Results 1 to 6 of 6
    Active Member Two Rings quattro4me's Avatar
    Jan 29 2005
    99.5 A4 TQM , 86 4000 CS QM, 05 Mini Cooper S
    4 rings or terror
    won't do more than 1800rpm!?!
    so i got about a 1/4 mile from my house yesterday and my car shut off! it cranked very slow when i restarted it, and oddly the check engine light for my rear o2 was gone, and now it will only do 1800rpm. i hooked up my vag, and it has no codes and is not in limp mode. any ideas
    Senior Member Four Rings somebody5788's Avatar
    Aug 13 2008
    Indiana
    Quote Originally Posted by quattro4me View Post
    Miles? When was the last time the timing belt and water pump were changed?
    -Nic
    2011 Honda CBR250R - gas sipping toy
    2001.5 Audi S4 - APR 93/100 | 710n's | EvoMS intake | RS4 clutch | RS4 Grill | Plasti-Dip'd center console | Podi gauge pod | VDO boost gauge | TSX-R clear lenses
    1994 Suzuki RF900R - It needs some love but it'll get there!
    1994 Jeep Grand Cherokee - rattle canned OD green Zombie Response Vehicle
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    Might be a simple question but is there gas in the car? I had an occasion where I was kind of far away from a gas station and I was on fumes. About 1/8 mile away from the gas station I was just about out of gas and my car wouldn't go over about 2000 RPMs .
    Jason
    Jan 29 2005
    4 rings or terror
    136k miles, the water pump, all of the valves, timing belt, tensioner, rollers, and PS pump all have less than 10k on them (i sheared the keyway in my crank pulley 10k ago) and yes my gas cap is tight, and i'm at half a tank. my fuel pump is a bosch repacement unit that has less than 30k on it. i have also tried a new air flow meter and ignition module, and compression is good on all cylinders. this one really has me stumped. i'm starting to wonder if my ECU took a crap.
    Active Member Three Rings TConklin821's Avatar
    Mar 17 2011
    Binghamton, New York
    If that's what you think, see if you can find someone with the same car and swap ECU?
    2001 A4 1.8TQM. Custom turbo back (eBay test pipe, LaBree downpipe, 2.5 inch piping back to a MagnaFlow muffler). Stage 1 tune. K&N Cone filter. RS6 Wheels painted dark gray with Continental DWS tires. ST Coilovers. Coming soon...2.0 coil packs.
    For sale...Brand new, never used, still in box Bosch rear o2 sensor.
    Jan 29 2005
    4 rings or terror
    Quote Originally Posted by TConklin821 View Post
    i know that there is a PES tune for my turbo, and the MIKA tune, i have the old ATP software from before they came out with the eliminator kits. Anybody know what other tunes work with a GT28R (GT2560R)?
