Page 1 of 6 123 ... LastLast
Results 1 to 40 of 222
    Senior Member Three Rings UkuRiSh's Avatar
    Jan 09 2010
    Audi S4 2011 S-TRONICK WHITE YAMY !
    New York
    Audi s4 single turbo by edge motors !
    hello everyone . I'm glad to say my S4 UP and running .
    BUILD BY www.Edge-Motors.com
    TUNE BY www.jfonztuning.com and EURODYNE
    BIG THANKS TO : Sergei From Edge Motors , Alex , Stive , Sergei (Motvey) , :) e.t.c
    STOCK 2.7 BLOCK
    STOCK PISTONS
    IE ROD'S
    Raceware Main Stud
    TURBO PRECISION PTE 6265 T4 ceramic ball bearings billet wheels
    CUSTOM TURBO MANIFOLD LOG STYLE
    PRECISION PTE 46mm Wastegate
    2.8 HEAD , STOCK 2.7 VALVE'S WHIT Supertech Valve Spring/Titanium Retainer
    NEW OEM Timing Chain Tensioner Left and Right
    BOSCH EV14 72 lb Injectors
    Custom 85 mm maff and Hitachi Sensor <===== Just add
    FUEL LINE -6 AN
    Prosport EVO Wideband Digital Air Fuel Ratio kit Guadge
    Prosport EVO Boost Guadge <===== Just add
    Prosport EVO Fuel pressure Guadge
    044 BOSCH Pump in tank AND <===== Just add other pump in line
    034 fuel rail
    Aeromotive fuel pressure regulator
    CUSTOM ENGINE OIL COOLER -10 AN
    CUSTOM DOWN PIPE 3"
    CUSTOM CAT BACK 3"
    CUSTOM Precision Front mount intercooler for 850 hp
    Greddy RZ blow of valve
    Evilown W/M Controller up to 30 psi , Pump , 750 cc/m , hook up to OEM windshield fluid container
    SPEC STAGE 3+ CLUTCH " Need upgrade the clutch to stronger one " <======== Upgraded Spec pressure plate to 55% more pressure and 6 Pack clutch good for over 800 lb-ft
    JHM SHIFTER
    ALL NEW FRONT AND REAR CONTROL ARM'S AND BUSHINGS
    034 ENGINE MOUNT
    034 Diff Carrier Mount
    034 Snub Mount with Bracket
    ASP Transmission Stabilizer Bar
    ASP Transmission Mounts
    ASP Rear Differential Mount
    FK Coilover
    HOTCHKIS FRONT & REAR SWAY BAR
    RS4 FRONT ROTORS AND 8 PISTON CALIPERS
    19X8.5 WMR 709
    BF Goodrich g-Force T/A KDW Tires
    ALPINE SOUND SYSTEM AND TWO 10 " KENWOOD SUBS .
    Timing belt And Much More ,,, -AN custom line's oil , antifreeze , stirling
    REBUILT TRANNY WITH JHM KIT "
    29 PSI RUN
    DYNO 19-23 Psi
    DYNO 27-29 PSI With Meth 50/50 mix
    BUILD EDGE-MOTORS THREAD ****> http://www.audizine.com/forum/showth...Y-EDGE-MOTORS-!
    Tuned By J-Fonz And EURODYNE
    www.edge-motors.com
    Veteran Member Three Rings cjk's Avatar
    Jul 15 2004
    2000 S4
    Seattle, Wa
    Nice work man! look forward to what kind of power it makes when fully tuned.
    VAST PNW Reseller
    REALTOR specializing in residential real estate throughout the greater PNW!
    Jan 09 2010
    New York
    Quote Originally Posted by cjk View Post
    Thanks man . I Need weld the intercooler piping and install oil coller , sterling coller . But car is running man and i'm so happy :) two more weeks and i'm goin for tune .
    www.edge-motors.com
    Active Member Three Rings bondar1989's Avatar
    Oct 16 2010
    03 B6 A4 TQM
    Long Island, NY
    absolutely amazing
    Active Member Three Rings nJoy's Avatar
    Dec 18 2010
    01.5 B5 S4
    Illinois (South Suburbs)
    Beautiful!
    Veteran Member Three Rings Spooled1.8's Avatar
    Jan 26 2006
    York, PA
    Great job, loving all of the upcoming single builds!
    -Pete
    2001 Imola Yellow S4 EPL/TiAL S605
    -Evolution Racewerks Intercoolers with Carbon fiber shrouds.-EBC Redstuff Pads-EBC Rotors-RAI Motorsport 3" Downpipes-AWE Twin 1 Exhaust-AWE DV1 DV's-AWE Center Vent Boost Guage-AWE DTS Bar-Advanced Automotion Rebuilt Trans-Southbend Stage 4 Clutch-Fidanza LWFW-ASP Engine Mounts-034 Motorsport Trans Mounts-Apikol Rear Diff Mount-KW Variant 3 Coilovers-
    Active Member Two Rings NKI 337's Avatar
    Apr 24 2007
    Miami, Florida
    WOOOWW!!! AMAZING!!!!!
    So jealous!!
    ***** www.dubbersinc.com *****
    Senior Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Black 2001 Audi S4 6MT
    Toronto, ON, Canada
    Jaw-dropping! Love it!
    Brilliant Black 2001 S4 - 6MT <3
    3" Gutted Vibrant Catback | X34 Intake | Stern Soft Engine Mounts | JHM SS | 710N's | 17" RS6 Wheels | AWE Boost Gauge
    Senior Member Three Rings MLJS4's Avatar
    Jan 06 2010
    Stg2 Nogaro, Stg3 Imola, Mk2 gtis X3, volvo s70 turbo
    Michigan
    nice job man more videos after tune! whos tuning it?
    2001.5 Stage 2 Nogaro
    2001 Vast Stage 3 Imola
    May 05 2011
    Reinland pfalz, Germany
    I LOVE how fat those log manifolds are...I am excited about all the headway with single builds! Looking forward to more! Thanks for sharing.
    We relish news of our heroes, forgetting that we are extraordinary too...
    Jan 09 2008
    88'90quattro 98'passat quattro
    haverstraw ny
    Quote Originally Posted by MadProfessor View Post
    most likely Kevin Black will be tuning it....
    Senior Member Four Rings McGovs2.7TB5's Avatar
    May 28 2008
    sweet build, can't wait to see some numbers.
    01.5 Brilliant Black S4 avant - JFonz 2+ / Piggies+SSAC / X34 intake / ST coils / Podi Stepper / A8 flat fives
    yeah it's a tip
    Registered Member Four Rings NYCVR6's Avatar
    Queens, NYC
    Quote Originally Posted by 390wheel View Post
    Very good choice.. I've known Kevin for years, he tuned my car and will be tuning it again in June... Looks like a very nice build.
    Justin- 01.5' Pearl S4 24V VR6 6766'd axle eater
    C&M Performance
    034 Motorsport
    Lugtronic
    CTS Turbo
    INA Engineering
    Drive your car, not your dyno sheet
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    2003 2.0 PTE 5857 B6 A4 quattro 5spd, 05 E55 AMG
    Jacksonville, Florida
    Curious on your choice of the 6265 over just the 6262? Everything that I have heard says that it doesn't produce any more power worth having and you just deal with more lag from the bigger turbine wheel since its only benefit would be to sustain boost (power) at higher rpms which will not even be remotely close to the rpms your car will be running. This was reading from guys who run/own Evo performance shops who use mostly Precision turbos on their shop/customer cars.
    ~David~
    I can help you with your 1.8t work (timing belts, etc)
    2.0 Billet PTE 5857 A4
    Those who say it can't be done should get out of the way of those who are doing it.
    119mph traps w/ 437whp/392wtq dyno jet power on 93 octane and washer fluid injection
    527whp/576wtq White Pano E55 AMG 11.69@120mph on street tires
    Senior Member Three Rings Mr. Merk's Avatar
    Sep 20 2007
    08 A4 S-line Titanium
    NW Arkansas
    i spy harbor frieght screwdrivers, sweet build
    02 S4 2.7T Stage 2+ | VAST | Penske | Stasis | Hotchkis | Stoptech | Neuspeed | XSP | IPP | JHM | Stern | Avalon | ASP | VMR | Podi | 034 | AEM | SDR
    08 A4 2.0T S-Line Titanium Stage 1 | VAST | ST | Koni | VMR | Forge | 034 | BSH | Omori | AFE
    87 S-10 383ci | th-375 | Slicks & Skinnies
    05 Sierra 5.3L SLT Crew | Bone stock
    Stage 3 Forum Advertiser Four Rings Max@034's Avatar
    Jan 13 2009
    Fremont, CA
    Juiced to see a PT running on an S4!
    Seems like now everyone and their mom is doing a single turbo build!!!
    Jan 09 2010
    New York
    Some update ! still working on the car fixing small things .
    http://www.youtube.com/watch?v=jz-YE60srGE
    www.edge-motors.com
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    2008 Bmw 135i
    Westchester, NY
    awesome dude, the motor looks great all painted up
    AKA: Bigair
    Sold: 00 Audi S4
    New: 08 Bmw 135i White
    S4 //VAST
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    99 GTRS A4; 00 stgII S4
    Lansing, MI
    sexy shit!!!! congrats
    '98 built 1.9 B5 A4 SOLD
    '00 Audi S4 6spd stg II SOLD
    '99 1.8 GTRS powered B5 A4 SOLD
    Registered Member Three Rings
    Jan 15 2009
    2001.5 audi s4 stage 3
    pennsylvania
    nice
    Active Member Two Rings gablks4's Avatar
    May 20 2011
    Los Angeles CA
    that's amazing and insane. how much hp and tq you think you can get that beast to? i would like to see it run a quarter mile, reminds me of the single big turbo supras back in the dayz those hit 1000hp i believe.
    Jan 09 2010
    New York
    Quote Originally Posted by gablks4 View Post
    It's not tune yet ! I gonna run the car at Waterfest 17 first day 1/4 mile , second day dyno :)
    www.edge-motors.com
    Senior Member Four Rings NishadJoshi's Avatar
    Apr 22 2010
    Playa del Rey, Ca
    Word? Nice! Numbers!?
    derp.
    Jan 09 2010
    New York
    Thanks guys . Some new vid whit more power .
    New File from EuroDyne 23-25 Psi feel's good :)
    Video **-> 23-25 Psi Sorry it's little long video , skip to 3:05 if you dont whant wait :)
    www.edge-motors.com
    Senior Member Three Rings BoostinonYOU's Avatar
    Apr 03 2006
    02 s4, 08 Thundra, 08 gsxr 1000
    San Diego North County
    Such a tease, the first two minutes you kept shifting right when you were about to be in the boost :/
    APR Stage 1 13.0009 @ 105 FULL INTERIOR | 100 OCT RACE GAS
    APR Stage 2+ 12.87. @ 109.10 1.89 60FT. FULL INTERIOR FULL EXHAUST | 93/110 mix
    http://www.youtube.com/watch?v=pCPXI5hMOUI
    I have a faster 1/4 time but no slip, didn't bring my helmet and promptly got kicked off the track w/o time slip :(
    APR | JHM | OZ RACING |
    Apr 03 2006
    Sounds wonderful though :D
    Senior Member Four Rings jamestown478's Avatar
    Dec 24 2008
    2000 S4 stage 2+ on meth
    Milwaukee
    I want ur steering wheel lol
    __________________
    2000 S4 built block and some tials :) My baby
    2002 tt 225hp also a meth addict, Fiances baby
    woodhouse94 - "well go fuck yourself im done talking to you because i asked for help and all you wanna do is fuck my family"
    marty was here- "why am i always the designated dick?"
    Veteran Member Three Rings michael66899's Avatar
    Oct 26 2006
    00 S4, 01.5 S4
    WA
    Mmm jealous, can't wait to get mine up and running. Hows the lag so far, also how is it in transient throttle? How would you compare it to say a standard K04 car? Can't wait to see more videos and results, best of luck with the tune!
    - 00 Nogaro S4 - Single Turbo Project / 01.5 - Silver S4 - Stg. 3 / Five other B5s that have all been sold
    -Girodisc-BW EFR-Fikse-AMD-Stoptech-Stasis-034-JHM-Stern-Neuspeed-Dahlback-Eurogear-CPP-Group 2-
    WWU Formula SAE - 600cc's and 450lbs = Lots of fun
    Active Member Four Rings S4 00 2.7's Avatar
    May 13 2011
    Nice build and clean work.
    APR | SSAC | UUC SS | JHM Delrin
    2003 Z06 (Sold)
    Wicked
    Jan 09 2010
    New York
    Quote Originally Posted by michael66899 View Post
    Nice!! what turbo are you will run ? 15 psi hit by 4300k and by 4700-4800 full boost , the car won't move 0-3500 rpm :) so yes it's a lagg if compare k04's but power is insane after 4700k it's feels like a jet take off :)
    www.edge-motors.com
    Dec 11 2006
    QuattroWorld
    Nice work man!
    For sale:
    Silver Trunk (Great condition)
    Pass. side timing belt cover (2.8 Brand New)
    AC Lines and Condesor
    Stock Fuel Rail with FPR
    034 Lower Compression Headgaskets
    Misc. oil and coolant lines
    Misc. brackets
    Misc. AN Fittings and braided lines.
    Jan 09 2010
    New York
    Quote Originally Posted by Das General View Post
    Nice work man!
    Thanks man , how is your car ?
    www.edge-motors.com
    Active Member Two Rings highspeeds4's Avatar
    Oct 26 2010
    MRAP
    Gardendale, AL
    1st off, your car is sick
    I would love to see this car vs. Tial 770s or Gt28rs
    This thing sounds mean as hell. Great job...........now start marketing this kit also ;-)
    2001 BB S4 6spd.......all stock 140k
    2003 Mazdaspeed Protege.......some mods but being sold
    2007 Chevy Tahoe 4wd........keeps wife and kids safe
    Dec 11 2006
    QuattroWorld
    Quote Originally Posted by UkuRiSh View Post
    It drives. It has small oil leak that needs to be fixed... and the tune needs to be tweaked to get it to run smoothly. As of now it stalls in first with the clutch in. My guess is it has to do with the lack of air being metered without a MAF.
    For sale:
    Misc. brackets
    Jan 09 2010
    New York
    I Just gave a call to EPL guy's to put my car on dyno they are located very close to me , they told me : " we use dyno only for tune " and they can't tune maesro 7 Soft :( , i'm looking for local dyno to finish my tune & Dyned .
    www.edge-motors.com
    Senior Member Four Rings Evilevo's Avatar
    May 26 2008
    2001.5 S4 2.8L, 2012 Golf TDI w/Tech
    Potomac, MD
    What? They tuned my car to 600whp on pump/meth on the stock ME7 ECU.
    Jan 09 2010
    New York
    Quote Originally Posted by Evilevo View Post
    Maybe the problem is because i got already tune , i almost done just need final tune :(
    www.edge-motors.com
    May 26 2008
    Potomac, MD
    I mean, they can tune you. But you are going to have to pay full price for the tune. They will use their own base file and tune from there. Most likely need their big MAF kit too
    Jan 09 2010
    New York
    I was asking just to put my car on dyno ! whatever i'm just looking for nearest dyno shop .
    www.edge-motors.com
    May 26 2008
    Potomac, MD
    There is a Dynojet that we used one time. I don't remember the name.though.
