View Poll Results: Should he keep or sell the B5 1.8T
Voters
6. You may not vote on this poll
  • Sell it!!! Motor is shot!
    0 0%
  • Pics and sell it here so someone can use it as a parts car!
    0 0%
  • Keep it sounds like a easy fix!
    2 33.33%
  • Need to be VAG report to answer
    4 66.67%
Results 1 to 6 of 6
    Veteran Member Four Rings jriddle11's Avatar
    Mar 26 2007
    B7 3.2Q and B6 1.8Q USP
    Byers Audi - OH
    Need assistance with the 1.8T motor
    I have a friend who owns a repair shop and he just picked up a b5 1.8T (non-quattro) and he is trying to decide if he wants to keep it or just sell it. The reason he is thinking he may sell it is because after about 10 minutes of driving the check engine light, oil light, and the oil pressure alarm came on. The motor doesn't have any knocks, should I VAG it and see what error codes come up to help him decide if its worth keeping or not? Anyone have any ideas if it could be an easy fix or if its something major and he should just sell it?
    Current: B7 OEM + and B6 USP OEM +
    Previous: B5 and B6, All OEM +
    Veteran Member Four Rings dcampana's Avatar
    Nov 01 2006
    04 Allroad, 01a41.8Q, 90 CQ
    Nor Cal
    Well if I were m I would pull off valve cover off in check for sludge probably is the issue. If its sludge I would do auto rx on it and see if that helps.
    Vag is a given to get codes first
    my ride: 2001 A4qtm... 2871r, 440cc, 3 bar, turbo xs dv, custom 3" exhaust, test pipe, Cm fx400 billet LWFW...
    90 CQ.. 2bennett... work in progress
    2004 AR... bone stock
    Timing belts, clutches, and all done in the North Bay. Pm me.
    Apr 22 2009
    new zealand
    you dont have anything to lose by vaging it, and it only takes 5 min.
    Active Member Two Rings B5RiceEater's Avatar
    Nov 09 2010
    brooklyn
    if he owns a repair shop then he can fix it for free just buy the parts duhh
    Senior Member Three Rings BlackLock_A4's Avatar
    Sep 14 2009
    San Jose
    Seems a little extreme to sell it without even running a VAG on it.
    2001 1.8TQM
    Speed doesn't kill. It's that damn sudden stop.
    Site Moderator Four Rings onemoremile's Avatar
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    A repair shop owner should never sell a car because he is scared of potential problems. He should at least investigate them and provide an estimate for repair to the potential buyer. Better yet, fix it and sell it as serviced. For a mechanic to push problems onto a customer.... just so wrong.
    Jim - Moderator
    I Do Werk.
