Results 1 to 8 of 8
Thread: winter set up
    Aug 06 2007
    new york
    winter set up
    just got a winter set up will 245/45 17 fit on the 06 a3 without rubbing..??
    Active Member Two Rings JRutter's Avatar
    Nov 20 2009
    A3 3.2 and A4 2.0
    NW WA
    with high offset maybe
    still no turbo - other mods here
    Active Member Two Rings dappy's Avatar
    Jul 30 2010
    Toronto, ON
    Quote Originally Posted by JRutter View Post
    You mean low offset. ie. ET45 or less. If you're running stock wheels with ET54 and on stock height, you should be fine. What size width wheel are you running? OEM is 7.5. If so, 245 is a tad wide, but still driveable. It's actually better to run narrower tires for better snow traction.
    2006 Ibis White 2.0T
    Nov 20 2009
    A3 3.2 and A4 2.0
    NW WA
    You mean high offset, like ET45 or higher.
    Actually ET45 might even rub if they are 8" or wider. Stock wheels should be OK.
    Aug 06 2007
    new york
    I have no idea guy I bought them from was running them on an a4 2005 I think maybe I should look to trade them off
    Active Member Two Rings everso's Avatar
    Jul 21 2011
    brooklyn NYC
    WHY would you run 245 tires in the winter? Winter set ups are not about style-**-they are about traction. The skinnier the tires the better for winter traction. getting 245s is just asking for inferior performance.
    2001 Audi TT 225 quattro Coupe (black/black)
    2012 Audi A3 2.0T quattro (black/black/titanium sport pkg)
    http://iedei.wordpress.com
    Aug 06 2007
    new york
    i didnt buy them for the tires i was looking to get a set of rims one of mine bent so i found these for a incredible price bought i will probably put them for sale and get something different
    Jan 10 2012
    Indianapolis
    Quote Originally Posted by dappy View Post
    the lower the offset number, the FURTHER OUT it will poke. High offset will go towards tucking INSIDE the fender, low offset will go towards poking OUT beyond the fender.
