An update:
I bought the aforementioned "kit" (three plastic clips) and took my seat out yesterday. It's a 2003 S6 with "Comfort" seats.
http://www.europaparts.com/seat-guid...35881203a.html
After a good 45 minutes of exploring the underside of my incredibly heavy and tech-laden seat, I was unable to determine how this kit would help me.
I looked and looked and saw neither a broken clip that needed to be replaced or a spot from which said clip had disappeared completely and a new one could take its place.
I have pictures at home on my camera b/c I was hoping to write up a DIY. Will post them up and if someone can show where I was a dummy, I'd be hugely appreciative.
These clips look exactly like the ones I used on my '85 Scirocco and my '88 GTI, though. Nothing like these could be found under my seat, though.
____________________________
Also, I followed the procedure in the Bentley for removing the seat. Some additional comments:
...the electrical connections are tricky to separate b/c the clip mechanism has a tab on the bottom and the top (up against the seat bottom...a picture will help explain...and you only need to disconnect the fat wire on the seat side (five connections lined up together), not the single, thin wire (the fore/aft adjustment) which comes out with the motor and seat together.
...once I removed the two front bolts which are supposed to disconnect the seat from the car, I needed to shoulder bump the seat to dislodge it from the front bracket...it wasn't a s simple as "move the seat back and out of the track".
...I did not have the airbag adapter but following the Bentley procedure (moving the seat into position and then disconnecting the battery) allowed me to do this with no codes...not even the radio (though I have to reset seats, clock, one-touch down windows, etc.)
________________________________
