Results 1 to 18 of 18
    Veteran Member Three Rings J0HN_R1's Avatar
    Jul 05 2010
    completes me...
    Calgary, Alberta
    Wierd smell...? Perm or ammonia...
    I'm getting a wierd smell the last couple days, and it comes & goes randomly...
    It smells almost identical to perm solution, or ammonia. Almost like cat-piss (but it's not).
    I know the smell of faulty catalytic converters (sulphur / rotten eggs), and I really don't think this is it.
    The smell does go away once the car is shut-off though, but is noticable at-speed or at a stop...
    * I also deleted my mufflers 3-4 months ago. The pipes end right where the mufflers joined, and point rearward on a slight angle to the corners of the bumper.
    Do you have manual trans, i know when you clutch slips it stinks, i just cant remember what it smells like exactly.
    Chris|1999.5 B5 A4 Avant 1.8TQM Brilliant black|Flickr
    PSS9 | StopTech | Fikse | Challenge Motorwerks | EPL
    Forum Moderator Four Rings SoCalS4Avant's Avatar
    Jan 24 2008
    California
    Air conditioning - mildew/mold?
    Moderator/Wiseguy
    Veteran Member Four Rings jfunkey's Avatar
    Jan 21 2009
    R32 B7/S4....2000 2.7t gone :(
    putting you into the wall
    Quote Originally Posted by J0HN_R1 View Post
    Im not sure its a good thing tht you know what perm solution or cat piss smells like. hahahahahaaaahah just fooling with ya. Good use of examples it helped narrow it down
    Maybe a few things. AC any relation to that or possibly to that. The build up of stuff over the winter can really have a bad smell when the ac comes on.
    JHM war machine. Total transformation. JHM/Tune/headers/intake manifold.
    My B7S4. Faster then my old RS4 and First B7 S4 in the 12's
    AMA member
    USMC member (active)
    Facts first member. Built and supported by many
    Registered Member Four Rings B6JoeS4's Avatar
    Sep 13 2008
    Chicago NW Burbs
    Kind of sounds like Freon to me. After I got my A/C charged, there was a lingering freon smell for a day or two. It has kind of that same "burn your nistrils" smell that ammonia does.
    Senior Member Three Rings split71's Avatar
    Jul 24 2009
    NE
    Id say check your cabin filter to see if it's wet / mildew like.
    Senior Member Two Rings audivoodoo's Avatar
    Mar 23 2010
    2004 Audi S4 6MT
    Aurora, CO
    Quote Originally Posted by B6JoeS4 View Post
    While I was in the navy we would deal with freon leaks as part as our fire fighting training. Typically freon in a colorless odorless gas, but when it heats up it becomes extremely poisons. Heated it will turn into mustard gas and have a acidic odor, momentarily, because the poison will actually burn the receptors in your nose so you wont be able to smell it for very long then you (in a closed area like a garage) pass out and die if you don't get out of that area. Im guessing its not freon your smelling.
    Jul 05 2010
    completes me...
    Calgary, Alberta
    AC works fine, and no reason why the cabin-filter would be causing it because the HVAC has been off totally when it occurs.
    I'm starting to think it maybe the cats, as it seems to be more prevalant during WOT in the lower gears. But I'm sure it's an "ammonia-y" smell.
    And having owned 4 cats over the last 20yrs (plus my parents cats), I know the smell of cat-pee. Liter-box changes are now apparently a "blue-job"...
    Oh, and my mother used to get her hair permed when I was in school. I'll never forget that smell... Ever...
    Quote Originally Posted by Turbwhistle View Post
    I know the smell of burning clutch also (dude I was working with rode the p!ss out of the work-trucks clutch), but don't think it's that either...
    Account Terminated Three Rings JohnnyAlQaeda's Avatar
    Sep 22 2009
    Colorado Springs
    is your "HVAC" set to recirculate or fresh air from outside? regardless of on or off, at speed enough air floods the engine bay to push through the filter into the car. its worth looking at.either that or someone pissed in your car. NH3 is quite a bit different from NO or NO2 so im not so sure its your cats.
    Established Member Two Rings ringsroc's Avatar
    May 11 2011
    2006 Audi S4, Tip, Brilliant Red.
    Germantown, MD
    Something else to Check is the engine compartment and hood lining for rodents. It should stink all the time, but perhaps the heat is making it worse?
    2007 VW Jetta 2.5- SOLD
    2006 Audi S4 Brilliant Red, Platinum interior.
    Senior Member Three Rings S4_Artillery's Avatar
    Apr 14 2010
    '07 S4
    Central Texas
    Did you ever think about if someone is fucking with you? Maybe there is a dead cat under your seat.
    Jul 05 2010
    completes me...
    Calgary, Alberta
    Will pull the cabin filter(s) today. HVAC isn't recirc'ing. No dead animals or pee-stains I can see (inside, or the engine-bay)...
    Jul 05 2010
    completes me...
    Calgary, Alberta
    So I'm really starting to think it's exhaust-related. Just noticed my brand-new tips are very black & sooty after only 2-3 months.
    When pulling away from a stop (50-75% throttle) & the windows are down, the back window gets condensation very briefly when the smell hits.
    Oh and 1 little tid-bit I forgot... I deleted my mufflers like 3-4 months ago. But I can't see that causing the smell.
    The pipes are cut exactly where the mufflers joined, so they end about 12" under the car. But they point nearly strait back.
    The smell is sickening, I think other drivers can smell it too... And like I said, it's most noticable under WOT...
    Jul 05 2010
    completes me...
    Calgary, Alberta
    Sorta fixed the problem, but it's not loud enough now... Reinstalled my mufflers, smell is gone...
    Next weekend I'll tear the downpipes out & beat the cat's out. Maybe they're melting/clogging/disintegrating..?
    May 11 2011
    Germantown, MD
    Well now that you added the detail that the exhaust stops 12" under the car.... Ill bet it was sickening.... perhaps even lethal at a long light.
    Jul 05 2010
    completes me...
    Calgary, Alberta
    Thing was, I couldn't smell it at stops (even with all windows down). It was only when I pulled away @ more than, say, 75% throttle...
    And like I said, the exhaust was like this for 3-4 months prior with no smell... Actually, during February & March, the pipes ended in front of the rear axles (no smell)...
    * JUST CAME BACK FROM A 30-MIN DRIVE, AND THE SMELL IS STILL LINGERING AFTER WOT (barely noticable, but noticable)...???
    Hopefully turning my downpipes into Piggies will remedy the smell. And a look-see with VAG-com...
    Senior Member Two Rings dtrizzo's Avatar
    Dec 24 2009
    Wichita, KS, USA
    It's the dead hookers in your trunk.
    2007 Phantom RS4// 20% tint all around//Clear Bra (entire front end)//Smoked Side Markers//Smoked & Clearcoated tails// Windshield 50% tint//Pioneer Amp and 12'' sub//Pioneer AVIC Z-150BH Head Unit//LED interior//LED City & DRL//HID fogs//10mm MTM spacers//JHM Lightweight Rotors (front & rear)//JHM Short Shifter//GruppeM intake//APR Tuned//Hotchkis front & rear swaybars
    Jul 05 2010
    completes me...
    Calgary, Alberta
    Quote Originally Posted by dtrizzo View Post
    Got rid of them months ago... Although, one of 'em had a weave...
