Results 1 to 12 of 12
    Active Member Three Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    DIY: Audi B7 RS4 Rear Differential Oil Change
    Couldn't find a DIY for how to do this so I decided to make my own. Hopefully this helps everyone. Let me know if you need anything clarified.
    Audi says it is lifetime fluid, common sense says it isn't. I figure change it every 50k miles and you can't go wrong. Expecially because it uses such little oil. I chose to go with Amsoil Severe Gear 75W-90 because I had good results with it in my Subaru. You could use whatever oil you choose, it needs to be GL-5 rated.
    Time: 15 minutes
    Cost: $15-$30 depending on the oil you use.
    Tools:
    • 3/8" Ratchet
    • 3/8" Torque Wrench
    • 10mm 3/8" drive socket
    • Oil Pump
    First off, get the back of the car up in the air. It would be best to get the car perfectly level to get every bit out, but I don't think it really matters. The drain plugs is up in the front of the diff so it should get nearly everything out. I like to use ramps because I am lazy.
    1. Using the breaker bar and 10mm socket, break the fill plug loose first. It's on the passenger side in front of the axel. It shouldn't be that tight, but make sure the socket is all the way in the plug.
    2. Once the fill plug is broken loose, crack the drain plug and drain the oil into a small container. My car drained out 0.8L of fluid.
    3. Attach the pump to the bottle of oil and stick the fill hole. Make sure to put back in the drain plug before pumping. Fill with the same amount you drained out.
    4. Reinstall the fill plug. Torque the drain plug to 26lb/ft and the fill plug to 13lb/ft.
    5. Lower the car, clean up, and you are done!
    2008 Audi RS4 Ibis White w/ Titanium Package | JHM LWFW & Stage 4 Clutch | JHM Solid Shifter + Shifter Linkage| Pilot Sport PS2 265/35/19 | EBWerks Full 2.75" Exhaust | Apikol Rear Diff Mount | 034 Billet Subframe Bushings | 034 Track Transmission Mount | EBWerks Cold Air Intake | Stern Motor Mounts | Stern Upper Control Arms | Hotchkis Sway Bars | EBWerks Rear Endlinks | EBWerks LW Battery Kit | Euro Bumper/Headlights | 50% Tint All Around
    355WHP 298WTQ on stock tune/91Oct
    Active Member Two Rings V8PWR's Avatar
    Apr 13 2011
    Tools
    Thornton CO
    Nice work!
    2004 Audi S4 Brilliant Red
    Bone Stock
    Soon......
    Feb 15 2007
    2007 RS4, 2005 X5 4.8is
    Fort Collins, Co
    so, .8 litres?
    2007 Audi RS4 - Daytona Grey
    2005 BMW 4.8is - Le Mans Blue
    Senior Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    /07' RS4/06' MDX/05'600RR/06'400EX/
    Long Island
    Technically .9L or 1QT but close enough.
    Ben - good job man, you are on a roll with the DIY threads
    2007 RS4 : K&N drop in : Hawk HPS up front Stop Tech in the back : DTH CF Engine Cover : 30% Tint : Magnaflow X : Tubi Rumore : JHM L/W FR & RR : Audi Sport Rubber Floor Mats : H-Sport Sways F/R : Stern Links : JHM Intake Spacers : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : 034 Trans Mount : HOEN H11 Fogs : LED City/DRL & Interior : ECS Clear Side Markers : MTM 10MM : Front Plate Delete :
    Nov 03 2010
    Cupertino, CA
    Yeah, I think it was probably a little more if you had the car perfectly level. Either way, all you need is one quart to change it.
    Senior Member Four Rings dparm's Avatar
    Apr 24 2009
    2005 S4 sedan
    Chicago, IL
    S4 rear diff is 1.5qt to fill, though we all know you won't get it all out. Buy two bottles and you'll have some for next time. :-)
    Also, be careful with the type of container you drain it into: long-term storage in certain types of plastic containers will end poorly.
    2005 S4 saloon 6MT
    Nov 03 2010
    Cupertino, CA
    Good point with the container. My drain pan was a bulk container of windex which I cut in half. I dumped the oil back into an empty oil bottle to get a measurement. I store my oil in a 25 gallon gas container until it is full at which point I take it up to Jiffy Lube.
    Aug 14 2009
    Long Island
    Quote Originally Posted by dparm View Post
    Weird, the fluid chart I have from Audi states 1.0QT for both the S4 & RS4. Although, I agree, always buy two to cover yourself.
    Forum Moderator Four Rings SoCalS4Avant's Avatar
    Jan 24 2008
    B8 A4 Avant, Touareg V8, E30 318
    Pasadena, California
    Great work, Ben. This and your other DIY's have been copied over to the B6/B7 S4/RS4 DIY/Tech forum.
    Dan - Moderator/Wiseguy
    EuroBerge
    Active Member Two Rings S4SHOES's Avatar
    Jan 21 2011
    Calgary
    i followed this for my s4 and everything was very similar except:
    the fill plug was behind the axle on the passenger side and the i had to remove the axle shield to get to it
    axle shield is 3 socket head bolts that use a 6mm
    thanks for the write up!
    Active Member Two Rings coasterjob's Avatar
    Apr 24 2009
    2004 Silver S4 MT , 1997 MK3 Jetta
    Lawrenceville GA
    Is it a good practice to this while changing the MT fluid? Looking to change MT and Diff this spring.
    (Just read Dparm's MTF write up)
    Show: Scratched and rashed up Avus wheels, fuzzy dice
    Go: "No Fear, drive it like you stole it" bumper sticker, expensive sticky tires
    Apr 24 2009
    2005 S4 sedan
    Chicago, IL
    The rear diff does not get nearly as much stress as the MTF/center/front diff housing does. You can change it much less frequently.
    2005 S4 saloon 6MT
