Transmission Photos:
As I have found the A4/S4 transmission (5HP19FL (front-trac) and the 5HP19FLA (Quattro)) are both the same in torque ratings. the factory torque rating for both of these transmissions is 310Nm or approximately 265 ft lbs. I no longer wonder why the S4 tip can’t handle even a chip. ZF is given a torque rating by the car manufacture and in the case Audi told them to make a transmission that can handle the factory torque rating of 155 ft lbs for the 1.8. Well it would be useless to make a transmission that can handle just that rating so they made one that could handle double that or close to it at 265. I was asking about parts to make it stronger and ZF doesn’t make any parts to beef up the transmission. So there went my idea of getting parts from them. They also had no idea who makes any parts to make the Tip stronger. ZF only makes stock parts to replace any parts that might have broken.
Here is the 5HP19FLA application guide
Here is some of the technical information and gear ratios. however this is for the front-trac. the quattro ratios are the same except for 5th gear that is .74
information about the 5HP19FLA
Here is the transmission Oil Reference guide
In regards to the Audi lifetime fluid. That is a bunch of crap. ZF recommends that you have the fluid changed every 60 thousand miles. No where did they tell Audi that the fluid is lifetime. If you don’t change your fluid you will actually end up doing more damage in the long run because the fluid will get burnt and not flow correctly and cause you to burn up the valve body, and friction plates.
The only place I have found and most if you already know about Level 10 in New Jersey. They seem to know what they are doing but I am going to keep my personal views and opinions about them out of this article. I also have found IPT that does transmission rebuilds as well
I will also be adding information to this article when I come across new information If you have any other questions concerning the Audi Tiptronic transmission please feel free to PM me.
