Page 3 of 3 FirstFirst 123
Results 81 to 106 of 106
  1. #81
    Active Member Two Rings B8_RDC's Avatar
    May 25 2010
    San Jose, CA
    Popping this up for folks that might not have seen this.
    Surprisingly my dealership did not perform this during my last oil change a few months ago. Just recently I got blinking EPC light and horrible bog on acceleration. Turns out my camshaft is riding dirty, ie metal on metal, and needs to be replaced. I've asked them to change the oil too.
  2. #82
    Jan 24 2007
    The campaign 15d6 is be must done on vehicle that was made 2009s. I haven't seen any campaign for vehicle 2010+. The campaign is open due to camshaft adjust screen coming loose and the bearing comes out and drops into the chain that might cause more damage. Also while doing adjuster unit if camshaft is damaged have to open up TAC ticket to get approved on the camshaft. Just for the information if the vehicle is out of warranty you guys should get this done, in long run might damage the camshaft which cost more than 300.
  3. #83
    Active Member Two Rings eirebob's Avatar
    Apr 13 2010
    santa rosa ca
    Quote Originally Posted by the1obster View Post
    Just had this done also. The service rep said that they found oil leaking from my drain plug and found that the drain plug treads where warped so they gave me a whole new oil pan and plug. I'm starting to think the dropped the bearing and it fell into the oil pan (i hope it fell straight through) and had to change it out. Do you guys notice the car idles rougher after the camshaft RVU?
    Just had this done when I brought mine in for the 25k.
    And no, I haven't noticed any discernable changes in idle, or any other performance characteristics.
    2009 A4 Quattro, Manual, Prem Plus, Sport Package
    Mods: APR Stage 1, Stratmosphere short shifter, Alu Kreuz, Tips, Tint, 034 Turbo hose, Cocomats. EC Intercooler pipe, hose kit. Vag.com mods.
  4. #84
    Aug 06 2009
    MD
    I just called the local dealer, Hunt Valley Audi in Maryland north of Baltimore, and the Service Adviser says he never heard of any camshaft RVU on any A4, but he ran my VIN and he said nothing came up. (This is a 2010 2.00, built August 2009)
  5. #85
    Senior Member Three Rings Kschroers1's Avatar
    Jan 12 2008
    Fresno, CA, USA
    Quote Originally Posted by wrp View Post
    Its for MY09 model year... no 2010's have posted as of right now.
    Service Advisor: Audi Certified 2011/2012
    VW Certified 2011/2012
    2011 Audi A4 Quattro 2.0T Ibis White/Tan Interior
  6. #86
    Senior Member Two Rings bluetori's Avatar
    Jan 14 2010
    an estate and LR2 CBR600RR race bike
    miserable
    Does this require an oil change if just checked? Obviously if it needed replaced they would change the oil. I ask only because I have to take mine in tomorrow.
  7. #87
    Oct 30 2006
    Audi urS6 2.2T
    Quote Originally Posted by A4_Joe View Post
    Yes it's the screen that fails, but the issue it causes is oil starvation in the head, hence why at times if it's bad enough you will get a new cyl head...
    -MilitantGrunt- Certified Audi Technician for hire: Freelance. Pm for details.
  8. #88
    New Member One Ring
    Nov 15 2011
    boston/ma
    I'm looking at the TSB
    A4 2009 9a04334-9a243268
    A4 2010 aa003650-aa027812
    an000217-an024840
    A5 2010 aa000475-aa030526
    A5 cabrio an004797-an007225
    Mine's been in the shop 2 weeks, repair bill approaching $3,000 out of warranty. The TSB is dated 7-5-2011 with revision August 3. This means that they've known about the problem for months and haven't notified owners that there's a bomb ticking in their engine. My just happended at 63,000 miles
    Talked to a mechanic buddy, they have a new design in the 2.0TFSI. Requires special tools only available from AoA to pull the valve cover, so no one outside of a dealer can crack it at this point to repair. Sounds like a revenue enhancing move for the dealers. I've been a 15 year A4 driver, 3 cars since 1997 and have helped sell several via referrals. This will sorely test whether I can continue on with a company that treats customers this way.
    Get this page 8 of 10 in Bold lettering. "If the vehicle is outside of the specified warrant period, the customer has the option to pay for the repair."
    If they had notified me that there was a grenade with the pin pulled in my engine waiting to go off, I would have beat feet to the dealer to get it done for $400. Would have been happy to do it and would have thought they are really on top of the customer service you should expect from a premium company and dealer.
    The directions for the camshaft repair are located in TSB 2023107. If anyone has a copy of that, i'd appreciate a lead on locating it.
    I could be treated like this at a Chrysler dealer with a lower shop rate....
    I asked for the CSA to save the parts. Let's see if I get them back.
  9. #89
    Senior Member Four Rings coolwater's Avatar
    Nov 06 2009
    NYC NY
    Look what a vag scan returned this evening.
    No check engine light, not sure if it's related though:
    Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K2 907 115 AA HW: 8K2 907 115 D
    Component: 2.0l R4/4V TF H14 0005
    Revision: E1H14-**
    Coding: 0104010A190F0160
    Shop #: WSC 26657 896 16801
    ASAM Dataset: EV_ECM20TFS8K2907115AA A01006
    ROD: EV_ECM20TFS8K2907115AA.rod
    4 Faults Found:
    7229 - Cam Adjustment Actuator B; Cylinder 1: Implausible Signal
    P11A4 00 [096] - Check DTC Memory
    7231 - Cam Adjustment Actuator B; Cylinder 3: Implausible Signal
    P11AC 00 [096] - Cannot Be Tested at this Time
    7232 - Cam Adjustment Actuator B; Cylinder 4: Implausible Signal
    P11B0 00 [096] - -
    7230 - Cam Adjustment Actuator B; Cylinder 2: Implausible Signal
    P11A8 00 [096] - Defective
    Readiness: 0000 0000
    -cW
    2010-A4-Q-TIP / BB - Black Int / Halogen to Bi-Xenon E-code / A5 Sline Y Wheels - Conti DWS
    GIAC ECU Stage 2(-) / STaSIS Exhaust / Eurocode Turbo Inlet / HR OE Sports/S4 Shocks / ALU Accents / LED Bulbs / Fog Rings / Reiger Style Trunk Spoiler
    AR rotors / StopTech Street Pads
    Future Mods: Side Blades / Eurocode HFIP / FMIC
    Build Thread =>http://www.audizine.com/forum/showth...m-build-thread
  10. #90
    Active Member Two Rings fromvwtoaudi's Avatar
    Oct 27 2011
    providence ri usa
    I too have a MY 2009 only had it about 2 months 38K mikes on the clock...noticed the steering vibration while turning immediately and dealer knew right away to change the power steering pump however it feels the same haha..
    But will call the dealer Monday to get this issue replaced..
    Thanks everyone for the info
    2009 B8 A4..premium plus/meteor grey pearl
  11. #91
    Oct 13 2006
    Dogville
    Thanks for posting the VIN range.
    (While my car is not in range, this does bother me. Hoping to keep mine a while)
  12. #92
    Oct 27 2011
    providence ri usa
    So just got back from my dealer and they showed me right there on the computer mine was performed during the certified pre-owned inspection a few days before I bought the car!
    One less thing to worry about ... Now if I could just get my steering wheel to stop vibrating while turning lol
  13. #93
    Senior Member Three Rings k9lovr's Avatar
    Aug 30 2009
    08 Tahoe - 20% tint
    VA
    Just dropped off my car for a coolant leak and was told that they are gonna perform the camshaft tab as well....car has 38k on it
    Current: 35% Tint, Gloss Black Grille, APR, Eurocode, StopTech, Powerslots, AWE, H&R, Eurogear, Lusch, OSIR, VMR, Hankook.
  14. #94
    Active Member Two Rings sdy101's Avatar
    Apr 14 2010
    2008 Acura MDX
    Central PA
    k9lovr, where was your coolant leak at? I smell coolant after driving my car (38k miles), but I can't find the leak. I also am eligible for the camshaft adjuster rvu, but I wanted to have some idea on the coolant problem before i took it in for service.
    Now: 2009 2.0T Ice Silver, Auto, Quattro, Prestige Pkg, Navigation
    Hoen Xenon-match Fogs | LED Interior Lighting | K&N Drop-in | Eurocode Turbo Inlet Pipe
    Previous: 2007 2.0T Quartz Grey, 6MT, Quattro , Premium and Convenience Pkgs
    APR 93 Octane | OEM Rev. D DV | K&N Drop-in | Apikol Snub Mount | Podi Boost Gauge | 50% tint | LED City Lights | 17" Sport Edition KV5
  15. #95
    Aug 30 2009
    08 Tahoe - 20% tint
    VA
    When I pulled the skid plate to do an oil change there was coolant on the cross member behind the drain plug. I started to look around and saw that coolant was leaking onto a spot just below the throttle body. I will take a few pics and post them up to give a better idea of where it was. Does the over flow reservoir look low? Mine was below the min line. I had already had it looked at before when it was low but they just topped it off and said they could not find a leak. I think it has been leaking for a while and just burning off before it dripped down.
  16. #96
    Apr 14 2010
    2008 Acura MDX
    Central PA
    Actually my overflow reservoir shows coolant near max level, so I'm not sure what's going on. Sounds like we have different issues. I don't see any leaks, haven't taken the belly pan off yet, but will have it checked out soon. Thanks!
  17. #97
    Veteran Member Four Rings oatzel's Avatar
    Jun 02 2004
    LA
    "My" (actually the ex-wife's) 09 just had this performed. They found scored cylinder heads and camshaft. Both were replaced. 23K miles.
    Current: 07 s4 avant, ibis, stasis exhaust, vogtland c/o, h-sport rs4 sways, vmr gunmetal v710s, 50/35% tint
    09 A4 2.0t, premium +, black on black, sport, nav
    Old: 03 a4 3.0qms, thermal exhaust, hyperflow, neuspeed sport, neuspeed bilsteins, h-sport (s4) sways, b&m ss, votex lip, s4 blades, rs4 reps, ecodes, rs4 pedals, 35% tint
    Older: 2000 A4 1.8TQ, bilstein/hyperco, apr, blah blah blah
  18. #98
    Forum Moderator Four Rings Blake P's Avatar
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by oatzel View Post
    Was the car demonstrating any particular symptoms prior to the RVU?
    2009 A4 2.0T quattro sedan: quartz, prestige, S Line, nav
    APR - ADV.1 - A.W.E. - StopTech - Posi-Quiet - STaSIS - Rieger - DEVAL/EuroGear - Ingolstadt-Kunst - FormulaOne - Valentine One - KW - VCDS - OEM+
  19. #99
    Jun 02 2004
    LA
    Oil Consumption and she had mentioned a ticking sound/vibration coming from the engine.
  20. #100
    Registered Member Two Rings
    Jan 04 2012
    '09 B8 A4 Quattro S-line / '69 VW Beetle
    Vennesla, Norway
    Is this world wide or only for US cars. I have a MY2009 1.8TFSI and vin is within the range. I bought it 2 months ago. Guess I have to check with the local dealer if this have been done if it applies to EU/Norway cars too.
    I have now checked with my local dealer and this was already done by the previous owner. puh, now I can relax.......for now :-)
  21. #101
    Senior Member Three Rings EuroEclipse's Avatar
    Dec 30 2009
    2010 Audi A4 Quattro / 2012 Volkswagen GTI
    Germany/Colorado Currently
    Brought my vehicle in over the weekend for maintenance. They checked to see if the RVU was required on mine and they said it wasn't. However, they did do the B&O and TPMS updates.
    2010 Audi A4 2.0T
    Engine Mods: EuroCode Tuning High Flow Cat - Lower Intercooler Pipe - Intercooler Hose Kit, APR/Carbonio Intake, 034 Motorsport Turbo Inlet Hose
    Tune: APR Stg II - Fully Loaded
    Cosmetics: OSIR Design Carbon Fiber Front Mask - Carbon Fiber Logo Base - D-trim, 35% tint
    "...every single one of ya'll is TD14LFE." - David@EuroCode
  22. #102
    Active Member Two Rings Eddie-B8's Avatar
    Jan 18 2012
    Brooklyn,NY
    they told me i have an rvu on my a4 last time i was at the dealer about a week ago... going back there on thursday to pick up gear oil and ill ask them again... has anyone done this without warranty around the tri-state area? if so how long did it take? how much did it cost? and which dealer did u go to? dont really like the guys in brooklyn....
  23. #103
    Jan 18 2012
    Brooklyn,NY
    Just got of the phone with audi service in brooklyn, ny on the phone he quoted me at around $320 +|- a few $... ill prob get it done this week and keep everyone else who hasn't done this posted... if anyone know a better place to get it done please let me know asap. thanks
  24. #104
    Senior Member Three Rings Comp4k's Avatar
    Aug 10 2009
    B8 A4
    Carlsbad, CA
    Took my 09 in for the RVU, no problems found.
  25. #105
    Jan 18 2012
    Brooklyn,NY
    About to head over to the dealer to get this done, keeping my fingers crossed that there is no other damage as I'm paying out of pocket will post back later after its done
  26. #106
    Jan 18 2012
    Brooklyn,NY
    Ok so just got everything change the tech said if I waited another month there would be a very big prob... Spent almost $400 on labor and few parts but in myimd well worth it to preven much bigger wholes in my pockets... Anyone who doesn't know if this needs to be changed just stop by your local dealer and find out, especially if you are out of warranty like me. Good luck
