williamr91's Avatar
    Feb 11 2011
    Vast stage 2 s4, Vast stage 2 allroad
    I've traveled some.
    MMMMM V8 with headers and dp's sounds nice. I want next :)
    2002 S4 Stage II Vast
    2004 allroad 2.7 (402, Stage II Vast)
    My grandma's 186. I'd like to connect (and verify!) If you understand that pm me.
    Apr 07 2011
    EARTH
    Quote Originally Posted by Axel- View Post
    Wow. I've seen other. Videos of s4's with the JHM super charger doing pulls, but this is the best one. Good camera quality, done during the day, short and to the point. Thank you for sharing.
    Jan 29 2011
    Toronto, CA
    Quote Originally Posted by patastinky View Post
    Thanks. Available in 720p too :)
    Active Member Two Rings quattro004's Avatar
    Aug 27 2009
    Minnesota
    If you don't mind me asking, what are those wheels and what is the size, offset and tire sizing you have on your avant? Car looks and sounds great in the video!
    Weapon of Choice: quattro
    | Apikol Snub Mount | B5 RS4 Reps | Vogtland Coilovers | Dunlop Direzza Z1 Star Spec-Summer | Dunlop Winter Sport 3D-Winter | Ecode Headlights | 5000k HID | 9500i |
    Senior Member Three Rings B5 SLPR's Avatar
    Dec 04 2007
    B7 S4 Avant
    So Cal/La Jolla
    06 S4 Avant, 6mt, K&N drop in, Full Oettiner body kit, 2.5 Oettinger exhaust w/ X pipe, JHM piggies, JHM 91 tune, JHM SS, JHM LW front and rear rotors, H&R suspension, Hotchkis RS4 front n rear sways, VMR 710's. Soon to come, motor mounts, trans mount, snub mount, Stg 4 clutch, JHM pulley, JHM intake spacers and way down the line, JHM SC. :) that is all
    "I like to party"
    VMR, Great Wheels, Great Company http://www.velocitymotoring.com/
    Oct 22 2011
    San Francisco
    Just picked mine up from JHM on Friday after a full makeover.
    They installed:
    2.5" high-flow cat dp's
    2.5" resonated catback
    91 tune
    SS trio
    Intake manifold and spacers
    K&N filter
    LW crank pulley
    LW flywheel and stage 4 clutch
    4:1 center diff
    Apikol snub mount w/ zero gap bracket
    Apikol diff mount
    034 tranny mount
    Stern motor mounts
    MAF hose
    Oil coolerkit/ Aux. radiator delete
    MS (Ohlins) coilovers
    Hawk brake pads... temp only until I get the Brembo's on all corners
    Metal clutch slave and line
    Hotchkis RS4 swaybars f/r
    034 front swaybar endlinks
    Spherical rod-end rear sway bar end links
    034 adjustable UCA's
    034 density line lowers etc.
    Metal tie rod ends
    Full 50k service and valve cover gaskets.
    Basically, if you could bolt it on the car, it is on there with the xception of the S/C and headers....until next winter.
    Needles to say, the car is much improved
    -Dave
    B7 S4 Avant 6mt <- Not stock
    20b RCR Superlite-Coupe
    Senior Member Four Rings boy412's Avatar
    Jul 15 2007
    2003 A4 Avant 1.8TQM Sport
    Mount Rainier, MD
    Jeeze Dave!
    Only thing I'm not sure about is that lightweight crank pulley. You're basically taking off the balanced one and replacing it with something that provides ZERO dampening. Mine is coming off shortly and am putting a Fluidampr in its place.
    At the moment I just have the SS trio on my car. I'm lusting after their lightweight brake rotors though (amongst other things).
    RAI | MTM Stage II | DSMIC | Fluidampr | FX400 | Vogtlant GT coilovers | B6 S4 brakes | ER TIP | Forge 007 | STaSIS | Stėrn | Apikol | JHM trio | Podi | OEM+
    2.0L stroker build in progress...
    Sep 25 2010
    1975 Bug
    Midwest
    Quote Originally Posted by RX-Heven View Post
    They installed:
    91 tune
    SS trio
    K&N filter
    LW crank pulley
    4:1 center diff
    Apikol diff mount
    034 tranny mount
    Stern motor mounts
    MAF hose
    Metal tie rod ends
    I just peed myself...
    JHM 93 Tune
    intake spacers/LWCP
    Dec 04 2007
    B7 S4 Avant
    So Cal/La Jolla
    Quote Originally Posted by boy412 View Post
    Jeeze Dave!
    The rotors are worth it, DO IT!!!!
    "I like to party"
    Jan 29 2011
    Toronto, CA
    Needless to say, the car is much improved
    Wow, you really went all out! Nicely done!
