Page 2 of 2 FirstFirst 12
Results 41 to 44 of 44
  1. #41
    Senior Member Four Rings walky_talky20's Avatar
    Jun 30 2008
    Erie, Pennsylvania
    The one nearer the front of the car runs to the Leak Detection Pump. The one nearer the firewall and coolant bottle just runs to the vacuum reservoir in the fender.
    Check the last photo in post #5. The one that is circled corresponds to item #12 on the factory vac diagram (to vac reservoir). The other line below that corresponds to item #16 (to LDP).
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, APR 93, Splitter, electronic oil pressure gauge, B6 Sport 17's, ST Coilovers,
    Need to borrow a Cam Chain Tensioner Tool? $4 for shipping. PM me. *Unavailabe*
  2. #42
    99.5 A4 28RS 1.8TQS VolcanoBlk
    Vancouver, BC Canada
    Since i am too AEB, do you have any pictures or instructions? Thanks tons and much appreciated.
    Quote Originally Posted by xdewaynex View Post
    AEB here and I deleted the pcv and all vacuum and check valves, except for the brake booster, and lines needed for boost gauge and turbo. I will say, that since I deleted all the vac lines, I never hooked my vac reservoir back up, and my cruise control doesnt work. Ill be hooking it back up soon and seeing if that fixes it. I also done an occ setup, with the use of 034's block breather adapter.
    David L.
    www.FormaTuning.com
    www.VancouverAudiClub.ca
    99.5 A4 GT28RS 1.8TQSM Volcano Black & 99 CW Acura Integra Type-R #0010
    Go-Eurodyne/GT28RS/ATP/Siemens/Bailey/Blitzkrieg/FMIC/Southbend/Fidanza/Greddy/Innovate/Walbro
    Footworks-Roti BLQ/CCW Classic/Flik LEX/Bilstein/Eibach/034/Stern/ASP/APR
    Misc-Porsche/S4rear/Rieger/A!/Ecodes/V&S/Sparco/Podi/Blitz
    Soon-SnowPerformance
  3. #43
    Senior Member Three Rings Spykce's Avatar
    Aug 06 2008
    Angola, In
    Resurrection bump! For anyone who has removed all of these systems. Have you had any drivability issues? My wifes avant needs a major refresh or to just remove everything. The suction pump and check valves on the EVAP system are the worst of the systems.
    Eric
    '00 A4 1.8T Quattro
    K&N panel | GIAC | Forge 007 | VDO Center vent boost gauge | Debadged | H&R sports | Bilstein sports | H-Sport Sway Bars | APR TBP
  4. #44
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    I just did of this what I could, the only real thing to remove was the purge valve and the vac. lines going to it from the TIP and the lines going behind the block and under the coolant reservoir. Removed all the old shroud back to behind the block and un-tangled all this mess. Evap deleted (I left the line going under the driver side fender with a check valve going to the bottom of the IM). I will leave the evap purge valve electronically plugged in and the hard line is under the fender. I put all the wires for the purge valve, N75, and ICM behind the second firewall. I've still got cleaning up to do here. Hopefully no CEL once all is said and done.
