Page 2 of 2 FirstFirst 12
Results 41 to 73 of 73
  1. #41
    Mar 26 2007
    Colorado
    I think I am going to pick up some Paint polish and Glanz wax. I have a 7 year old S4, but the paint still looks great even after a simple hand wash. However I have very minor swirl marks, only seen under my garage light
    CURRENT:
    2011 B8 A4 Avant
    2011 Infiniti g37
    2008 4Runner
    2015 GMC sierra
  2. #42
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 23 2004
    those would be great choices.
    are you doing this by hand or machine?
  3. #43
    Veteran Member Four Rings khalimadeath's Avatar
    Nov 18 2009
    03 S6 Avant, 70 VW Bus
    Reno NV
    Used the 1Z by hand, polish then wax. Turned out FANTASTIC. Used the extra paint cleaner on a couple problem areas and the paint damage cleared right up.
    Dont have a fancy camera but the results are clear
    -Zach-
    The C5 Union////////////
    The United States Constitution
    (c) 1791. All Rights Reserved
  4. #44
  5. #45
    Stage 1 Advertiser Two Rings Mike @ einszett's Avatar
    May 03 2007
    Austin, Texas
    Very nice! Thanks for sharing!
    Mike
    einszett North America
    german waxes polishes cleaners | since 1936
    support@1z-usa.com
    www.1z-usa.com
    888-719-4698
    The einszett Detailing Guide - Articles, Terminology and More...
  6. #46
    Feb 26 2008
    Items for Sale
    Hey mike, my ac was smelling really bad so I went ahead and order your kilma klean product.
    It worked a little bit but the ac still stinks, any ideas? Should I use another bottle? Thanks
  7. #47
    Feb 23 2004
    did you try removing your cabin filter?
  8. #48
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    I just bought my second audi and I want to give it a beginning clay and rewax to get the factory crap off of their and start it off fresh. Any tips and tricks? I have never used a clay bar, but have use waxed plenty of times lol. I always did one panel at a time.
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
  9. #49
    May 03 2007
    Austin, Texas
    Quote Originally Posted by Dirtyylicous View Post
    On a scale of 1-10 with 10 being most severe, what was it before and what is it after the treatment?
    - Check your cabin air filter
    - Make sure the evacuation tube (drain tube) is free and clear. If you run your A/C on a hot day you should see plenty of water underneath the car.
    - Make sure there's no debris like leaves in the fresh air intake
    If a system hasn't been treated in a while or never treated, sometimes a second treatment is needed.
    Mike
    support@1z-usa.com
    www.1z-usa.com
    888-719-4698
  10. #50
    May 03 2007
    Austin, Texas
    Quote Originally Posted by seal66 View Post
    First, congrats! With a new car, I personally feel that clay would be too aggressive. A mild polish like PolishWax topped off with Glanz Wax would start you off on the right foot.
    PolishWax will remove any contaminants while enhancing the depth and gloss. Glanz Wax will seal it off with durable protection. Apply both with a foam applicator pad. Hope this helps!
    Mike
    support@1z-usa.com
    www.1z-usa.com
    888-719-4698
  11. #51
    Feb 26 2008
    Items for Sale
    Sorry for taking so long to reply, the cabin filter is new.
    Before the treatment on a 1-10 it was a 9 now id say a 7, its worse for the 1st 1 min then it gets a little better. The intake is clean and im not sure
    how to check the drain tube
  12. #52
    May 03 2007
    Austin, Texas
    Sorry for not getting back to you sooner. As far as checking the drain tube, water should be draining from the evaporator box (which houses the evaporator core) and you should see dripping underneath the car after running the a/c. Not sure how old your car is or what region you live in (lots of humidity or dry climate) but if the evaporator core is fairly contaminated, a second application might be required.
    Mike
    support@1z-usa.com
    www.1z-usa.com
    888-719-4698
  13. #53
    Feb 26 2008
    Items for Sale
    Thanks, ill check it out
  14. #54
    Senior Member Three Rings SIMPLXA4's Avatar
    Aug 09 2009
    97 Audi A4 1.8T
    Utah
    Items for Sale
    Is there a type of brush I could use for cleaning alcantara? Ive also heard there are brushes out there that I could use for "bringing life back into worn alcantara"? And last but no least is there a cleaner for alcantara you prefer?
  15. #55
    Veteran Member Three Rings rkdiddy's Avatar
    Nov 22 2006
    '13 Q5 and '14 IS350
    So Cal
    I would love to hear any tricks to applying Cockpit. I've always used just a microfiber towel. I notice it seems to go on a little blotchy.
  16. #56
    Veteran Member Four Rings beantown's Avatar
    Jul 27 2009
    '15 S3
    Boston
    Items for Sale
    Quote Originally Posted by rkdiddy View Post
    Use a foam applicator pad. It will spread the product evenly. Then lightly buff off any remaining residue with a microfiber.
  17. #57
    May 17 2012
    Houston, TX
    Items for Sale
    Mike - what's the metallic polish wax and how's it different from the polish wax. Both are in red cans. For metals only?
    My car is a new S4 and I want to try out the polish wax and gland combo. But need some exact application instructions.
    Car wash first. Dry. Then start polish with hand applicator. Wipe off with microfiber. Then glanz with hand applicator. Wipe off with microfiber. Sound about right?
    How bout time in between 2-3 applications on glanz. Can it be done immediately or better to waitvan hr? More or less?
  18. #58
    Veteran Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2013 Jetta GLI
    Ohio and GTA
    Items for Sale
    No questions here either but i own and use almost every product of yours and wont go anywhere else.
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG (Gone)
    2012 S4, Monsoon Gray, 6MT (Gone)
    2014 S4, Glacier White - fully loaded
  19. #59
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Have Napa leather in my 2012 S4. I purchased the 1Z einszett Leather Care Lederpflege to use on my seats but was curious about the steering wheel. Can I use it on the steering wheel, is the a best way to apply it and will it discolor the stitch, its gray in color.
    Thank you.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2 & TCU Tuned / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    12.3 @ 112mph on 93oct file
    THEN THEN THEN Rinse & Repeat!
  20. #60
    Feb 23 2004
    it should work nicely on the steering wheel, what I would do is apply the leather care on the mf applicator pad or towel first and then blot fold the mf towel or app to blot it down then apply on the steering wheel.
  21. #61
    Jan 04 2013
    Phoenix, az
    Thank you. Is "blot fold" when you apply the product to the towel then fold it over so less product gets onto the surface? Basically using the opposite side of the towel from which it was applied.
    Sorry if this is an amazing stupid question. Never heard that term.
    Thanks and love the products.
  22. #62
    Feb 23 2004
    blot and fold the towel so you spread it out on the towel then apply and buff off.
  23. #63
    Jan 04 2013
    Phoenix, az
    OK, LOL
    Now I feel stupid. Trying to make it more complicated than it is.
    Thanks
  24. #64
    Jan 04 2013
    Croghan NY
    Items for Sale
    Does 1Z make a 'restore' product? My wifes car the vinyl on the rear bumper (jeep) has faded to a light gray (from original black) and I'd like to get it back to it's original condition or something close? I'm hoping 1z makes a product that is good for that job, as well as cleaning up all the plastics under the hood of MY car (audi s5).
    any suggestions? Some other folks have told me i might need to pre-wow/black wow it, but i'd rather not have to collect another brand of products for 1 little project and then never use them again.
  25. #65
    Senior Member Four Rings JeriQo's Avatar
    Jul 08 2015
    mike -
    i bought the klima cleaner and they center vents have the screen and it prevents me from inserting the tube all the way down.
    any advice?
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 15mm rear
  26. #66
    Senior Member Three Rings Avus RS4's Avatar
    Apr 09 2015
    Niwot, Colorado
    If there is a question I'd like to ask Mike is about 1Z einszett Plastic Deep Cleaner
    It looks like the bottle, label and the content have been redesigned and reformulated. I don't like it. It feels more like a conditioner than it does a cleaner, it even smells diffrente.
    I'm very disappointed.
    This is what the bottle, old formula looked like:
    This is how it looks now:
    2007 Avus Silver Rs4
    Bone Stock
  27. #67
    Feb 17 2013
    Q7 . A3 3.2 Quattro and way too many cars in the garage.
    Burlingame
    Items for Sale
    I do like the older stuff. I do have both of them and feel they both are different and smell different .crazy they changed them
  28. #68
    Jul 08 2015
    can someone help me out?
    i have a question 2 posts up
  29. #69
    Apr 09 2015
    Niwot, Colorado
    Quote Originally Posted by JeriQo View Post
    mike -
    any advice?
    Try from the filter cabin.
    Also have you replaced the filter cabin?
    If not, you should, it will help quite a bit, and then spray some of the 1Z where the filter cabin goes, then install the filter and turn the heater on closed windows for a few minutes on recirculating mode
    Bone Stock
  30. #70
    Jul 08 2015
    Quote Originally Posted by Avus RS4 View Post
    yep, i replaced that myself 2 months ago...
    hmm not sure how thats gonna work out.. all the fluid from the spray is gonna drip on the floor.
    ive read that you just insert the tubes on driver side center vents all the way down but the theres that screen..
  31. #71
    Apr 09 2015
    Niwot, Colorado
    My bad. I thought the klima cleaner was in spray/aerosol form, it looks like it's a foam?
    I've just did mine this past weekend using Ozium.
    My best advice is to wait to see if Mike can answer your question as I've never used this product in foam form and it might take some expert advice in applying it to your car.
    Sorry, I couldn't help.
    Bone Stock
  32. #72
    Apr 09 2015
    Niwot, Colorado
    I've found this review online.
    Maybe this can help:
    This product works. It's been a month since I used it, and the mildew smell hasn't come back. I didn't get any results with first can, because I didn't know how my A/C works. After emptying the whole can into the vents, I had some liquid dripping on interior carpet, which was a sign that vents weren't open. Long story short, turn the engine on, turn A/C on, set it to central ventilation, and then turn the engine off. This will leave duct system open, so you can reach evaporator core. My A/C system has 2 motor regulated gates installed 2 inches apart (which stay open only if you turn engine off while A/C is running), plus a plastic screen between them and vents, so i had to make a small hole on it. You may need to remove dash panel around vents in order to see what is inside (recommended). Then just use a can.
    Bone Stock
  33. #73
    Feb 23 2004
    Answer from Mike:
    Please do not apply Klima Cleaner through the vents. We can’t stress enough, please read the directions on the label or visit our site for application directions at www.go1z.com/applyklima which will direct you to apply through the blower fan. Applying through the vents is an old method that is no longer applicable on many cars today. You must apply through the blower fan as we instruct. This is the only and most effective way of cleaning the evaporator. If you do not know how to do this, please have a mechanic apply it for you.
    If you have any other questions, please do not hesitate to ask.
