Page 1 of 7 123 ... LastLast
Results 1 to 40 of 267
    Senior Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    Built A4, 08 Charger R/T
    Detroit Metro Area
    Turbo Nerds "Bout damn time" build thread
    Ok so I think it's time to make this....
    Everyone knows I blew my motor months ago so I got some real updates, I'll jump straight to the specs.
    2001 Audi A4 1.8TQM
    Motor:
    -JE 82.5mm pistons, 9.25:1 CR
    -JE piston rings
    -IE Rods
    -ARP head bolts
    -ARP main studs
    -ARP rod bolts
    -ARP crank bolt
    -OEM main bearings
    -OEM rod bearings
    -OEM thrust washers
    -OEM head gasket
    -OEM oil pump, pick up tube, screen
    -Full timing belt kit (Gates racing belt)
    -AEB head
    -Supertech valve springs and retainers
    -Supertech Inconel +1mm exhaust valves and stock sized intake valves
    -034 Track Density motor mounts
    -034 snub mount with cage
    Turbo setup/exhaust:
    -PTE6262 .83 A/R Billet Ball Bearing
    -SPA knockoff mani
    -TiAL 38mm wastegate
    -3" 034 SPA downpipe
    -3" DMH cutout
    -3" custom exhaust
    Fueling/tune:
    -ID1000 or EV14 1000 fuel injectors
    -Adjustable FPR
    -Aeromotive 340lph fuel pumps
    -Maestro7
    -MAFless
    -Hallman Pro MBC
    Transmisson:
    -240mm Clutch Masters FX400
    -JHM "Trio" package
    -034 Track Density tranny mounts
    Intercooler/Meth:
    -Treadstone TR8
    -2.5" cutom intercooler piping
    -AEM meth kit (Fail safe, 5Gal tank)
    Interior:
    -S4 Alcantara seats (heated, full power) (might be for sale soon)
    -S4 Cluster
    -Custom gauge pod (see pic below)
    -AEM 52mm digital boost gauge (30vac, 35psi)
    -AEM 52mm Uego wideband
    Exterior:
    -Casablanca white
    -S4 front bumper
    -S4 side skirts
    -S4 grill (ordering RS4 grill)
    -96 A4 euro style trunk (not pictured or painted yet)
    -Painted lower rear bumper
    -Tints
    -BBS VZ 18x8.5 ET30
    -Bridgestone Potenza RE040 235/40/18
    -Depo Ecodes
    -DDM 35W 4500k HID's (lows)
    -DDM 35W 3000k HID's (fogs)
    -Full respray
    Miscellaneous:
    -Euro valve cover
    -New expansion tank and cap
    -Rebuilt steering rack
    -New front axles
    -Stern power ring and bushing
    -FSI red coils
    -NGK BKR7E
    -R8 Oil Cap
    I'm sure I'm forgetting some things but that's pretty much it. The block is done being bored, decked, hot tanked, and they gapped the piston rings for me (didn't want to deal with it really). I pulled the motor this earlier today so I can get the machine shop my flywheel so they can balance my rotating assembly, I should have the motor back from them this week sometime. I will be building the motor myself and hoping to have it running in the next couple weeks (crosses fingers). I work Monday through Friday from 11am-11pm so I literally have no time to work on the car during the week, but Saturday's and Sunday's all day long I will be . Car will be given a deep thorough bath next weekend (engine bay, parts and accessories mostly). Still awaiting shipment on some parts but I almost have everything I need.
    On to the pics I've taken so far.....
    B5 Casa A4 with a built motor that isn't in the car and a PTE 6262 BB .83 A/R that going sing lag city b*tch lag lag city b*tch.
    May 12 2009
    Detroit Metro Area
    May 12 2009
    Detroit Metro Area
    Then the overheated block I bought....
    After I cleaned it up and honed it a bit so I can see how deep the pit in the cylinder wall is...
    I'll get more pics up when I get my block back from the machine shop and when more parts come in....
    Couldn't find the pic of the gauge pod, it's a custom dual gauge pod that uses the middle A/C vents (1st and 2nd vent are used, and 3rd is normal.... fiberglassed and the gauges face towards me). It's being made right now and I should have it soon, I'll be sure to get the pics up when I recieve it.
    Senior Member Four Rings Seerlah's Avatar
    Dec 05 2007
    I learned in the B6 A4 section that JE's clearance spec sheet is wrong, just in case the person who built your block went by that (piston to wall clearance is wrong). There are people in the B6 A4 section who have had piston slap because of going by the JE clearance spec sheet. Just a heads up. And nice build.
    http://www.audizine.com/forum/showth...ht=piston+slap
    I hate it when my car acts like a little bitch, treating me like the bitch
    FS:Brand New K&N Air Filter RU-3700 (3" inlet, 5" base, 4" tall, 4 5/8" top), Brand New 3" Injen (Amsoil) Dry Filter Setup with Heat Shield, Brand New OEM 06A Oil Pump, Used Greddy Intercooler...throw me some offers
    Active Member Three Rings jaychen's Avatar
    Feb 19 2011
    Brisbane
    Nice build,
    Are you side skirts painted or do they come factory painted?
    May 12 2009
    Detroit Metro Area
    I'm not too worried about piston slap, I really shouldn't have any since I have rifle drilled rods. Thanks for the head up though, I'll talk to the machinist about this. I'm leaving to go to the machine shop in a couple minutes to drop off a few things so they can balance it. I'll take some quick pics of the block while I'm there.
    Quote Originally Posted by jaychen View Post
    Nice build,
    They were a different color that came off an S4 so I had to paint them.
    Senior Member Three Rings bw86's Avatar
    Dec 06 2008
    '99 a4 1.8tqm
    LI
    • '99 a4 1.8tqm - GIAC 93 - 3" TP - Borla cat-back - Vogtland coils - 034 DV - S4 Xenons
      coming soon: 2008cc - Holset HX35 - AEM EMS - ID1000s - IECVA1s - Meth
    Senior Member Three Rings CCA4's Avatar
    Oct 25 2009
    A4, Cannondale Ironman caad 5
    Sterling, VA
    Lookin good so far man, I envy that you can do your own bodywork. When you upgrade to the PTE 6262 I may want to take that elim kit off your hands
    01.5 A4 Avant 1.8TQM|VDO|K&N|APR TIP|710n|Stërn|DieselGeek|Diode|Forge MBC|A8/TT|EBC Redstuff|Neuspeed Race|ATP 3" TP|034 Catch Can|Sport cloth swap
    Senior Member Four Rings Dan[FN]6262's Avatar
    Sep 12 2008
    02 A4, 94 GMC, 06 450R
    South Central Pa, Dundalk MD
    Quote Originally Posted by Turbo Nerd View Post
    Coming this winter/early next year....
    -PTE 6262
    -Treadstone T3 stainless steel cast manifold
    6262 will not fit on that manifold. You have to get a tubular or SPA
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    May 12 2009
    Detroit Metro Area
    Thanks for the good replies, as far as bodywork I don't do it myself I just sanded that ish down for a couple hours. The S4 bumper is red, the santorin blue, and the filler plate is silver lol.
    Dan, that kind of sucks it won't fit on that manifold because that mani is pretty sick. My initial mani I was going to go with was the full race one which is nice. When time comes for the new turbo setup I'll have to find out what I want to do but I have nothing but time.
    Little update already, I went to the machine shop to drop off my flywheel and crank pulley/harmonic balancer/whatever you may call it to have it balanced and resurfaced. I seen my block sitting there all purdy and brand new but I didn't take any pics since they had it wrapped up, it shouldn't be too long before I can pick it up.... These guys are fast and top notch. I seen all the big block's sitting there and I'm thinking to myself "wow my motor looks like a small turd compared to these big boys lol.
    I'll update again when new parts come in or something happens, again thanks for the comments, recommendations, and info.
    Btw I'll let you know when I want to get rid of my elim kit, it only has like 12-15k on it.
    Oct 25 2009
    Sterling, VA
    Lol gotcha. I tried to do body work on my old Bronco and it was decent, but I no longer have anyplace to do that kinda stuff :(
    Thanks man!
    Active Member Two Rings melomandn's Avatar
    Nov 08 2010
    Upstate New York
    x2 on this!
    01 1.8t quattro 5 Speed Swapped and a bunch of goodies..
    Senior Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    1983 Toyota Cressida, now new and improved w 401,000 km (AKA the shitmobile)
    Looking forward to seeing progress. As for the detonation that did the engine in, any idea as to why it occurred?
    Senior Member Three Rings MOtown A4's Avatar
    Oct 06 2008
    2001 Audi A4 1.8 T
    Shelby Twp. MIchigan
    what machine shop are you going to? im pulling my motor and building a 2.0 pte6262 this winter, so it would be nice to have a referral from someone who has had experience with a shop, and since im local to you it would work out even better.
    Active Member Two Rings quattro4me's Avatar
    Jan 29 2005
    99.5 A4 TQM , 86 4000 CS QM, 05 Mini Cooper S
    4 rings or terror
    do'n work
    May 12 2009
    Detroit Metro Area
    Quote Originally Posted by MOtown A4 View Post
    Automotive Machine Shop they are on the corner of Utica and Garfield in Roseville. Here's there number (586) 294-4311. Goodluck with your build, if you need any help let me know.
    May 12 2009
    Detroit Metro Area
    Quote Originally Posted by ZimbutheMonkey View Post
    My thoughts were dying fuel pump. It had a S4 fuel pump in there and it whinned a bit, I could feel the power drop off at about 6k (like I hit a brick wall) which I think I was running lean. I didn't have a wideband at the time but I can assure you this won't happen again.
    May 12 2009
    Detroit Metro Area
    Clutch and ARP main studs should be here this week, still waiting on the custom gauge pod, probably will go to the dealer sometime this week to get a new pilot bearing, flywheel bolts, and a few gaskets.
    Edit: after looking at my funny looking bumper I think I'm going to run it like this for the winter and put a euro plate on that says "Frankenstein".
    Active Member Three Rings TConklin821's Avatar
    Mar 17 2011
    Binghamton, New York
    I like that. Most Euro plates are 10 digits though. It'll have to be Frnknstein or something to that effect
    2001 A4 1.8TQM. Custom turbo back (eBay test pipe, LaBree downpipe, 2.5 inch piping back to a MagnaFlow muffler). Stage 1 tune. K&N Cone filter. RS6 Wheels painted dark gray with Continental DWS tires. ST Coilovers. Coming soon...2.0 coil packs.
    For sale...Brand new, never used, still in box Bosch rear o2 sensor.
    May 12 2009
    Detroit Metro Area
    I'd really prefer not to get the car painted during winter since I would be scared to drive it. I might just primer it my self and shoot it with paint for winter and in the spring get the whole car painted. Here's a pic from February....
    Looked pretty funny but I could car less.
    May 12 2009
    Detroit Metro Area
    Oh yea that vid is for you since it made me remember it from reading your sig lol.
    May 12 2009
    Detroit Metro Area
    Machine shop called me a little bit ago they said the motor is ready and I'll be picking it up tomorrow morning, clutch is going to be here tomorrow also. Total cost for machine work was $605, includes bore, deck, hot tank, balance, gap rings, and resurface the flywheel..... I don't think that is too bad.
    I'll be sure to take pics when I get it tomorrow.
    Martin.
    May 12 2009
    Detroit Metro Area
    Woke up a little late today so I didn't have a chance to pick the block up, I'll do it first thing tomorrow morning. CMFX400 came in this morning before I left for work (didn't have a chance to take pics as I was kind of late).... Hopefully it will hold for a while. Still waiting for ARP main studs to come in and since the machine work, clutch, and other things drained my paycheck I have to wait till next week to hitup the dealer to get a few odds and ends.
    Plans this weekend remove my axles and steering rack, then go to town on cleaning my filthy engine bay. I'll get the pics up of the clutch tonight when I get home and pics tomorrow of the block.
    That's about it for now.
    Feb 19 2011
    Brisbane
    What was wrong with your last bumper?
    Build is coming along quickly!
    How much power are you hoping to put down with the new setup?
    May 12 2009
    Detroit Metro Area
    Nothing just the usual rocks chips and bullshit, I sanded it down before I blew my motor and was going to paint it but I didn't see a point at that time to do it since I wouldn't be driving it. As for power I want at least 340-350 wheel on pump gas and meth on this setup, my next setup I want 500+ whp on pump gas.
    Here's the clutch that came in.....
    Question, can I re-use my pressure plate bolts from my old one or do I need to buy new ones?
    Senior Member Four Rings ThatA4T's Avatar
    Jun 10 2009
    98 A4 1.8T Quattro, 66 vw bug Rat Rod
    Denver CO
    Replace them
    Double DIN swap, pioneer avh4000, TONS of suede, 15% tint, Forge 007, apr/vdo, rs4 grille, GIAC chip, Depo ecodes with 55w 5000k HID's, ST Coilovers, 034 street density motor and trans mounts, 034 snub w/ bracket, 034 aluminum subframe bushings, valeo single mass cluth/flywheel setup, new control arms and axles, evo ms CAI, powderoated snazzy stuff, euro trunk, multi colors, Shaved exhaust cuttout with hidden turn down tips (in progress... again)
    its only just begun...
    Dec 05 2007
    How much more would it have cost to have the shop assemble your block? Or you just find comfort in knowing that you yourself assembled it?
    May 12 2009
    Detroit Metro Area
    I will only pay for service if there is something I cannot do or don't want to do. I'm not sure how much thy would of charged to assemble the bottom end but it isn't brain science and this isn't the first motor I built. The machine shop asked if I wanted them to hang the pistons and I said no ($75), the only thing they did that I didn't feel like doing was gapping the rings.
    I feel like a bigger man knowing that I built it myself and not some shop. Also for piece of mind "I know" I torqued everything, I know I greased this, I know I installed that right ect. I'm certainly not saying I'm a pro engine builder or anything but I'm not a noob at it and I think this motor should be very healthy, I don't care for max power I'd rather have a engine that is strong and healthy.
    /rant lol
    Dec 05 2007
    Why so mad? haha
    May 12 2009
    Detroit Metro Area
    Lol not mad just excited to drive this thing again.
    Active Member Four Rings Turbwhistle's Avatar
    Jan 02 2011
    Common, where are the pictures of this block?
    May 12 2009
    Detroit Metro Area
    Lol Monday for sure I will pick it up. This weekend I was pretty busy we had a family party Saturday and Sunday (today), so Friday before work I had to set up tables, chairs, and what not. If I didn't have anything planned for this weekend I would of started assembly of the motor, but then again the ARP main studs are going to be here Thursday.
    May 12 2009
    Detroit Metro Area
    So I picked up the block and couldn't take any pictures since I'm at work right now, I will snap some when I get home later on. Machine shop said they couldn't resurface the wheel since it's a dual mass and that I could run it like that, got me a little skeptical. They said they mic'd it and checked for out of round, came out fine they said. So should I just go over with it with 100 grit sandpaper? Also they didn't label or mark my rods, I'm not trying to put the rods in backwards and have problems.... I have the IE rep rods rifle drilled, anyone know what I should do? The pistons aren't marked either but I can figure that out.
    Dec 05 2007
    I thought only thing that mattered was having the tangs on the connecting rod facing the intake manifold? Since the block and parts are fresh, I am not sure the orientation of the other parts (pistons and wristpins) matter. If I'm wrong, someone please correct me (still learning).
    Also, why the 228mm over the 240mm clutch? Simply because of cost?
    May 12 2009
    Detroit Metro Area
    Thanks I will let other chime in too but thats what I figured.
    Yes because of cost at the moment. My main priority is to get the cat back on the road asap, so it was either 540 shipped of 1075 shipped, and if this one starts to slip than I will have enough money later on to upgrade to a 240mm. I could of bought it right now but than other parts would of been delayed and like I said I need this thing back to life.
    Thanks for the info though.
    May 12 2009
    Detroit Metro Area
    As promised.
    ARP Head Bolts
    Polished Crank, Rods, and Pistons
    Close up
    From this.....
    To this.....
    I got the dilemma figured out about my question, I was thinking too hard for some reason.... better to think than to not think at all.
    Dec 05 2007
    So, only tang orientation matter in your case?
    May 12 2009
    Detroit Metro Area
    Pretty much, I was just confused for a little bit how they actually balance a motor..... The rods are all the same weight as is the pistons so they don't take anything off (as far as the rods) to balance the assembly. So pistons or rods can go in any cylinder they want (tang orientation like you mention) and there is really no way to put in the pistons wrong (I mean there is but I won't lol), since I have the beveling for the valves on my pistons I can't really mess up.
    May 12 2009
    Detroit Metro Area
    This weekend is plasti-gauging, engine bay clean up, remove axles, remove steering rack, remove center diff (ship to JHM), swap cams, change lifters, change one valve (I don't like the way it's looking me in the eye, I can tell she wants to go) and probably start putting the motor together but depends on how late it is. Have to hit the stealership (or All European or S&G Imports) sometime this week to pick up flywheel bolts, pressure plate bolts, pilot bearing, exhaust gaskets (turbo to dp, turbo to mani, mani to head), oil and coolant line gaskets, and some other little things.
