Page 5 of 18 FirstFirst ... 3456715 ... LastLast
Results 161 to 200 of 707
  1. #161
    Senior Member Four Rings BUSAfREAkA4's Avatar
    Dec 17 2009
    Busa has a 1.3L engine so ill call it a small compact
    NJ All Day
    when are you doing photo's at that globe? I wanna come!
    -Nick
    REDRUM
    seph: who's ricky and why were you at his place with all those dildos?
  2. #162
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    2010 A4, 2000 S4, 2003 A4 Avant, 2007 Dodge Caliber
    Falcon, CO
    Quote Originally Posted by Staz View Post
    iphone pic but pro shots at this location coming soon
    Is that the same globe that is Iron Man 2?
    2010 A4 Meteor Gray ~ DD.
    03 A4 Avant ~ Polar White ~ 2.7TT Swap/Build thread
  3. #163
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '02 A4 1.8TQT // '05 MV Agusta F4-1000
    Mo County, MD
    Is this build done yet? The tiptronic community is waiting...
    Audizine's most powerful & most respected B6 Tip
    Previous: 283.4 awhp - 287.1 ft-lbs. | 93 octane
    UPDATE New build in progress
  4. #164
    Active Member Four Rings Staz's Avatar
    Jul 03 2010
    QUEENS, NY
    yep thats the same spot that iron man 2 was filmed
    refilled the power steering fluid .. hopefully it hasnt all magically disappeared again..
    i need to pickup injectors .. recommendations ??
    also motor mounts and tranny mounts.. was going to go with 034 track density for both. opinions ?
  5. #165
    Jul 03 2010
    QUEENS, NY
    Ok so it after filling it yesterday morning i checked it again just now and its at the minimum line again .. Wtf ?
    No leaks either on the floor
  6. #166
    Senior Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM
    Long Island
    where is that globe exactly?
    2005 Audi A4 1.8T Quattro SE- 6 Speed Manual - Light Silver Metallic
    REVO Stage II, TT225 Injectors, 034 High Flow Cat, Forge TIP, Forge 007, Magnaflow 14851, K&N Drop-In, CiM Boost Gauge, H&R Springs, Koni FSD's, RS4 Sway Bar, 18" C5 RS6's, Blackout Grilles, 8000K HID's (Lows & Fogs), Smoked Tails, S4 Grille, Pioneer AVIC D3, EuroPlate, Tint..
  7. #167
    Jan 30 2007
    Falcon, CO
    Quote Originally Posted by gtsingh91 View Post
    Flushing Meadows - Corona Park, the sight of the 1964 - 1965 world's fair.
  8. #168
    Senior Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    1983 Toyota Cressida, now new and improved w 401,000 km (AKA the shitmobile)
    It has to be going somewhere, no way around that. If there's no leaks on the floor, it's probably occurring under pressure. My guess is that it's likely on the inner rack seal. Fill your reservoir start the car up and turn the wheels back and forth on the spot. If that doesn't make a puddle then rev it up to 3000-4000 in neutral and turn the wheels. If that doesn't do it, then let the car come up to operating temp and try the same thing. That'll be exactly the same conditions as if you were moving.
  9. #169
    Senior Member Four Rings Bische's Avatar
    Jun 03 2009
    '02 1.8TQM Wagon, '96 Ford Mondeo 2.0RS
    Sweden, north
    I bet the fluid is inside the boot(s) covering the inner tie rods.
    -Bische
    2011: 16.16sec@88mph
    163whp/208wtq
    <Bische's Wagon - The thread>
  10. #170
    Jul 03 2010
    QUEENS, NY
    ok so theres no leaks on any hoses and the rack is dry ..
  11. #171
    Sep 20 2006
    Mo County, MD
    How much fluid have you put in so far?
  12. #172
    Jul 03 2010
    QUEENS, NY
    on my way home tuesday night i started noticing the noise so i parked it and left it. wednesday morning i popped the hood and the resevoir was completely dry (atleast thats how it looked) so i filled it over the max line to see how much it would drop again.. drove fine - this morning i start the car and its making the noise again when i turned the wheel.. i check the level and its way below minimum so i re filled it now. i figure maybe air got into lines so it just needed to drink it up
  13. #173
    Mar 27 2010
    Correct me if I'm wrong, but the power steering system doesn't pass through any other fluid reservoir on the car (i.e. like how coolant can leak into oil without dripping on the ground). So if it isn't in the reservoir, it has to be leaking into or onto something.
  14. #174
    Sep 20 2006
    Mo County, MD
    You're fine and there is no leak IF
    a. the hoses are dry on the outside
    b. there is no puddle when you park
    c. there is no puddle in your bellypan.
    So, 2 things:
    The system needs more fluid.
    The noise you hear is due to the air in the system displacing where the fluid should be. That will work it's self out eventually.
    EDIT: Most importantly, make sure all the hoses clamps are tight because if not, this will allow air to get into the system again and the pump will make noise.
  15. #175
    Jul 03 2010
    QUEENS, NY
    yep the hoses are dry and not cracked. I dont have a bellypan so it would be on the floor and both days ive checked and the floors been dry.. i remember having to fill up my reservoir last juneand havent had to worry about it since then.. and now its back.. any other reasons why it would be running out like that ?
  16. #176
    Sep 20 2006
    Mo County, MD
    It's possible, as zumbu says, you might have a leak but only when the system is under pressure. I would make sure all clamps and fittings are nice and snug. Also, you may need to bend and flex the hoses to help reveal any cracks, if present.
  17. #177
    Jul 03 2010
    QUEENS, NY
    And it disappeared again
  18. #178
    Jul 03 2010
    QUEENS, NY
    Quote Originally Posted by Bische View Post
    ding ding ding !! you are correct .. had an audi tech just look at and yup its chillin in the boots !
    time for a new rack
  19. #179
    Mar 27 2010
    Quote Originally Posted by ZimbutheMonkey View Post
    Aww, no ding ding for me?
  20. #180
    Jul 03 2010
    QUEENS, NY
    :o zimbu wins !
  21. #181
    Senior Member Four Rings EErie B6's Avatar
    May 30 2008
    2005 allroad & 2004 B6 A4
    PA, but my true love is Jersey
    I say PSi Concepts 18g Turbo.
    Do it.
  22. #182
    Sep 20 2006
    Mo County, MD
    You said....
    So how is there fluid there now all of a sudden? You really didn't check the rack or you would have seen the fluid just sitting there in the inner tie rod boot......hmmmm. Anyhow, glad you solved the mystery.
    time for a new rack
  23. #183
    Jul 03 2010
    QUEENS, NY
    i personally didnt get under the car to check it .. i brought it to my mechanic to check it out and he said he didnt see anything (customers not allowed in work area for insurance purposes) .. kinda lame that he didnt spot it ..
    today i took it to the audi dealer by me and the foreman actually took a look at it and spotted it .. glad he did .. but now i have to change my rack :(
  24. #184
    Senior Member Four Rings jayiszraw's Avatar
    Aug 03 2009
    new york
    yo yo heres where i come to the rescue Click
    Revo stg 2| Cone filter| boost brothers fmic| custom exhaust| tein super streets| B5 S4 front brakes| Usp front| S4 rear| 20% tint|
  25. #185
    Senior Member Four Rings Dan[FN]6262's Avatar
    Sep 12 2008
    02 A4, 94 GMC, 06 450R
    South Central Pa, Dundalk MD
    Quote Originally Posted by EErie B6 View Post
    Do it.
    gay.
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
  26. #186
    May 30 2008
    Quote Originally Posted by Dan[FN]5857 View Post
    gay.
    As a person of the homosexual race, I take offense to that.
    -John
    "get the biggest of everything you can. always. that's a winning combination. everytime. just ask the military." -Dan[FN]WTF
  27. #187
    Sep 12 2008
    < hug >
    < no homo >
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
  28. #188
    Jul 03 2010
    QUEENS, NY
    so what do u think i should do dan <3
  29. #189
    Senior Member Four Rings Kittrell's Avatar
    May 07 2008
    '05 Ultra Sport
    Seaside, OR
    PTE 5128.
    USP CLUB MEMBER #62
    - DJ
  30. #190
    May 30 2008
    Yeah Dan...
  31. #191
    Senior Member Four Rings kneel's Avatar
    Dec 01 2007
    Atlas Gray Revo Stg.3 Avant, MK5 GLI
    Orange County, NY 10918
    Yeah Dan?
    Neil_
    2003 Atlas Gray Avant w/ REVO STG.3
    PSi Concepts 20g Turbo..... Baby Recaro Seats!
    PODI
    Dubs on Defrost 5 - April 7th, 2012 - Westport, CT
  32. #192
    Jul 03 2010
    QUEENS, NY
    2868 has surging problems..
    18g would be maxed out and dont want to kill the turbo that fast
    what else is there for atleast 350awhp
  33. #193
    Sep 12 2008
    drop in rods, 830cc injectors, drop in 005, nice intercooler, 5857, = 350awhp all day long on stock small port head and "returnless" fuel system. Turbo won't be breaking a sweat. also be easier on your autotragic trans.
    just spending the $700 up front to make your bottom end bullet proof opens up a world of fun turbos.
    that's just what I'd suggest. save a lot of money switching between setups. I know all about that bullshit. it's best just to get it out of the way in the beginning and get a turbo with real potential.
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
  34. #194
    Jul 03 2010
    QUEENS, NY
    more info plz dan - shoot me a pm or ill shoot u one either way def want more info on this
    anybody have any experience with these guys: http://shop.rackdoctor.net/2002-A4-R...95-25896-4.htm ??
  35. #195
    Jan 30 2007
    Falcon, CO
    Good find, I need to get a steering rack as well.
  36. #196
    May 07 2008
    '05 Ultra Sport
    Seaside, OR
    How do you go from an HTA2868 to a PTE5857? Thats like going from a GT2871R to a GT3582R.............
    USP CLUB MEMBER #62
    - DJ
  37. #197
    Sep 12 2008
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
  38. #198
    Jul 03 2010
    QUEENS, NY
    Do it right or do it twice !
  39. #199
    Senior Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 USP, 68 Camaro, 00 Cavalier
    Lancaster, PA
    Um yes trust me
    -Andrew
    2005 Dolphin Grey Ultra Sport
    HTA3582R 1.8L
    AEB IECVA1
    Agtronic Motorsport
    PARTS FOR SALE
  40. #200
    Sep 12 2008
    trust Andrew and I
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
