Page 6 of 6 FirstFirst ... 456
Results 201 to 222 of 222
  1. #201
    Active Member Two Rings udcc11's Avatar
    Oct 17 2011
    Gladstone, IL
    Did you end up selling this car? If not whats going on with it.
    2000 Nogaro S4 Six-Speed Stage II+ soon to be stage 3 Frankenturboed
    Totaled 2002 Santorin S4 Six-Speed Stage II+
  2. #202
    Senior Member Three Rings UkuRiSh's Avatar
    Jan 09 2010
    Audi S4 2011 S-TRONICK WHITE YAMY !
    New York
    Quote Originally Posted by udcc11 View Post
    My SPEC Stage 3+ clutch is tosted so i just installed new one , other fuel pump 044 in line and 85mm maf housing with hitachi sensor and fix some litlle things . When i take the manifold out i finded some cracks on it , i welded and add high temp flex pipe and i make it stronger turbo brackets , very soon goin to run 29 psi my base file and dyned we will see diferent , after dyno J-Fonz Will Tune my car . Looking to get over 600whp we will see . So this kinde Story man i just goot my new cutch little over 600 mil on it i need put 200 mil more on my clutch and then i can tryed high boost.
    p.s
    Car Is Still For Sale
    BUILD EDGE-MOTORS THREAD ****> http://www.audizine.com/forum/showth...Y-EDGE-MOTORS-!
    Tuned By J-Fonz And EURODYNE
    www.edge-motors.com
  3. #203
    Jan 09 2010
    New York
    New Tune by J-Fonz 25 psi no meth car fells good , some video when we test the last file guess what 911 turbo :)
    Second Run But Posche give up .
    www.edge-motors.com
  4. #204
    Active Member Two Rings nothingbutwin's Avatar
    Jun 23 2011
    2001 Audi S4
    Green Bay wi
    did you have this dynod after the new tune?
    '01 s4 KW-catback-CAI-rims-tint-piggies
    its getting there...
    www.lindgrensupercars.com <--Check it
  5. #205
    Senior Member Four Rings DESPOT D S4's Avatar
    May 09 2010
    stage 2 b5 s4silver,stage 3+ b5 s4 santorin tial 605.
    in a audi
    Quote Originally Posted by UkuRiSh View Post
    very nice,how much?
    Tial 650's, CM850 Twin, ER SMIC'S AWE Twin, KW V3, TDI TRANS with RS4 3'rd gear, 034 Adjustable everything, Hotchknis Sway Bars, 034 track engine and trans mounts, Apikol rear diff carrier, JHM trio < dont do it its going out asap, only keeping the ss, 18x9.5 et 25 bbs lm's , sexy clean santorin <3
  6. #206
    Jan 09 2010
    New York
    Quote Originally Posted by nothingbutwin View Post
    Yes i did dyno J-Fonz spools 200 rpm later then EuroDyno and make more power on top
    www.edge-motors.com
  7. #207
    Jan 09 2010
    New York
    Quote Originally Posted by DESPOT D S4 View Post
    very nice,how much?
    around 20k after i finish some work on my car .
    www.edge-motors.com
  8. #208
    Jan 25 2006
    Audi S4 2.7T, A4 2.0T
    MD
    Later or earlier?
  9. #209
    Jan 09 2010
    New York
    Quote Originally Posted by Don Supreme View Post
    Later or earlier?
    Yes 200-300 rpm Later but top end power is better on J-Fonz, we stop tune the car at 24 psi it's made 450whp i think on mustang dyno just 93oct no meth , next time we will tune on dyno 29-30 psi i hope to see some better numbers .
  10. #210
    Senior Member Four Rings Evilevo's Avatar
    May 26 2008
    2001.5 S4 2.8L, 2012 Golf TDI w/Tech
    Potomac, MD
    Can you post the dyno sheet? I would love to see what your powerband looks like.
  11. #211
    Sep 14 2009
    s.e. mass
    Quote Originally Posted by Evilevo View Post
    also interested... any explanation in the spool differences?
  12. #212
    Jan 09 2010
    New York
    I will post some time two different ECU dyno sheet .
    Quote Originally Posted by naudlee View Post
    probably tune .
    www.edge-motors.com
  13. #213
    Sep 14 2009
    s.e. mass
    im just curious what in the tune caused the lag...
    prior tune was on stand-alone correct? or am I thinking of the wrong single turbo'd car
  14. #214
    Jan 09 2010
    New York
    No, I have two stock S4 ECU with different Tune Euridyne and J-Fonz i never run stand-alone
    www.edge-motors.com
  15. #215
    Active Member Three Rings Monty23's Avatar
    Oct 27 2011
    S4, R6, Raptor 660, 2011 Jeep Wrangler Unlimited, 2000 Dodge Dakota 4.7
    Near Philly, Pa
    Did you ever get tuned at 29-30psi? Are you still happy with your tune from jfonz?
    UUC, Piggies, H/R, iForged, JFonz stage 2, Podi
  16. #216
    Jan 09 2010
    New York
    I can't say anything , because my car is a part for some modification so I will post result some time , I almost done .
    www.edge-motors.com
  17. #217
    Oct 27 2011
    Near Philly, Pa
    Sounds good, I'm excited for updates here.... Has your car ever had any overheating issues during summertime heat while sitting in traffic with the 2 - 7 inch ebay fans? Are you still running the stock mechanical fan on your accessory belt?
  18. #218
    Jan 09 2010
    New York
    I have no Problem with over heat I'm use stock fan and two little fan for AC radiator
    I'm planning to buy hood with wents it will help cooled down engine bay little .
    www.edge-motors.com
  19. #219
    Jan 09 2010
    New York
    Some pictures i did today .
    My log manifold cracks betwen tee conection and i decide use 034@Max style thanks for sharing Max and parts . Also i almost finish my manifold ,
    www.edge-motors.com
  20. #220
    Oct 27 2011
    Near Philly, Pa
    That mani is beautiful!!! Thanks again for the fan info - I am definitely going that direction... I would love to see how your old welded log manifold spooled vs. the 2.8 cast manifolds... When will your car be running?
  21. #221
    Jan 09 2010
    New York
    Thanks man , hopefully by end of the week and big thanks to Edge Motors .
    www.edge-motors.com
  22. #222
    Senior Member Three Rings SpeedWorksAuto's Avatar
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Very nice!
    I have been considering using the 2.8 exhaust manifolds too. My manifolds have cracked a couple of times.
