Page 1 of 8 123 ... LastLast
Results 1 to 40 of 281
    Stage 2 Banner Advertiser Three Rings Info@EuroCode's Avatar
    Dec 24 2008
    Torrance
    .:Eurocode Tuning:. Alu Kreuz Group Buy, B8 A4/S4/A5/S5/Q5, Round 2, July 22-Aug 21
    GROUP BUY IS: CLOSED
    Due to popular demand, the team at Eurocode has opened a second group buy on our Alu Kreuz (pronounced kroitz) drivetrain stabilizer for the B8 chassis Audi's to include the A4, S4, A5, S5 and Q5.
    Our Alu Kreuz replaces the factory multi piece drive train stabilizer with one solid, lightweight structural member to further stiffen the chassis and prevent unwanted suspension deflection. All 6 mounting points are secured to one single plane; the net result is sharper steering with a reduction in chassis flex.
    Who would benefit from the addition of the Alu Kreuz? We feel that if you enjoy spirited driving, like to take the on ramps and off ramps of the highway a little quicker than you peers, enjoy a nice drive through the canyons (twisties), the occasional track day or high performance driving class or just want to run your car balls out on the road course, the Alu Kreuz is perfect for you.
    During our testing of the B8 chassis cars which are comprised of the Audi A4, S4, A5, S5 and Q5, we found that there was quite a bit of torsional flex coming from the factory subframe/engine carrier. This torsional flex produced what we felt to be incorrect steering sensitivity and response in all aspects of driving. To combat this unwanted characteristic, we did a thorough examination of the front suspension, chassis unibody, and the engine carrier/subframe. Our conclusion was that the OEM hollow steel drivetrain stabilizer underperformed.
    The team at Eurocode set out to combat this torsional flex and decided to redesign the drivetrain stabilizer. Our first step was to analyze the material that the factory stabilizer was made up of and then create a load case scenario in which to test it under. We sent out a sample for materials testing and found the factory stabilizer to be made up of carbon steel with a density of 0.284 lb/in3, predominately hollow and stamped into shape. The OEM stabilizer is made up of nine separate pieces, and they are all welded together to form one single unit. Once all of this data was collected and loaded, our team set out with the goal of improving chassis rigidity and weight reduction. Our team found that a replacement stabilizer manufactured out of billet aluminum would accomplish our goals, so the next step was the design process.
    Our design process went through several revisions, with each version being loaded into computer modeling to test how it would stack up against the inferior OEM product; these revisions were also built and tested not only on the road, but as well as on a closed course with the feedback provided by a professional driver to the design engineers.
    The finished product, which we dub “Alu Kreuz”, is incredible. It features a one piece, billet T7 aircraft aluminum construction, type III hard anodized coating, and all necessary provisions to attach the OEM sound deadeners. It requires zero modification to the vehicle, and works perfectly with the OEM power steering cooler. The Alu Kreuz is also nearly two pounds lighter than the OEM brace and greatly improves chassis torsional rigidity. It looks amazing as well.
    Independent analysis was performed on the product and the conclusions were that in each of the pre set load case scenarios, the Alu Kreuz deflected less than the OEM stabilizer, carries less stress for a given applied load and the fatigue life of the product is greater than OEM.
    *Does not fit right hand drive cars
    Installation manual may be downloaded here
    Terms of the group buy are as follows:
    • Group buy will run from July 22, 2011 through Aug 21, 2011 (one month)
    • Individual discount will be based on the number of participants in the group buy
    • A fully refundable $200.00 deposit is required to join the group buy (backing out will affect others)
    • We will update this post as necessary to inform the participants of the discount level
    • All orders will need to be paid in full prior to shipment of the group buy items
    • A link will be provided to place deposit
    Group buy pricing:
    • 1-5 participants $389.00
    • 6-10 participants $379.00
    • 11-15 participants $369.00
    • 16-25 participants $349.00
    • 25+ we will ship for free in the contiguous USA
    List of group buy participants:
    1. routertyty SHIPPED
    2. Stubek SHIPPED
    3. rayjpepSHIPPED
    4. NWS4Guy SHIPPED
    5. TXB8S4 SHIPPED
    6. PsYkHoTiK SHIPPED
    7. CreoSTi LOCAL INSTALL
    8. Jlarke SHIPPED
    9. NJDeVsFaN SHIPPED
    10. WhoS4 SHIPPED
    11. Cooper993 SHIPPED
    12. blackESfour SHIPPED
    13. crossover SHIPPED
    14. socfan12 SHIPPED
    15. brandonb SHIPPED
    16. xaser240 SHIPPED
    17. Petroguy SHIPPED
    18. helix139 SHIPPED
    19. JMike SHIPPED
    20. mobyrz SHIPPED
    21. Ddun LOCAL INSTALL
    22. WAZZU STU SHIPPED
    23. DUBSPORTN SHIPPED
    24. wwhan SHIPPED
    25. nivlek SHIPPED
    26. akim_hobo SHIPPED
    27. jayq16 LOCAL INSTALL
    28. Chestlock SHIPPED
    29. MrPerfect SHIPPED
    30. HawksBAC SHIPPED
    31. Rockst8r SHIPPED
    32. phanker SHIPPED
    33. bbhbba SHIPPED
    34. primetime SHIPPED
    35. rick b SHIPPED
    36. englishbay SHIPPED
    37. hyho SHIPPED
    38. xstwin SHIPPED
    39. shookatash SHIPPED
    40. rx7ven SHIPPED
    41. DavidB8 SHIPPED
    42. dingosatemyaudi SHIPPED
    43. Dubber4life SHIPPED
    44. willyspub SHIPPED
    45. AudiAnnie SHIPPED
    46. IvanS4 SHIPPED
    47. eirebob SHIPPED
    48. Djc4 SHIPPED
    49. jceven SHIPPED
    50. ctjibber SHIPPED
    51. Alex'S4 SHIPPED
    52. killaapp SHIPPED
    53. CoupeGT84 SHIPPED
    54. ciscokidz SHIPPED
    55. rs2urq SHIPPED
    56. cblock SHIPPED
    57. jasonshhuang (TW) 1 SHIPPED
    58. jasonshhuang (TW) 2 SHIPPED
    59. jasonshhuang (TW) 3 SHIPPED
    60. jasonshhuang (TW) 4 SHIPPED
    61. jasonshhuang (TW) 5 SHIPPED
    62. jasonshhuang (TW) 6 SHIPPED
    63. jasonshhuang (TW) 7 SHIPPED
    64. jasonshhuang (TW) 8 SHIPPED
    65. jasonshhuang (TW) 9 SHIPPED
    66. jasonshhuang (TW) 10 SHIPPED
    67. ahcow SHIPPED
    68. yfrancis SHIPPED
    69. Akrion SHIPPED
    70. Deckdout2 SHIPPED
    71. agkellyboy SHIPPED
    72. stan211 SHIPPED
    73. eleusive SHIPPED
    74. popplulaa SHIPPED
    75. HyperM3 SHIPPED
    76. BillyG SHIPPED
    77. Acowabunga LOCAL INSTALL
    78. evanstonjohn SHIPPED
    79. clochner SHIPPED
    80. astrolite SHIPPED
    81. 4rociouS SHIPPED
    82. gmermel SHIPPED
    83. SupraBlur SHIPPED
    84. JonS4 SHIPPED
    85. FatalBert SHIPPED
    86. AudiBmw SHIPPED
    87. kaliper SHIPPED
    88. rcaro900ss SHIPPED
    89. brady5501 SHIPPED
    90. conky SHIPPED
    91. LeadToRome SHIPPED
    92. bcborn SHIPPED
    93. Imola_B8 SHIPPED
    94. Wahrheit SHIPPED
    95. cory_can SHIPPED
    96. Bernardo Carpio SHIPPED
    97. Brabo1892 SHIPPED
    98. mage0608 SHIPPED
    99. quickshooter SHIPPED
    100. lbonl SHIPPED
    101. Brosen SHIPPED
    102. JMN SHIPPED
    103. pkasso SHIPPED
    104. speycaster SHIPPED
    105. TofuShop SHIPPED
    106. zed 2.0 SHIPPED
    107. ctwickman SHIPPED
    108. A4Ber SHIPPED
    109. metalica08 SHIPPED
    110. turr520 SHIPPED
    111. Muray
    112. tph1207 SHIPPED
    113. MalSer SHIPPED
    114. CJ_S4 SHIPPED
    115. goony SHIPPED
    116. S5xy SHIPPED
    117. JasonR SHIPPED
    118. JasonR SHIPPED
    119. Audacious SHIPPED
    120. rnlabas SHIPPED
    121. 15DGR V6 SHIPPED
    122. Projectile SHIPPED
    123. simplicity SHIPPED
    124. QuattroWerks SHIPPED
    125. jrod 1299 SHIPPED
    126. petrashevsky SHIPPED
    127. BOconnor SHIPPED
    128. Nellie51 SHIPPED
    129. Twei
    130. SPatel SHIPPED
    END OF GROUP BUY
    Customer Reviews!!
    http://www.audizine.com/forum/showthread.php/437726
    Quote Originally Posted by mikejsully View Post
    After much anticipation I was able to get the Alu Kreuz installed on Thursday. Right out of the box you the piece feels solid and rigid, it is not until you compare the factory part to this that you really understand how much Audi skimped on bolstering the subframe in this car.
    Install was easy, since the install manual was not complete when these shipped I emailed Eurocode for torque specs and they promptly replied. This is my first interaction with them and I am very impressed with the customer service they have provided so far. OK Back to the install... Once the car is up on stands and the belly pan was removed it only took 10 minutes to swap the parts. very straight forward! just watch out for the power steering line that is attached to the brace... you do not wan to rip that sucker off. Overall the hardest part of the install is mounting the belly pan back to the Alu Kreuz. The provided machine screws are almost too short and it makes finding the holes difficult. Had I been using a lift this may not have been an issue.
    Driving impressions - I felt an immediate improvement in how the front end behaved. At times I felt the car (stock) was a bit mushy(sorry for the vague description, but it is the only word that suited my feelings) up front, especially in slow to medium speed turns. Almost felt like the outside wheel wanted to lean over. That feeling is all but gone now. I have to admit, I also had the thought "I just paid good money so there needs to be a tangible result... it is not just my mind I swear" but after a back to back drive in a relatives S5 (which stock feels a little more solid than the stock S4) I could really notice the difference. Very happy with the result, turn in is crisper and the mushy front end is banned. Not sure if this is just me but my car also seems to track better as well.
    For such a simple solution that will never be seen this is a beautiful piece to look at, if only I was under the car more to admire it! at least it is safe under the belly pan. The stock piece is a joke in comparison. Almost looks and feels like an afterthought. A sad sign of a company known for over engineering their products moving to cost cutting measures in the wrong areas.
    If you just commute in your car or never drive in a spirited manner (not sure why you would buy a car like this if so) then this would be a waste of money. The S4 is a fine handling car out of the box, but this just pins the front end down so you can enjoy it even more. At the group buy price this part was a steal, after driving around in it for a few days I can say I would gladly have paid the full price plus shipping.
    Thank you Greg at Eurocode for the quick responses and help with the torque specs. Cannot wait to give you more of my money... if only I could justify the headers. How about an APR Pulley and install Kit once you get some in stock?
    Mike
    Quote Originally Posted by jimmyrecluse View Post
    I've got this. It's awesome as fuck. Looks hot too.
    Quote Originally Posted by rugbylion View Post
    I had this installed yesterday and it makes a very noticeable difference in handling and I am very pleased with this mod. The car just seems to be even more capable of tackling low and high speed turns with ease. I couldn't believe the stock part compared to Eurocode's Alu Kreuz Stabilizer. The stock part looked like a skinny pretzel.
    As always, David and Greg rolled out the carpet for their customers and I was also invited to drive David's Sprint Blue Beast. What they have done to this car is incredible! I'll be headed back there for some H&R spacers soon. Thanks again to EC for their service and the new stabilizer!
    Quote Originally Posted by AofC_RR View Post
    Just got mine on the car friday. Definitely helps tighten up the steering. I know it's less of an issue for you S4 guys but in the B8 A4 it's too light.
    Quote Originally Posted by pyramid View Post
    Got mine installed today. I'm very happy with it. I would describe the sensation like putting a good strut tower brace in another car.
    Impressions: Car seems to track straighter/truer under straight line hard acceleration/braking and cruising. Front end feels like there is more feel than before, especially at the limit. On my test drive today I drove exceptionally hard into a few corners and instead of the stock uncertainty about how much the front end was pushing it felt like there was immediate feedback of exactly how much grip/slip was going on. Everything feels better connected and the communication is much improved.
    The front actually feels so much more solid now that I could really feel the slop in the rear end and differentiate the two easily. This made me wonder, is there a similar part that could be upgraded in the rear to serve a similar function? I would buy one of those today if such a thing existed.
    EuroCode Tuning, Inc.
    1872 Del Amo Blvd Unit A
    Torrance, CA 90501
    310-294-8108
    Veteran Member Four Rings Stubek's Avatar
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    Deposit Paid
    2011 A4 Avant Meteor Grey/Black, Titanium Package, Prem+ Nav, B&O. Tint, LED license plate lights, LED interior lights, custom sub, lots of VAG updates, APR Stage 1
    Build thread: http://www.audizine.com/forum/showth...ead?highlight=
    Active Member Two Rings rayjpep's Avatar
    Jul 06 2009
    New Jersey
    deposit paid
    Senior Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2008 Land Rover LR2 2010 Audi S4
    Deposit paid!
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR Stage 2 w/pulley + exhaust
    **** Have USB HEX-CAN Vag-Com cable if you need someone local to mod you ****
    My Fuelly mileage
    Apr 22 2010
    TX
    Deposit paid.. Can't wait!
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    Can you confirm if this will work on a Q5 or A5 since they share the B8 chassis?
    Active Member Three Rings PsYkHoTiK's Avatar
    Aug 23 2010
    Redmond, WA
    Deposit Paid...
    2011 Audi B8 S4 | Ice Silver | DSG | Sport Diff | APR 93 stage II+ V2 | APR Pulley | APR RSC Catback Exhaust | APR Stage II Intake | Eurocode Alu Kreuz | StopTech ST-60 355mm front BBK | StopTech Slotted rear rotors | Carbotech 1521 Bobcat "street" pads | Carbotech RP2/XP10 "track" pads | Custom front brake air cooling | Track/Summers: 19" OZ Racing Superturismo LM w Michelin PSS | Winter/Ski Resort: 19" Audi RS4 wheels w Conti DWS
    Stage 2 Banner Advertiser Four Rings David@EuroCode's Avatar
    May 26 2004
    Quote Originally Posted by Stubek View Post
    Yes, this will work on Audi B8 A4 / B8 S4 / B8 A5 / B8 S5 & Q5 all models!!
    This part will not work on RIGHT HAND DRIVE applications!!!
    "If everything seems under control, you're just not going fast enough."
    - Mario Andretti
    Senior Member Three Rings CreoSTi's Avatar
    Feb 22 2004
    Los Angeles, CA
    Put in my deposit too.
    -Mike- : 2011 Ibis White S4 : S Tronic : APR Stage II + EMCS : APR RSC exhaust : AWE S-Flo : 19x9" BBS LM : KW V2 : E-codes : Eurocode Alu Kreuz : EuroGEAR/DEVAL carbon front lip + rear valence : oCarbon cluster surround : Recaro ProSport
    Nov 11 2009
    1998 Honda Civic EJ4, 1988 Austin Mini
    Vancouver Canada
    Add me in. I will pay the deposit tonight
    Current Mods:
    Stratmosphere Intake, 50% Tint, APR ECU + RSC Exhaust Upgrade, BBS CH-Rs 19x9.5, KW V3, H&R Sway Bars (Front and Rear), Hawk HPS Brake Pads, APR Supercharger Pulley Upgrade
    Upcoming Mods:
    APR/Custom Supercharger Cooling System
    Mar 16 2011
    Saline, MI
    Deposit paid.
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    Quote Originally Posted by David@EuroCode View Post
    I'm right handed!
    Sep 29 2009
    I'm right handed!
    LOL
    My Fuelly mileage
    Senior Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2011 MKVI GTI 4 Door DSG
    Pittsburgh/PA
    Seems like a straightforward install but any instructions available?
    Hot Photos<--Click Here
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG
    2012 S4, Monsoon Gray, 6MT
    www.AskMy2Cents.com
    Dec 24 2008
    Torrance
    Quote Originally Posted by nick71692 View Post
    Quote Originally Posted by Info@EuroCode View Post
    Not too difficult of an install
    Torrance, CA 90501
    310-294-8108
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    Will this include the longer screws people have mentioned needing?
    Dec 24 2008
    Torrance
    Of course!
    Torrance, CA 90501
    310-294-8108
    Active Member Three Rings K1speeder's Avatar
    Aug 29 2010
    San Diego/Philadelphia
    Deposit paid!! Let's get 25 so these can ship ASAP!
    2010 S4 Prestige, Meteor Gray, S-tronic, B&O, Nav, Silk Nappa, Gray Birch, RS5 Pedals, RS6 Shift Knob, Hardwired V1, APR CPS Coolant Separator (Ordered), EuroCode Alu Kreuz (Ordered)
    AWE Intake
    2009 Q5 P+, 3.2, NAV, Brilliant Black, Beige Milano Leather, Ash Wood, Hardwired V1
    I have HEX-USB+CAN Vag-Com cable if a local member needs some mods
    Active Member Three Rings jordancl's Avatar
    Jun 29 2010
    Recommended mod! Especially at the discounted price.
    Jul 02 2010
    Delaware
    Deposit paid.
    Dec 17 2008
    '11 A4 2.0T Q 6MT, 1996 A4 2.8Q
    Charlotte, NC
    Hey I'm in this thread! If you're on the fence as an A4 guy see my build thread for more of a review. Well worth it. When you see the stock and Alu Kreuz side by side you'll understand. It's a very well made and engineered part. This thing should be stock!
    Keep up the good work Eurocode!!
    Ol' Whitey - 1996 A4 2.8 Quattro 5 speed Arctic White with Remus exhaust
    #2 - 2008 A4 2.0T Quattro 6MT Quartz Gray -Prem, Heated seats, Convenience, Bluetooth, Ipod, Bose with AWE exhaust (1/08 - 1/11)
    #3- 2011 A4 6MT Quartz Gray - Premium Plus, B&O, Titanium - Full Gen1 AWE dual exhaust, Eurocode HFIC pipe, Trufit hose kits & Alu Kreuz DTS, 3M Clearbra, Piano Black Dash Surround, MY10 rear headrests, Huper Optik, S-line Stoneguards
    Audi Brand Specialist
    B8 Titanium Club Member #4
    Senior Member Three Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    is it more for shipping to canada?
    B8 S4- large dose of testicular fortitude
    Gone 06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
    Dec 24 2008
    Torrance
    Quote Originally Posted by sciblades View Post
    Free shipping is for USA customers, Canada shipping is calculated at checkout
    Torrance, CA 90501
    310-294-8108
    Active Member Two Rings socfan12's Avatar
    May 14 2011
    MB GL450
    Deposit paid! I'm in!
    Jan 14 2011
    Redmond, WA
    Deposit paid. Hurray!
    Sep 09 2008
    Deposit paid
    Nov 11 2009
    Vancouver Canada
    Deposit paid
    Current Mods:
    Upcoming Mods:
    Registered Member Two Rings Petroguy's Avatar
    Jul 06 2011
    St. Louis
    I'm in!
    Jason B8 S4
    Senior Member Three Rings ACowabunga's Avatar
    Feb 24 2010
    OC, CA
    Can we pick up the piece from the shop as well if we are in the area?
    2010 Audi S5: Meteor Grey || Tuscan Brown
    Senior Member Four Rings helix139's Avatar
    Apr 21 2010
    Florida
    deposit paid!
    2011 S4 Premium Plus 6MT, Sepang Blue Pearl, Black Silk Nappa, Sport Diff, B&O, Nav, Ti Pkg
    May 26 2004
    I'm right handed!
    But have you driven Japan with your right hand?
    RightHandDriveJapan
    - Mario Andretti
    Senior Member Four Rings Chestlock's Avatar
    May 30 2010
    Victoria, BC
    Trying to pay deposit... website won't let me. PM sent David.
    May 30 2011
    Hong Kong
    Is the brace of the RHD and the LHD B8 of much a difference? Or just a matter of different location of the screw holes? Please do make us RHD car owners one....
    Apr 02 2011
    Warrenton VA
    Deposit paid.
    2011 S4, Quartz Gray, Nappa Black/Tuscan, Prestige, S-Tip, Sport Diff.
    2008 Corvette Z06
    1964 FIA Cobra replica
    Sep 29 2009
    Quote Originally Posted by Chestlock View Post
    You can alwasys ship to me and pick it up on a road trip bro
    My Fuelly mileage
    Senior Member Three Rings ddun's Avatar
    Jun 06 2009
    Stanton, CA
    Deposit sent
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    looks like 20 already with those who say they paid! I wonder if we can get the first 25 in under 24 hours and get these shipped next week!
    Senior Member Three Rings DUBSPORTN's Avatar
    Nov 26 2009
    2010 S4 ICE SILVER, 1990 VW CORRADO VR6 MB QUARTZ BLUE, 2008 MERCEDES E350 SPORT, 1996 VW JETTA VR6
    PSL/FL/South East
    DEPOSIT PLACED!!!
    1990 VW CORRADO OBD II VR6 QUARTZ BLUE :thumbup:
    2010 AUDI S4 3.0T ICE SILVER PREM PLUS :thumbup:
    2008 MERCEDES E350 SPORT BLACK :thumbup:
    1996 VW JETTA VR6 COOL WHITE
    MY MOTOR WAS RUNNING LIKE A CHAMP AND I STILL SWAPPED IT!?!
    Dec 24 2008
    Torrance
    Quote Originally Posted by ACowabunga View Post
    Yes, that would not be an issue at all.
    Our website does not accept international credit cards, you will need to call us at 310-294-8108
    Quote Originally Posted by HKCW View Post
    The steering box on the RHD cars interferes with installation. It is going to take a redesign of the product.
    Torrance, CA 90501
    310-294-8108
    Registered Member One Ring nivlek's Avatar
    Mar 14 2008
    Deposit paid!
