Originally Posted by
Turbwhistle
Would it perform better with the molded pipes or would the diy kit be comparable?
I mean, technically speaking. Yes it will perform better in the intercooler piping since you will have less turbulence due to having the connected pipes and the size difference going from silicone to pipe and back again. However, the difference is going to be quite small given that both sets of piping are the same diameter. The biggest difference you would see between intercooler kits is the actual intercooler. Not just the core, but the end tanks.
So between the two options of molded pipes and DIY pipes, you won't notice a difference except during the install process since molded will be easier.
