Page 1 of 8 123 ... LastLast
Results 1 to 40 of 297
    Active Member Two Rings ipop07's Avatar
    Jun 09 2009
    Cambridge, ON
    B5 widest wheels pic request
    I am trying to find some pics of a b5 platform with some 18x9" and 18x11" wheels more specifically but something close would do it too.
    I am trying to see how they would look depending on the offset and how the fenders were dealt with and such...
    I have 3 piece wheels
    18x9 et 45 (2.5" lip with 7.5" barrel)
    18x11 et 25 (4.5" lip with 7.5" barrel)
    and I'll be mounting
    235/40/18 on front
    265/35/18 on rear
    98' A4 1.8T: Unitronic custom tune, T3 turbo, Tein SS coilovers, highflow exhaust manifold, 440cc injectors, FMIC, Forge DV, Remus exhaust, ECS adjustable fpr, RS4 bumper and sideskirts, BBS Motorsport 3pc 18" E28 wheels, S4 interior - being built
    Active Member Two Rings ryandoka10's Avatar
    May 11 2009
    00 stage 3 s4
    MY GARAGE
    I dont believe that you can get anything wider than a 9.5 in the rear on the narrow body cars. I have seen a few people with rs4 widebody setups running 10 inch all around. The problem you run into is the upper knuckle in the rear. ive run 18x9 rears et 35 with rolled fenders and they fit flush.
    Senior Member Four Rings ThatA4T's Avatar
    Jun 10 2009
    98 A4 1.8T Quattro, 66 vw bug Rat Rod
    Denver CO
    i believe ive seen 10 inch wheels on a narrow body b5 with a good amount of poke
    Double DIN swap, pioneer avh4000, TONS of suede, 15% tint, Forge 007, apr/vdo, rs4 grille, GIAC chip, Depo ecodes with 55w 5000k HID's, ST Coilovers, 034 street density motor and trans mounts, 034 snub w/ bracket, 034 aluminum subframe bushings, valeo single mass cluth/flywheel setup, new control arms and axles, evo ms CAI, powderoated snazzy stuff, euro trunk, multi colors, Shaved exhaust cuttout with hidden turn down tips (in progress... again)
    its only just begun...
    Senior Member Four Rings NeedingAnAudi's Avatar
    Mar 16 2009
    99.5 A4 1.8TQM 00 A6 Widebody
    Lombard, IL
    Quote Originally Posted by ryandoka10 View Post
    I'm sorry, but you are definitely wrong. Wes rocks 10s in the rear with 225s
    Brilliant Black B5 ..... 15k on Street Built Engine
    Strictly Pleasure/Zero Clearance/Stretch Your Legs
    Alex
    Will work on Audi/VW in Chicagoland
    Jun 09 2009
    Cambridge, ON
    There are lots of guys running the keskin kt1 wheels which are 18x8.5 in front with et30 and 18x10 with et25 on the back.
    Here's an example:
    http://www.audizine.com/forum/showth...T1-s?styleid=8
    my 18x12 that I have clear the upper knuckle no problem, it just that it sticks out a little too much. I have pulled my fenders about 30mm and I will be running stretched tires on that. But I am afraid it wont be enough...as of now the wheel still sticks out about 1.75"
    Fronts are perfect since they are 18x10 with a pulled fender and stretch..
    Jun 09 2009
    Cambridge, ON
    Quote Originally Posted by NeedingAnAudi View Post
    http://i849.photobucket.com/albums/a.../DSC_28301.jpg
    That looks good. Do you know the offset of those wheels? Is he running a spacer at all? Are they 18s? (they look like 18 just need confirmation)
    May 11 2009
    00 stage 3 s4
    MY GARAGE
    Its kool man. I wasnt sure, just trying to give some help. Thanks for correcting me. Thats what this website is for. Thanks for not jumping down my throat.
    Jun 09 2009
    Cambridge, ON
    Oh and I was just thinking, what is Wes running for tires front and back? I will be running 235/40/18 and 265/35/18 in order to keep the overall rolling circumference of fronts and backs the same. (to not damage the diff)
    Mar 16 2009
    Lombard, IL
    I definitely wasn't trying to jump down your throat. But I know this game is all about low and wide, and every year it gets lower and wider.
    Oh and his specs
    Quote Originally Posted by wesleyfbm View Post
    18x8 et20 205/40 30mm adapter
    18x10 et27 225/40 38mm adapter
    Alex
    Senior Member Four Rings wesleyfbm's Avatar
    Aug 25 2008
    the 01 a4 tttt and my BMXer
    rhode island
    Thanks buddy!
    No issues here. But with the camber I do rub shock mount on hard bumps.
    Jun 09 2009
    Cambridge, ON
    Thanks buddy!
    how much camber are you at?
    I just realized ( i dunno how I didnt think of this before), since my wheels are 3pc, the width is as follows (correct me if I am wrong)
    fronts are made of a 2.5" lip with a 7.5" barrel so the true width is 9" not 10"
    and rears are a 4.5" lip with a 7.5" barrel so true width is 11" not 12"
    Aug 25 2008
    rhode island
    I dont know how much camber. Whatever it is my car decided to do at that height.
    Keep in mind. Lower you go the more camber you will have.
    ^ and for your widths....why are you subtracting 1"??
    And have you taken into account the width of the face between lip and barrel?
    Jun 09 2009
    Cambridge, ON
    I was on low already and had under 1deg of camber. I dont think i'll go much lower since the car sees occasional track and i need it to be functional.
    The reason I am subtracting 1" is because it depends on how you measure. I did a little research and proper way to measure is from inside of beads like so:
    I get 12" if i add the width of lip and barrel or measure from outside of bead to outside of bead, but I get 11" if I measure like the photo shows.
    Jun 09 2009
    Cambridge, ON
    Quote Originally Posted by jasonsowers View Post
    That looks like shit.
    I don't want to be rude but no one asked for opinions on whether you like it or not...or anyone for that matter. The point of this thread is not to get people's opinion on how it looks.
    You have something that looks better with a wide tire? You're welcome to share.
    PS: if it was sarcasm, i take what i said back...
    Jun 09 2009
    Cambridge, ON
    Heres where I am right now:
    front:
    rear:
    Nov 14 2006
    '02 911 C4S, '00 Passat Variant
    Renton, WA
    Oh look, another helpful comment from the god of Audi style himself.
    -Darrick
    No more Audis, but can't leave this place alone.
    Mar 16 2009
    Lombard, IL
    Quote Originally Posted by ipop07 View Post
    rear:
    lol I think your definitely pushing it with this.
    Alex
    Jun 09 2009
    Cambridge, ON
    I know, now I am considering either doing metal work or adding some wide flares or getting a narrower lip for the rears..
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    pull the rear fenders and stretch the tires. you'll be fine.
    ~Aaron
    His
    2001.5 S4 - GIAC . H&R . Bilstein . RUFF . AWE . SSAC . Devil's Own . FMIC . ABT...
    2001 S8 - ST
    Hers
    2000 S4 - ST . Avus . SSAC
    2000 A6 Avant - ST . H&R . Sevas . Hotchkis . OEM
    couple of audis
    quattro kings
    Jun 09 2009
    Cambridge, ON
    Quote Originally Posted by Klum00 View Post
    thats the plan for now. I am gonna buy 225/40/18 and 255/35/18....anyone coming to canada soon to bring me some tire? haha
    Senior Member Two Rings silverman's Avatar
    Sep 27 2008
    '98 A4 1.8tqm. Bilstein pss9.
    Hartford, CT.
    Good luck with this! It can be done!
    Cactus green B5 A4!
    Jun 09 2009
    Cambridge, ON
    found tires locally, picking them up within a week, adapters are here and ill be mounting and test fitting by mid next week.
    Active Member Four Rings coolgraymemo's Avatar
    Jun 10 2010
    Northern California
    How low are you?
    I really wanna see if you can pull this off.
    - Memo
    SSR Comp. STaSIS S/S. GIAC. Forge. Valeo E-Codes.
    Aug 25 2008
    rhode island
    almost positive these are 11"
    and the pulled fenders are dope.
    Aug 25 2008
    rhode island
    and just so we know what homeboy is working with...sweet cc mod bro
    and another look at my setup
    Aug 25 2008
    rhode island
    That sounds about right. Thanks for the info!
    Senior Member Four Rings dumpedb5's Avatar
    Nov 22 2009
    One Fast Twinkie /1969 Stingray/1988 notchback mustang (sold)
    City Of Roses
    STOP TROLLING DOUCHE!
    Travis-
    2001.5 6mt Imola B5 S4 Avant - GIAC - FMIC - Vast stg3 clutch - Piggie pipes - Muffler delete - Tein SS coilovers - 15 mill spacers in back - nuespeed Front & Rear sway bars - E-codes - Tint - 18x9.5 privat kup's.
    Air ride build coming soon!
    Nov 22 2009
    City Of Roses
    You will make it man. Your stance is about to look HOT!
    Travis-
    Jun 09 2009
    Cambridge, ON
    Thanks man...tires are on order, and should be here by maybe friday :) I will post pics as soon as I got stuff together...going to do other things that need to be done before the engine is ready to go back in :)
    Jun 09 2009
    Cambridge, ON
    Those look like 19" in the first picture..and second picture looks like 18x10
    Aug 25 2008
    rhode island
    I have no idea the wheel specs for the 2nd pic but the first is 19x11 i believe.
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    ipop, in your picture is your suspension compressed? They won't poke that much with load on them as you will increase camber as you compress the suspension in the rear.
    Jun 09 2009
    Cambridge, ON
    Quote Originally Posted by .Mad Hatter. View Post
    No, its in the air, I know they will go in more..just not sure how much..we'll see soon..I had 10mm spacers on when I tested the wheels, but I will have 15mm adapters when I actually put them on so another 5mm on top...theres too many variables to be able to get a proper image of what is gonna happen, thats why I want to wait for wheels with tires and adapters to be all put on and car dropped on the ground..
    Apr 27 2010
    seattle/WA
    http://www.audizine.com/forum/showth...rning...-KT1-s
    18x8.5" front ET30 215/40/18 falken 512
    18x10" rear ET25 225/40/18 falken 512
    i just replaced my vmaxx's with some S4 ST's on saturday and its sitting way lower now(aggressive offsets/wide wheels and vmaxx's DO NOT MIX. shit bottomed out like crazy and slammed the rear lip into my passenger fender). ill get some more shots of the rear when i get a few extra minutes.
    2001.5 A4 TQM
    Unitronic Stage 2/APR exhaust/2.5" test pipe/Intake
    JHM Shifter/solid linkage/AWE DTS/034 Weighted Delrin knob/Apikol Rear diff mount
    ST's/Keskin KT1 18x10ET25 18x8.5 ET30 and some stretch
    2.1L 9.5:1 Stroker/Built AEB head/PAG 5857 kit... under construction.
    Jun 09 2009
    Cambridge, ON
    Quote Originally Posted by LightSwitch View Post
    http://farm6.static.flickr.com/5207/...e4c45ab3_b.jpg
    you sir were an inspiration for me..i have that thread bookmarked :)
    I was shopping for the kt1's because of you and couldnt find them anywhere and as I was searching I stumbled across these wheels and couldnt pass up the deal...
    However if you have thoughts of selling them I have a friend with an S4 that will buy them from you in no time.
    my wheel sticks out about 1.75" with a pulled fender. How much does that stick out past the fender for you?
    Mar 16 2009
    Lombard, IL
    Illinois plates! Why have I never seen this thing
    Alex
    Veteran Member Three Rings G-low's Avatar
    Feb 13 2004
    Ct
    not sure if it was said but those will come in a bit on the top once you compress the suspension. throw a decent stretch on them things youll be fine
    97 1.8tqm T3T4
    Apr 27 2010
    seattle/WA
    thanks man! i'll be keeping them through the summer at a minimum, but if i decide to part with them ill let you know for sure. Ill snap some pictures/take some measurements for you today/tommorow. It looks WAY better now that i've dropped it down another 1/2".
    2001.5 A4 TQM
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    01.5 Pearl Stage 3 s4 AVANT
    down town long beach
    laser s4 avant > silver a4 sedan
    Both are awesome looking cars though... i would love to have your interior.
    Jun 09 2009
    Cambridge, ON
    this is turning into more of a build thread lol...
    im buying porsche brakes now lol cuz i bought 312mm rotors without realizing they were bigger lol
