well im going to be as precise as i can and sorry for my bad english :P, i hope u'll understand.
first of for you who dont know how to remove the front bumper here is a guide
http://www.audizine.com/forum/showth...oval-of-Bumper
After removing the bumper and you dont know how to open up the headlights here is another guide.
http://www.audizine.com/forum/showth...-Corner%29-Mod
but to make it easier for you.
it takes about 10 min to open up a headlight, not so complicated at all, you will need a flat screwdriver and a heating gun.
the pics are from Phils DIY: on how to open up the headlights, but in this case theese are not the same headlights we are going to open so thats why im telling you it is easier :)
1. remove the 5 clips that are holding the headlight with the other part of the headlight
2: after removing the clips, remove the rubber protector:
3: now use the heating gun like ont he pic Phil is using, for like 3-5 minutes about 10cm from the headlight, so that the rubber holding the headlights becomes soft.
After that try to take the headlight apart.
You need to pull a bit, if you have someone there he/she can help you heat the rubber while you are removing the headlight.
now the headlight is open.
well as you can se that the LED part of the headlight is on the other sitde of the headlight, so now what you need to do is unscrew the screws take of the Ground cable and then the headlight is free, but first remove the screws from the original LED stripe
Here is the original LED's
Here si the canbus with the resistor, this thing is connected with the original led, cut it off
Now the DRL plate is loose :), you also have another plastic shield in front of the led remove it before drilling.
So what you need to do now is to remove everything from the LED plate, like this picture:
Glue the led stripe on the plate where the last led were sitting, as on this picture
Connect the wires, the ones you did cut of from the original led, and test if the led works, you can do that by connecting the headlight with the car.
if it works then close the headlight first you need to reheat the glue and the press everything in again and dont forget to put the clips and the rubber shield on :)
i know this might seem to be comlicated, its not its just me who cant explain very good on how to do, but i hope that you understand, jsut ask me if anything will explain as best as i can.
