Results 1 to 7 of 7
    Active Member Two Rings Rule22's Avatar
    Nov 19 2010
    Chicago
    2001 audi a6 4.2
    2001 audi a6 4.2 is shaking rpms are are steady the check engine light was flashing went soild then turned off it shakes and sounds ruff idk what it is it happens in all gears drive park neutral ect please lemme know asap
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Pull codes, see if its just 1 or 2 cylinders or all of them. If its just 1 or 2, swap coil packs and recheck codes and see if the misfire follows the coil packs, then you need new coils. Try fresh plugs too if its not the coils
    Nov 19 2010
    Chicago
    Yea ima check codes wen i get home is it safe to drive you think?
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Flashing CEL isn't good. Try to keep it in low RPMs and as little throttle as possible. But honestly I would drive it as little as possible until you get it resolved.
    From my experience, I had misfires on cyl 4 and 5, I just replaced my spark plugs and never had an issue again. Might be a good first step, probably the cheapest option too.
    Nov 19 2010
    Chicago
    Ok yea the plugs are about 10k old
    Senior Member Three Rings pohsib's Avatar
    Jan 04 2009
    Vancouver, BC
    Items for Sale
    Pull your MAF connector and see if it smoothens out. Your trans will shift a bit rought but at least you'll know it its that. My MAF went bad and was causing the same issues.
    Nov 19 2010
    Chicago
    Codes said back fire no cyc name tho
