Page 2 of 2 FirstFirst 12
Results 41 to 70 of 70
  1. #41
    Veteran Member Four Rings 400HPA4's Avatar
    Jul 04 2004
    2002 Audi A4, 2002 GTI 337
    OC
    Looks pretty good, the file runs a tad rich at redline cyls 3-4 are missing from the idle stabilization, It looks like you MAF readings are a bit low for the size of the turbo (perhaps they are using an upgraded MAF?)
    Here is a graph of the A/F
  2. #42
    Active Member Two Rings Renga's Avatar
    Sep 07 2005
    Stockholm, Sweden
    I see now that there are some numbers missing!
    Changed the picture now!
    Any other blocks I can log?
    2006 S4 4.2 MT6, Ferrita catback, Turbocenter Stage 1 ECU, Porshe BBK, Sportec 19"
  3. #43
    Jul 04 2004
    OC
    Even though you can log 3 blocks at a time, it is not a good idea to do so unless you need all three of those blocks together for diagnostic purposes. I feel that block 031 (lambda) should be logged by itself, it will sample at a much higher rate and give you much more accurate data.
  4. #44
    Active Member Two Rings dfaudi's Avatar
    Sep 19 2005
    michigan
    Someone please help!!
    Ive been going into lag mode ever since my Giac FXK04 tune (2 months). I realized a fmic was needed with the tune. However im still running a stock intercooler (Michigan cold weather).
    I have to keep an obd scanner with me all the time to reset the codes. Im always getting system too rich. Getting frustrated. I finally finished finals adn have a little time.
    I finally got to datalogging.....
    While not in lag mode:
    Block 20: im reaching #'s upto 9.8!
    Block 115: Boost seems ok
    block 26: Knock is thru the roof ranging from 5-26 V !
    The thng that stumps me is that if i drive agressive it stays in tune mode, but as soon as i drive conservative, after about a minute, it'll fall into lag mode boosting max of 9-11 psi.
    In lag mode:
    Block 20: timing is good all 0's and some sporatic 1's and 2's
    Block 115: Req boos is much above actual since actual is staying at the 9-11psi
    Block 26: knock is still low at low rpm and works it way up to low 20's at high rpm!
    I have an EGT gauge and it reads 7-800 F avg and 12-14 highway.
    Could it be the intercooler affecting the timing (block 20)? Thus causing all the other shit...boost restrictions?
    A Boost leak?
    A check valve or something?
    Still dont know what the hell the N75 does...could it be the problem?
    Any experienced dataloggers please help.
  5. #45
    Jul 21 2004
    Florida
    In lag mode:
    A Boost leak?
    The GIAC FX program evidences uniquely high timing correction thatt signifies knock is detected and continuing to be corrected for. I would have this problem fixed before the weather gets warmer. You can pretty much disregard the knock voltage reading when scanning with an enthusiast tool like vag-com. Those readings are secondary regardless as the correction factors for timing rely upon them solely and act accordingly. Your tuner may try and convince you that high timing correction is fine as long as your knock voltages are below 30. This is incorrect according to the folks who designed the entire engine management system so be sure to present that data to them as they were not aware of it in the past...
    Here is a link to help you out...
    http://www.audizine.com/forum/showth...threadid=78686
    Ross-Tech may also be able to help you as they specify to monitor correction factors and NOT knock voltage in order to assess if the car is knocking.
    See about bringing the timing into check and how that helps. cheers! Mike
  6. #46
    Veteran Member Three Rings A4Jared's Avatar
    Jul 05 2004
    2004 A4 1.8T 6spd; Cayenne S
    Bethesda, Md
    Its gotta be a bigger MAF. With the Samco TIP k&n filter and Dahlback k04-15 set up, on 93 octane I would see much lower CF, zero across the board as a matter of fact and between 200-210 g/s MAF reading. So either this is MUCH tamer s/w, he's got a bigger MAF and something ain't right.
    Renga, maybe you should be running more boost? Also can you go into more detail about your setup? And what octane do you use? Have you had the chance to dyno your car?
  7. #47
    Sep 19 2005
    michigan
    Mike thanks for hte response.
    So are you saying its a software issue?
    could a small boost leak be causing the high timing issue? Or a bad knock sensor?
    As well, how much does a FMIC help with the timing. Could the lack of the FMIC with the fxk04 tune be the problem??
  8. #48
    Jul 21 2004
    Florida
    You could definitely try out a FMIC, IF that is required by the software. It may help a bit. I would troubleshoot some other things first though. Your knock sensors are likely fine. They are doing their job and the car is retarding timing to protect itself. That's a good thing. It's always possible you have a boost leak. You can log 115 to check actual versus requested boost. Does your car always go into limp mode or do you sometimes run with full power? Regardless, check for a leak by doing the logs and if there is one and you fix it, ontinue logging channel 31, 34, and 20 after to see if all is well. If channel 20 continues to retard in the region of 8-12 degrees as others are seeing, than consult the software manufacturer to fix the timing issue. cheers! Mike
  9. #49
    Sep 19 2005
    michigan
    Ill reset the codes to giveme full power, and if i drive aggressive its fine, but as soon as i start driving conservative, it falls into lag mode minutes after. Sometimes it holds up a bit longer than other times....i datalogged the boost...ill post after i graph it.
  10. #50
    Sep 19 2005
    michigan
    I did some logging. Im still falling into lag mode. Then ill drive a bit and itll go back into tuned mode. Getting frustrating!
    Can you guys take a look?
    http://dfcustoms.net/Datalog.htm
    I will do some more of 20, 31 and 34.
  11. #51
    Jul 21 2004
    Florida
    Looking at that log, the car is overtimed. I'd be willing to bet that due to that advanced timing if you log channel 11 you will see single digit BTDC everywhere due to the computer self adjusting down for the problem. You have ruled out a boost leak. ?id=2265766
    The GIAC B7 A4 programs are no longer running the overaggressive timing. On the B7, their timing looks like this...
    I would see if they can back down the timing for you about 6 degrees. Show them a log of your channel 11 BTDC before and after the fix for the overtiming and you will see more timing is actually being used after removing the excessive timing. I just received a logs from a fella with the same issue and they showed exactly that happening. Should be an easy fix for you. Good luck and let us know how it goes.
    cheers! Mike
  12. #52
    Sep 19 2005
    michigan
    Did this guy also fall into limp/lag mode frequently??
    Thanks for the input. I did more logs today, i jsut need to graph it.
  13. #53
    Sep 19 2005
    michigan
    Can you check the link again for the second set of logs (block 5). http://dfcustoms.net/Datalog.htm
    I found it kinda wierd that my throttle showed part throttle at full load/boost.
    Funy thing is a month ago i was on the highway and all of the sudden my traction/TPS lights went on. My car was running like shit. I get home, disconnect the throttle harness, do a throttle alignment, tested the positioners with a multimeter and reconnected. Atfter that everything was fine,no more lights. Also, last week, i washed my engine bay, and on my way home the same thing happened. Everything fine again.
    Could it be that my TPS is on its way, or is it just the tune thats closing the throttle from overboost?
    what d'you think?
  14. #54
    Sep 19 2005
    michigan
    Was on my way out of town today. Luckily my throttle positioner crapped out on me and left me stranded. Its pretty sweet when you are on hte highway and your gas pedal doesnt do anything.
    ________________________
    Current: GT3076R Powered '02 Audi A4 1.8QMT - B5 2.8L Trans
    Coming Soon - AEB High Rev Head - W/M - Built 2.1L Motor
  15. #55
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2004 A4 1.8t
    Vancouver Canada
    Hey Mike do you know if any of the FXK03 software has been corrected for aggressive timing since release ? I am probably running one of the earliest FXK03's out there and have never looked into software revisions despite some obvious timing issues in hotter months.
    My FX is so old in fact that I am able to Lemmi tweak it which I believe is no longer possible in the newer versions.
    2004 A4 1.8t
    283 hp 305 lb/ft
    BetaAlphaTau member #33
  16. #56
    Jul 21 2004
    Florida
    I'd just give them a call to find out, but last I spoke with them, they're keeping it the same. If that's the case, it's probably great you have the older file so you can just tweak it. You may want to PM the user "Itchy Foot". He had some really good results reducing his timing. The car is now running consistently more BTDC since he did it. I'd see if he can point you in the right direction.
    cheers! Mike
  17. #57
    Veteran Member Four Rings IKE20VA4's Avatar
    Apr 08 2005
    2005.5 A4 2.0T Quattro
    Portland, OR
    bump cause i needed this info
    2005.5 A4 2.0T Quattro Manual Sport
  18. #58
    Jul 21 2004
    Florida
    Edit: MAF readings looked good.
  19. #59
    Apr 08 2005
    Portland, OR
    oh i meant about the MAF readings
  20. #60
    New Member Two Rings
    Feb 06 2006
    on the move
    bump
    VW R32 MKV
  21. #61
    Stage 2 Banner Advertiser Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Bump for some great info.
    iPhone 4/4S Vapor aluminum case sale! $40 shipped! -> click here for details
  22. #62
    Veteran Member Four Rings junkie1.8TQ's Avatar
    Dec 03 2005
    2004 A4 1.8TQ
    Charlotte, NC
    Re: Vag-Com Data Logging FAQ...(first revision)....
    man was thinking about getting a vag-com soon... being a noob i have no idea what you guys are talking about. i guess i should start learning...
  23. #63
    Jul 21 2004
    Florida
    Thanks for the bumps.
    Here is a more complete version with how to use the vag com in it from first use as well...
    http://www.mjbmotorsport.com/datafaq.html
    cheers! Mike
  24. #64
    Dec 03 2005
    2004 A4 1.8TQ
    Charlotte, NC
    definitely need a beginners Vag-Com Sticky...
  25. #65
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    good thread does anyone know the grams per sec to horsepower ratio ?
  26. #66
    Jul 04 2004
    OC
    There is no ratio. To many variables to just correlate incoming air mass.
  27. #67
    Active Member Two Rings BigChris's Avatar
    May 20 2007
    2003 Audi A4 1.8T 5spd
    Bergen County NJ
    this is great! i just picked up my vag com last week and have been looking for a nice thread like this!
    "It is what it is..."
    BetaAlphaTau member #29
  28. #68
    Senior Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    Edmonton, AB
    Vote for sticky.
    1990 Coupe quattro /// Project
    Euro :: RS2 :: 034 :: ARP :: K&N :: Stebro :: Koni :: Brembo :: Dunlop
    Buy my B6 A4 parts: for sale thread here
  29. #69
    New Member One Ring
    Jun 20 2008
    Vancouver, BC
    Hi there,
    I just purchased a 2004 A4 3.0Q and I wanted to purchase the necessary stuff to start playing with the programming.
    So what is the best way to go to allow me to make all the changes/programming possible?
    Thank you in advance for your help.
    James
  30. #70
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    Good listing of all the different blocks within the engine controller and what they mean:
    http://www.ross-tech.com/vag-com/m_blocks/
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
