Results 1 to 8 of 8
    Mar 03 2010
    66 Monte carlo, 63 GT 850
    Rutland, MA
    1.8 Clutch replacement? Pull motor or Transmission?
    Which way is easier to do a clutch in a 2000 A4 1.8T Q?
    Pull motor out front or pull transmission from bottom?
    Senior Member Four Rings ThatA4T's Avatar
    Jun 10 2009
    98 A4 1.8T Quattro, 66 vw bug Rat Rod
    Denver CO
    engine and tranny together ill never do it any other way
    Double DIN swap, pioneer avh4000, TONS of suede, 15% tint, Forge 007, apr/vdo, rs4 grille, GIAC chip, Depo ecodes with 55w 5000k HID's, ST Coilovers, 034 street density motor and trans mounts, 034 snub w/ bracket, 034 aluminum subframe bushings, valeo single mass cluth/flywheel setup, new control arms and axles, evo ms CAI, powderoated snazzy stuff, euro trunk, multi colors, Shaved exhaust cuttout with hidden turn down tips (in progress... again)
    its only just begun...
    Senior Member Four Rings walky_talky20's Avatar
    Jun 30 2008
    Erie, Pennsylvania
    If you have a lift, tranny out the bottom is probably the fastest and is definitely the way a shop would do it. If you don't have a lift (but have an engine hoist), then pulling the engine out the front (or pulling engine/trans together) is probably a better choice. This is especially convenient if you are doing other service at the same time (timing belt, seals, mounts, etc). This is if we're talking 1.8T. If it's a V6, leave the engine alone IMO.
    I will be doing a bunch of upcoming service on my 1.8T including mounts, turbo, cat, t-belt, etc. If I was going to do a clutch at the same time I would pull the engine to do it seeing as the front would already be off.
    2001 Laser Red A4 1.8TQM, APR 93, 710N, electronic oil pressure gauge, B6 Sport 17's, OEM Sport Shocks, H&R Sport Springs, My 5-Speed Swap
    Need to borrow a Cam Chain Tensioner Tool? Just pay shipping ($4 total). PM me.
    "If i had a manual for my commuting, i would literally...LITERALLY...kill myself in the face. Kill myself dead... right in the face." -toaster
    Oct 21 2005
    y
    If doing JUST the clutch, pull the tranny. If doing maintenance stuff, pull engine. Haven't tried both engine and tranny together.
    Pulling the engine costs more money (coolant and gasket sometimes not reusable).
    Registered Member Three Rings
    Aug 10 2009
    Rochester, NY
    Quote Originally Posted by ricekikr View Post
    Pulling them together I think is faster if you REALLY know what you are doing. I can get a b5/b6 into the service position in no time (goes the same for women).
    2002 B6 A4 1.8tqm: TurboSmart DV, 2871 Elim, ATP Manifold, Revo Tune, 630cc injectors
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    Below is a 1.8T clutch DIY just removing the trans.
    Click HERE
    Jason
    Jun 10 2009
    Denver CO
    Quote Originally Posted by John Gutmannnn View Post
    ive had my car in service position so many times my guess is i can have it apart in 20 min or so. i had he engine and tranny out in about 4 hours id say basically by myself had some help for the first couple hours but the actual removal was done alone. and this was the first time pulling the engine from a b5 for me. its really quite simple if you get a feel for it before jumping into it and do your research. ill be pulling mine back out to do a build shortly.
    Mar 03 2010
    Rutland, MA
    Thanks to all who replied. I opted for the pull out the bottom.
    I had all ready swapped the 5 speed to a 6 speed including all the driveline. Basically I needed to replace the rear crank seal which is teflon and I being old school used grease on it..... ARgh.
    I found the diretions in the box when I was going to throw it away. Never noticed them before and it said exclusively not to use oil or grease. So was looking for info on which might be easiest.
    anyhow, I took it out, fixed to steering rack boots, and new rear calipers, rotors and pads including the rear crank seal in 8 hrs. Made pretty good time and thanks to all that replied.
