Results 1 to 24 of 24
    Active Member Four Rings Turbwhistle's Avatar
    Jan 02 2011
    Possibly bad cv boot?
    So today i was switching my wheels over and i have been hearing a thud thud thud thud thud while i drive, at all times, breaking, cornering, accelerating, etc. So while i was changing the wheels and i had the car jacked up, i checked the cv boot. I also did the wheel bearing test where you pull and push on the tire to see if it is loose. Well, when i got to the rear passenger size i saw this.(the picture) I saw some grease but everything was not covered it was kind of scattered spray. Am i missing the clamp? Is the boot bad? Would this be the cause of the thud sound? Please help me out? I searched a bit and it seems like wheel bearings is mainly when cornering and going over speed bumps. I also heard that when you have a bad cv its more of a clicking. Please help me.
    Active Member Four Rings coolgraymemo's Avatar
    Jun 10 2010
    Northern California
    Not a lot of people check the technical. Get this moved into the main model discussion if you really want help.
    - Memo
    SSR Comp. STaSIS S/S. GIAC. Forge. Valeo E-Codes.
    Jan 02 2011
    I was going to ask a mod to move or delete, but i didnt see any online.
    Sep 01 2007
    90 Eclipse GSX. 04 A6 4.2l
    W. Mass.
    Your missing the clamp for what ever reason. You can buy a universal cv boot clamp at a parts store, but a really big zip-tie works just as well, and you prolly got some kicking around the house.
    This how ever isn't causing your thud noise. That is most likely ball joints or TREs. Possibly a loose wheel.
    Unless all of the axle grease came out of that boot and the CV joint is smoked.
    Senior Member Three Rings FNK's Avatar
    Mar 07 2010
    Audi A4 2.8L 2001.5 Quattro
    Montréal, Éts
    I've done over 2000-3000km with a leaking cv boot before changing the boot, and there was still plenty of grease inside. Some get out, most stay in.
    As for the thump... look if it's not a control arm, or rod-end, or the steering rack.
    I doubt it's the cvboot because some grease got out, just a coincidence.
    Senior Member Three Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM, 03 A6 3.0QA
    Danville, KY
    Like mentioned, I would check ball joints and tre. My car was making several thud sounds, until I replaced the control arms in the front. I get a popping sound now, mainly due to a tre I didnt replace b/c the jam nut is seized. CV makes a clicking noise, Ive got the same problem.
    1998.5 A4 1.8TQM / FrankenTurbo F4H-L / C2 Motorsports Tuning / 440cc Injectors / C2 Billet 3" MAF Housing / Cat Delete / Vibrant Muffler
    2003 A6 3.0QA
    Mar 07 2010
    Montréal, Éts
    What is that "TRE"?
    Active Member Three Rings SS92's Avatar
    Jul 11 2011
    Charlotte, NC
    Quote Originally Posted by FNK View Post
    What is that "TRE"?
    Tie rod ends ;)
    2000 B5 A4 1.8T ATW GT2871r, Unitronic/Maestro tune, RaceTec FMIC, etc... - > Stockpiling for BAT
    Mar 07 2010
    Montréal, Éts
    Ohhhh
    Active Member Three Rings jaychen's Avatar
    Feb 19 2011
    Brisbane
    My money would be on tie rod ends or cv joint.
    Jan 02 2011
    I am working on a video to show the sound a little bit, i will see what i can do.
    Jan 02 2011
    ok here it is, you can hear it pretty well, turn your computer up. If you can not see it please tell me.
    http://s1087.photobucket.com/albums/...t=e7d554f6.mp4
    Jan 02 2011
    bump, can anyone identify what the thumping noise is from the video?
    Feb 19 2011
    Brisbane
    Have you checked your wheel bearings? its sounds like whomp whomp whomp whomp whomp? yes/no?
    jack the car and try and turn your wheels with your hands (steering lock will need to be engaged for the fronts).. see if there is any movement in all 4 wheels.
    it was raining as well so if thats not the noise you are talking about we will need a clearer video.
    Jan 02 2011
    The noise i am talking about was from :25-:30 ish, it may sound like a whomp whomp, i am no good with spelling sounds/ describing what they sound like. I have jacked that car up multiply times and tried the wobble test, is that what you are talking about? Or are you trying to say spin the tires as if the car was moving?
    Jan 02 2011
    I got a few pictures and a video.
    This is driver side front.
    Video:
    http://s1087.photobucket.com/albums/...3D921613e0.mp4
    Jul 11 2011
    Charlotte, NC
    Jan 02 2011
    Thanks, i sent him a pm. So you think that is the issue causing the whomp whomp whomp?
    Jul 11 2011
    Charlotte, NC
    Quote Originally Posted by Turbwhistle View Post
    My control arms caused a bunch of clunking, and really bad steering wheel wobble. Someone else will have to chime in about the whomp whomp whomp
    Jan 02 2011
    ok, i hope they do... thanks.
    Active Member Three Rings TConklin821's Avatar
    Mar 17 2011
    Binghamton, New York
    Good luck man. As far as your CV boot goes, the boot itself is fine. As mentioned above, the clamp came off, happened to me too. It COULD behoove you (if you have a grease gun with a needle attachment) to slide a needle under the end of the boot and bump some more grease in there (be sure you get the right kind) before sealing it back up, just to ensure you have enough.
    2001 A4 1.8TQM. Custom turbo back (eBay test pipe, LaBree downpipe, 2.5 inch piping back to a MagnaFlow muffler). Stage 1 tune. K&N Cone filter. RS6 Wheels painted dark gray with Continental DWS tires. ST Coilovers. Coming soon...2.0 coil packs.
    For sale...Brand new, never used, still in box Bosch rear o2 sensor.
    Feb 03 2008
    Waterford, CT
    I've got a similar thing going on with my 98 A4 Avant. I believe it is a rear wheel bearing. What did you find was wrong?
    I also have the same thing going on with the rear outer CV joint boot, in that it is missing the metal band that goes around the inner side of the outer boot.
    120 miles/day, to and from work, Monday through Friday...600 miles a week, ~30K miles a year.
    Active Member Two Rings Brown's Avatar
    Dec 25 2010
    A4 B5 1.8tqm
    Georgia
    It sounds kinda like a bad wheel bearing, have you checked to see if all the wheel lugs are tight? lol
