Results 1 to 26 of 26
    Active Member Three Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    DIY: Audi B7 RS4 Spark Plug Change
    While there is already a DIY for the sparkplug change on our cars, I figured that a more detailed one couldn't hurt. This made a big difference
    Time: 30minutes-1hour
    Cost: ~$120 for the spark plugs
    Tools:
    • 3/8" Ratchet
    • 3/8" Torque Wrench
    • 6" Long 3/8" Extension
    • 5/8" Spark Plug Socket
    • 1/4" Ratchet
    • 2" Long 1/4" Extension
    • T-20 1/4" Drive Bit
    • Medium Philips Screwdriver
    • Medium Flat Screwdriver
    First, you will need the spark plugs. I had my friend order these from Worldpac for cheaper than at the dealer and I got them 2 hours later.
    1. Let the engine cool with the hood open for an hour or so. If it feels warm on the top of the motor anywhere, the sparkplugs will still be blistering hot. (Learned this the hard way)...
    2. Remove the air intake duct. Remove the two Philips screws in the front of the engine bay. Pull up on the rear part of the duct and then pull the whole assembly towards the back of the engine bay. Remove it and set it aside for later.
    3. Remove the top of the airbox. To do this you need to loosen the hose clamp on the tube going to the engine. Disconnect the MAF connector by pushing down on the clip and then pulling to disconnect. Lift up the rubber tube that is snapped into the cover, and then finally remove the tube that connects to the front of the airbox by squeezing the connector together and pulling out. Remove the airbox cover from the car and set it aside. Now is a perfect time to either replace your air filter element or clean it if you have a K&N one.
    4. Remove the two small T-20 Torx screws holding the harness to the valve cover.
    5. Push down on the clips on each coilpack until the pop and then disconnect them. Once they are all loose, you can move the harness out of the way of the coilpacks. If you have trouble disconnecting them, you can push the connector towards the coilpack and then squeeze the tap to release it while pulling away. It can be tricky to get them off, just use patience and you will eventually get them all undone.
    6. Remove the 4 coilpacks by pulling up on them evenly. Careful, they are fragile.
    Now for the driver's side
    7. Lift on the plastic engine cover starting at the front corner and then working back. There are 3 clip locations. Remove from the car and set aside. Remove the dipstick and set it aside.
    8. Remove the Philips screw holding the coolant tank. Lift up the front of the tank and disconnect it from the back by pulling forward. Be careful not to stress any of the hoses.
    9. Remove the two small T-20 Torx screws holding the harness to the valve cover.
    10. Using the same method as before, disconnect all of the coil packs. Once they are disconnected, pull them directly out and set them aside. The one under the coolant tank is a little tricky. You can carefully pull the coolant tank a little to provide room.
    11: Go around to each plug with the Socket, Extension, and ratchet (you could use a breaker bar for this as well). Break each one free then unscrew it using the socket and extension only. Once each plug is removed, set it aside and then move to the next one. Careful, they are very hot.
    12. Take each new plug and check the threads to make sure nothing is damaged. Stick it in the new plug into the extension and socket and thread each one in BY HAND. Do not use a ratchet for this. If you feel any resistance, stop and try again. They should go in a couple turns before stopping. Leave them finger tight. Do all 8.
    13. Set the torque wrench to 22lb/ft. Go around to each plug and torque it to 22lb/ft. It will turn about one full turn before becoming tight, this is normal. Make sure to do all 8.
    14. Insert the coilpacks back in each hole and press them down until they are fully seated. Do this for all 8. Plug in the harness to each one and squeeze the plugs until they are fully seated.
    15. Reinstall the 2 T-20 Torx on each side. You only want them slightly snug. Don't strip them out.
    16. Reinstall the coolant tank by cliping in the back two clips then fastening the Philips screw.
    17. Reinstall the plastic driver's side engine cover by clipping in the 3 clips. Replace the oil dipstick.
    18. Reinstall the air filter and airbox. Can be tricky, take your time and it will go in just fine. Make sure to plug in the MAF sensor and replace the hoses in their clips.
    19. Reinstall the air intake guide and refasten the two Philips screws.
    20. Clean up everything and start the car. If it was anything like mine, it will idle much smoother.
    2008 Audi RS4 Ibis White w/ Titanium Package | JHM LWFW & Stage 4 Clutch | JHM Solid Shifter + Shifter Linkage| Pilot Sport PS2 265/35/19 | EBWerks Full 2.75" Exhaust | Apikol Rear Diff Mount | 034 Billet Subframe Bushings | 034 Track Transmission Mount | EBWerks Cold Air Intake | Stern Motor Mounts | Stern Upper Control Arms | Hotchkis Sway Bars | EBWerks Rear Endlinks | EBWerks LW Battery Kit | Euro Bumper/Headlights | 50% Tint All Around
    355WHP 298WTQ on stock tune/91Oct
    Senior Member Four Rings RS4POWER's Avatar
    Jul 19 2008
    2007 RS4
    EC
    Well done!
    The way a diy should be drafted.
    Active Member Two Rings Trogdor1464's Avatar
    Apr 20 2011
    Vegas
    Nice write up. My plugs came in today as well. Got the same ones. Plan on changing them tomorrow along with apikol snub and smoked reflectors. Correct me if Im wrong but these plugs come gapped already correct?
    Nov 03 2010
    Cupertino, CA
    Yes, from what I was told they do not need to have the gap set.
    Stage 3 Forum Advertiser Three Rings
    Jun 04 2008
    the fastest audis
    California
    Another great DIY for B7-RS4 owners. For all of you who don't have friends at parts warehouses, we keep these plugs on the shelf for you: B7 RS4 spark plugs.
    In addition to these, we have a growing catalog of parts for the 4.2 FSI motor. Everything from spark plugs to oil change kits to injectors. If you don't see it on our site, we can probably get it! Send us an email (sales@jhmotorsports.com) or give us a call with your parts list!
    - Keaton
    Apr 20 2011
    Vegas
    Quote Originally Posted by BenSti View Post
    Cool thats what I thought.....thanks!
    Nov 27 2007
    San Jose
    Nice write up.. how many miles did you have on the plugs before the change?
    Nov 03 2010
    Cupertino, CA
    49000 miles on the old plugs.
    Active Member Two Rings Mr Hyde's Avatar
    Oct 20 2009
    Long Island
    Nice writeup. Thanx
    Just call me...........Mr Hyde
    2007 Mugello Blue Pearl RS4
    // RS6 Flatbottom Steering Wheel // Dension Gateway // V1 w/ LI-S4 Concealed Display // Stoptech Brake Pads // Powdercoated Rims // MTM 10mm Spacers // Ventureshield // Full LED Interior & City Lights // PIAA DRL's // Hoen Fogs
    Senior Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    /07' RS4/06' MDX/05'600RR/06'400EX/
    Long Island
    Quote Originally Posted by Trogdor1464 View Post
    Nice right up. My plugs came in today as well. Got the same ones. Plan on changing them tomorrow along with apikol snub and smoked reflectors. Correct me if Im wrong but these plugs come gapped already correct?
    No snub for the RS4's.
    2007 RS4 : K&N drop in : Hawk HPS up front Stop Tech in the back : DTH CF Engine Cover : 30% Tint : Magnaflow X : Tubi Rumore : JHM L/W FR & RR : Audi Sport Rubber Floor Mats : H-Sport Sways F/R : Stern Links : JHM Intake Spacers : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : 034 Trans Mount : HOEN H11 Fogs : LED City/DRL & Interior : ECS Clear Side Markers : MTM 10MM : Front Plate Delete :
    Active Member Two Rings Krys-RS4's Avatar
    Mar 09 2011
    Chicago
    You guys think I can do it? :)
    Nov 03 2010
    Cupertino, CA
    Just make sure to put the air filter back in the right place and you should be fine. The hardest part is actually removing the airbox to get to the plugs. Just take your time and make sure everything goes in easy. If you have any trouble, don't force it. This is one of those things where you can really mess stuff up if you cross thread the plugs (but that is difficult to do)
    Apr 20 2011
    Vegas
    Quote Originally Posted by NY07RS4 View Post
    FOCK!!! I didn't even realize that. It said B7 chassis on JHM's webiste so I just assumed it had one. Didn't even bother looking at the car. Now I gotta send it back and I guess get the tranny mount. Meh, oh well. I wonder why Audi left the snub off this motor.
    Nov 03 2010
    Cupertino, CA
    I had been wondering the same thing. Do the 034 Street Density mount and a Apikol Rear Diff mount and you should be good! I am going to do a DIY on the diff mount because I need to go put loctite on the bolts.
    Apr 20 2011
    Vegas
    Yeah those are next on my to-do list now that the snub has to go back. I'll keep an eye out for your DIY. I'll pick up some loctite too, lol.
    Senior Member Two Rings maxbhp's Avatar
    Aug 11 2007
    OC, CA
    Ben, you've been an awesome asset in the short time you've been here with us. Keep up the great work.
    08 RS4-Phtm Blk/Ebny, Prem, Tit, CF Trim, Tint, JHM Tune, JHM/Hypershift Hybrid SS, Clearbra, Audisport Trunk Liner/Floormats, V1 w/ LI-S4 Stealth Display, Stasis MS, Apikol Rear Diff, 285/30s, Rotiform VCE 19x10, Euro Wheel Air Leather and Suede, Suede Boot/Knob, Painted Side Mirrors, European OEM RS4 Headlights, Smoked Markers, OSIR Matte Carbon B-Pillars, OEM rear camera, PTT Can-gate, MTM exhaust, Yellow fogs, H-Sport rear sway bar, Euro OEM Seats, Alcon 6 370mm
    Veteran Member Three Rings i_eat_staples's Avatar
    Aug 03 2004
    Wilsonville, OR
    awesome, love the step-by-step and pics u include in it, makes it a lot easier and less intimidating for peeps like me who arent, shall we say, mechanically inclined
    '07 rs4
    '91 spec miata
    NW Quattro - NW Premier Audi Club
    Senior Member Two Rings dtrizzo's Avatar
    Dec 24 2009
    Wichita, KS, USA
    Thank you for all the hard work! This is a great write-up.
    2007 Phantom RS4// 20% tint all around//Clear Bra (entire front end)//Smoked Side Markers//LED interior//LED City & DRL//HID fogs//10mm MTM spacers//JHM Lightweight Rotors (front & rear)//JHM Short Shifter//GruppeM//Hotchkis front & rear swaybars
    Nov 03 2010
    Cupertino, CA
    Thanks guys, let me know what you want to see. I am planning on doing a writeup for everything I do on the car. I am planing on doing the JHM short shifter and swaybars soon.
    Senior Member Two Rings PolishPete's Avatar
    May 12 2008
    IL
    Thanks for the DIY.
    2008 A4 2.0T Quattro Special Edition / 35% Suntek Tints / APR Software / (Lease Ended)
    2007 RS4 / 35% Tints / APR Tune / More To Come
    Aug 03 2004
    Wilsonville, OR
    thatd be great, i think it would be an outstanding asset to the rs4 community considering how small we are. There seems to be a bit of a gap between DIYer's and guys like me who really benefit from walkthroughs, as there seems to be a general lack of them for the b7rs4
    my vote would go towards rotors/pads, coilovers, clear corners (theres one out there but i lost the link), exhaust
    '07 rs4
    '91 spec miata
    Nov 03 2010
    Cupertino, CA
    Well, I have a set of Porsche Carbon Ceramics for sale, if they sell I will be doing Ohlins Motorsport coilovers, swaybars, endlinks, motor mounts, and some other stuff. I can do a DIY on the exhaust next weekend or sometime when I have a chance. I haven't gotten the stock exhaust yet so it would be the install only.
    Active Member Four Rings rs4 tony's Avatar
    Sep 13 2010
    2010 S5, 2009 Viper SRT 10, 2010 Ecalade
    Long Island, NY
    thats exactly what i did...jhm wouldnt give me a full refund so i sold it to a s4 owner for the same price 4 months later..... its only 30 bucks... better 30 then 150 lol
    2007 Audi Rs4 Daytona Pearl/Carbon Fiber Trim/Navigation/20% Tint All Around/PIAA Yellow Fogs/K&n Drop In/Apikol Rear Diff. Mount/034 Street Transmission Mount/Front Plate Delete/Michelin Super Sports 275-30-19/MTM 10mm Spacers/JHM Intake Manifold Spacers/JHM LWFW & Stage 4 Clutch/StopTech Street Performance Pads Front & Rear/JHM L/W Front Rotors
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by Krys-RS4 View Post
    yea you can do it.
    Aug 14 2009
    Long Island
    Quote Originally Posted by i_eat_staples View Post
    I have done a DIY for the rotor/pads on that 'other' site. I'll try and post it over here too.
    Forum Moderator Four Rings SoCalS4Avant's Avatar
    Jan 24 2008
    B8 A4 Avant, Touareg V8, E30 318
    Pasadena, California
    Great work, Ben. This and your other DIY's have been copied over to the B6/B7 S4/RS4 DIY/Tech forum.
    Dan - Moderator/Wiseguy
    EuroBerge
