Results 1 to 12 of 12
    Stage 2 Banner Advertiser Four Rings Adam@SPP's Avatar
    1951 pontiac 2007 harley deluxe
    D2S8 failing transmission?
    '01 124,xxx miles without any issues whatsoever thus far...
    tranny fluid flush at 114k miles.
    last night I came home and just as I pulled down my street, while in D, revved up high and kicked back into gear...
    ...this was just as I got on the throttle after a rolling stop.
    I parked the car and didn't drive it till just now...drove it for about 10 minutes w/o a problem and then it happened again...and again.
    it's slipping "out of gear" at low speeds/gears (1, 2, and 3) and then catching. it was hard to even make it home without it doing it.
    just seems weird this literally all of a sudden happened...without any signs/symptoms/issues.
    any tips?
    any ideas?
    any advice on moving forward?
    thanks guys
    -a
    customizable brake rotors, made-to-order | adam's rotors inc.
    adamsrotors.com
    , info@adamsrotors.com, tweet @adamsrotors, or facebook
    the S4: ROTORS4, the S2: ROTORS2, and the S8: ROTORS8
    Senior Member Two Rings TozoM8's Avatar
    Sep 17 2010
    Black on black 01 Twin Turbo S8, 6MT, built in SRX 01' allroad 2.7T
    Chicago
    It has a broken trust bearing behind clutch B. The front clutch assembly slams back at sudden acceleration and the fluid line doesn't line up anymore. You need a rebuild.
    01' black on black twin turbo S8 with 6 speed manual (euro TDI 6th gear), RNS-E, Passport SRX
    Forum Moderator Four Rings HIstateS8's Avatar
    Feb 16 2005
    Kaneohe, Oahu, HI
    I'm cringing myself. I just hit 78xxx and I'm waiting for my transmission to fail as well, because I know it's coming one day or another.
    -Brandon S.
    Moderator
    PM any questions or concerns
    2002 Metallic Black //S8
    Jun 27 2010
    US
    Quote Originally Posted by HIstateS8 View Post
    Just 78K?! You're just approaching the break in point...enjoy the many thousands of miles you have to go before worrying about that.
    In the meantime, you can worry about leaking coolant pipe on your oil cooler and output shaft flange seal on your center differential leaking gear oil onto your left cat (it'll smell like burning rubber and ass) :)
    Feb 12 2011
    D2 S8, Porsche 928's, Ducati 996 sps
    Frisco, TX
    Not to hi-jack this thread, I have that smell you described and saw that my left cat area has oil on it. What do I need to repair?
    Thanks
    ^ so PM him then...
    Quote Originally Posted by TozoM8 View Post
    see you are the transmission master, shooting you an email now.
    adamsrotors.com
    Jun 27 2010
    US
    Quote Originally Posted by Dannyfumi View Post
    Thanks
    Extremely common problem...I replaced mine for the 2nd time at about 90K miles (dealer did 1st replacement at 40K under CPO warranty).
    http://www.audipages.com/Tech_Articl...placement.html
    Feb 12 2011
    Frisco, TX
    Quote Originally Posted by silverd2 View Post
    Thank you!
    Danny
    Active Member Two Rings '01-S8's Avatar
    Aug 04 2011
    BLK/BLK- '01-D2-S8 /// '96 EJ6 SOHC Boosted Civic
    PKNY
    Stage 3 Forum Advertiser Four Rings Scotty@Advanced's Avatar
    May 16 2008
    South Texas
    Excellent candidate for a 6 speed swap.
    Active Member Four Rings Nollywood's Avatar
    Nov 03 2011
    '03 Audi A4 Avant TQ 5MT, '95 Audi A4 Quattro 4,2 V8 32V, '08 BMW 120d M-Sport
    Aso Rock!
    Quote Originally Posted by Scotty@Advanced View Post
    That's the spirit!
    2003 Audi A4 Quattro 1.8T (BEX) Avant 5MT, Crystal Blue.
    1995 Audi A4 Quattro 4,2 V8 32V (AHC) 6MT, S8-Powered DTM Race Car.
    1996 Audi Cabriolet 2,6 V6 12V (ABC) 4AT, Indigo Blue, New V8 / Quattro / 6MT Project.
    2008 BMW 120d (N47) 5-Door M-Sport 6MT, Shwartz Metallic, Grey Leather.
    Apr 05 2011
    2008 Audi A4 S-line
    New Providence, Pa
    Yeah, I had replaced mine twice now, No big deal, Worst part was removing the exhaust band bolts, that was made short order of by an angle grinder. Now I have to change two more on another '01 and a '99. Its what I do apparently. Well, what are friends for huh? (there tools and talent, that's what) Have fun
