Been a while since last update so I thought I'd give a short briefing what has happened since last fall. A lot has happened but not much progress :)
When I got the car running and drove it back to home two days later I started to have charging issues. The battery couldn't keep the current. While I was looking into that I accidentally left the car on neutral and forgot it when I left home. It slided down to my other car and the front bumper took a small hit on the passenger side corner. I decided to take the car to a dealer to ask about new altenator but during first acceleration the instrument cluster had a late christmas and all warning lights lighted up and the voltage gauge jumped up to 16V... Got the car towed to a friends "garage" for an altenator change.
After that I took the car to a friend paint shop to fix the front bumper but the outcome was that the car was over painted with OEM achat gray with matte finish.
Old 17" Ultraleggeras has been sold and new wheels are coming for this summer..
Now it was finally time to take the car on the road to take logs. After the first two pulls my 3rd hear started to make loud while.. I've had 3rd and 5th gear making noise for a few years and last winter when we had -25C degrees my 2nd gear made horrible noise under mild acceleration so it was time to buy a new gearbox..
Found 44tml old gearbox from -04 A6 and it was changed. So far don't have noises from it...
The Aquamist HFS-3 was a real PITA from day one. It didn't help that bentley manual had wrong wiring diagram. ELSA had the corrent one but the system still wasn't working as it should. I had help from BlakMarketKlash (<- thanks) with the wiring and everything seem to be OK but the gauge didn't light up when the ingition was turned on.
Big thaks to Dave@EPL for helping me with this and he confirmed what I suspected. Euro cars have different wiring compared to US S4s. Dave told me that US -03 2,7tt cars the coil didn't get 12V until the car was running and thats why I my gauge didn't light up before it was running. Next issue was the system was spraying at all until I adjusted the threshold to 9 o'clock. This made the system activate but it was hitting failsafe. Now the threshold is adjusted to 11 o'clock and the system is working as it should.
Tuning is still in very early stage. Basically I'm running base map with 10% WGDC but its running guite strong already. Here's logs from last pull. The car is running 25
.5psi (to be exact
). AFR's is still on the rich side ~11,5-11.
