I have access to c5 a6 rear brake set up, calipers, rotors, and i think carriers. By any chance will these fit on my b5 a4 1.8tqm avant? I searched and i found nada. Please help, thanks.
Should be the same. Measure the rotors to compare. If sizes are different you might only have to swap caliper carriers to get them installed correctly.
Dolphin Gray 2005.5 Audi A4 2.0T Avant 6MT
Santorin Blue Pearl Effect 2001.5 Audi A4 1.8T Sedan 5MT
some of them came with 255x10 rear rotors IIRC these used the same caliper as our a4 with a different carrier, again IIRC. there area a couple people around using them to balance out there A8/TT setups.
na they use a 256x22 vented rotor, cant use their rotors with our caliper, but the s4 rotors+calipers with carriers bolts on. hold up, I will have a look for them.
If you get the parts for free I would go for it, its like a 10 min job and replacment parts are the same cost. I would imagine most A6s came with the 245s though. See if the fronts are 312x25 then you could upgrade them as well, dont know if the carriers will bolt up or if you will need TT ones though.
The backs should do, it depends on which engine weather you will just need the carriers and the disks, or if you will need everything. the V8 came out with 269x22 rears, so you would need everything. it would also be a good idea to go with the fonts from the same car which are 321x30s the calipers wont bolt up, you will need adapter brackets, or you could go with the A8/TT setup to balance. The 2.7T came out with the 321 fronts (same as above) but one of the 245 or 255 rears from my previous post, all of the NA V6s came out with either the 288 or 312 fronts and 245 or 255 rears. the rears of these you will only need the carriers if it is the 255 or it is the same as the ones you have already (245s), the fonts im not sure if you will just need the carriers or if you will need everything, it depends on the bolt patten on the uprights.
the car is a 2004 c5 a5 s-line 2.7t so yes or no? I will need adapter brackets, would i be worth it, and i plan on doing tt carriers and a8 rotors soon. i need new rotors any way.
They will be 245 or 255 rotors, I cant tell you which, the only way to know is with part numbers or to measure them. they should just bolt to your uprights and you will only need the caliper carriers, this is good it means you dont have to disconnect your stock caliper. You might want to check in the C5 section to be absolutely sure they didnt change the uprights, just because it is the last year before the C6 came out, but i wouldnt think they did. for free I would say just go for it and see. the only thing that happens if you cant bolt the carrier to the uprights because they used a different bolt patten, you chuck em out, havnt lost anything.
If you do need adapters, its a waste of money, just find some S4 calipers, it will be cheaper and better.
