Four Rings
 Originally Posted by jibberjive
Does EPL go with their big MAF for K04 setups now, or do they use the Hitachi MAF element in a bigger housing?
I know Tony was talking about that because of how much better and more precise that MAF is, but I don't think he is doing it yet.
Senior Member
Three Rings
K04's are incapable of maxing out the drop-in Hitachi sensor housing, so it's highly unlikely anything but the standard EPL housing will be used on any build that's 500whp or less.
Four Rings
72lb injectors installed, new base file loaded and running.
Stock -> APR Stg1/2 -> GIAC Stg2 -> APR K04 Stg3 -> EPL/TiAL 605 -> V̶A̶S̶T̶ EPL/Frankenturbo F4H -> In Progress
Four Rings
I know, I was thinking maybe for ease of having a single universal sensor that they use on everything, but it makes sense that they wouldn't throw in an extra couple hundred bucks for a sensor that's not necessarily needed.
** GT2860R-7 S4 Build Log--
FOR SALE:
--JHM DELRIN SHIFTER STABILIZER BUSHING (LATE STYLE)**
--RS4 AIRBOX--
LOOKING FOR:
--Your Fuel Tank Lid and Fuel Pump Baskets--
Four Rings
Have the boost pretty well set, now turning to cleaning up the AFR.
Four Rings
Finally someone wants to see how much power these turbos can make! Can you post wg duty cycle
Four Rings
It's a fixed WGDC at ~72%.
Active Member
Two Rings
Sweet Jesus!!!
2000 S4 6spd Coilovers, APR exhaust, 18 x 8.5 VMR V710s, 7000K HIDs and Fogs, CC mod. More to come.
SOLD:2003 A4 Avant 1.8TQ 5spd
APR stage 2+, TT Injectors, 710n DV, 2.5" TP, 2.5" DP, port/polished intake mani, Powergasket+ phenolic spacer, single mass flywheel, valeo clutch, K&N drop in, iridium plugs, german castrol 0w30
Four Rings
Smoothing the boost curve a little more. Going to bring that top end boost down. Doug says 24 psi or 400 g/s at red-line, but not both, I think I'm past that point now.
Four Rings
Three Rings
Nice to see it getting all dialed in man.
Tial 605's EPL Tuned
Lots of other goodies.
Four Rings
It's coming along nicely. When are we going to take your car out for another session?
Four Rings
Do you have any F.A.T.S logs or anyspeed?
Four Rings
Jeff what kind of tool are you using to see boost that high? Zeitronix?
Looks good and damn that's a lot of boost! We have my buddy's set running a 24ish spike, then taper. That's of course because of a high IAT rise and no secondary cooling on the car like W/M.
I think anytime FATs or anyspeed are used as a measurement the acceleration chart should be with it..
Four Rings
Not sure what you're getting at.. But I was asking for the whole "shebang", if you will. Just to see what those boost levels are yielding.
Four Rings
I'm doing a lot of experimenting right now, just to see what boost level is worth trying for and what profile works well. I've got a bunch of FATS runs, but they're all a byproduct of trying to collect some useful info to tune with. The tune is still a work in progress so I'd rather not start putting out numbers that may not be representative of the final tune. When it is done I'll be happy to share the trends I've seen and numbers I recorded. At this point it would seem that making more boost than what I'm comfortable with is easily within reach. I swapped out my 2.25" dual exhaust for a single 3.5" and boost went back up over 27 psi with the same DC that was making a more comfortable 26 psi with the dual.
I'm using a Zeitronix to record boost pressure.
Four Rings
I am in for results, thanks for posting this up, it will make dialing in my FT tune easier
I don't think I care anymore
Four Rings
All I'm getting at is you were asking for FATs or anyspeed runs and I added that I personally like to see acceleration graphs anytime those two are mentioned as well, that's all.
I agree though, I mean with boost up there if I saw the correlating acceleration graphs I would be able to put 2+2 together on if these turbos are efficient at that level.
Four Rings
word, yeah I was just moving quickly on my phone when I posted. I wasn't trying to seem edgy if that's how it came across. I'm excited to see the correlating graphs and boost levels! get you shizzle dialed in flyboy!
Four Rings
I'm not gutsy enough to push my stock motor like this any more, but here's some data showing what's possible, for a short while at least.
Frankenturbo FATS @ 27_psi
Four Rings
Are you still running EV14 52# injectors?
Edit: I see you are running 72lbs, so hmmmmmmmm.. What kind of fuel pump?
Four Rings
RS4 pump
Four Rings
RS4 pump
Does Tony feel that the pump is about maxed out? It would seem like there is a fuel supply issue. I am not saying you need a new pump, just that your current fuel supply seems to be struggling to keep up... I am having a similar issue, but with smaller injectors.
Four Rings
The subject of the fuel pump has not come up.
Four Rings
I had an rs4 pump 60lb siemens 3bar running RS6s @ 30psi no problem.
Four Rings
Well as you can see from his logs, duty cycle is on the high side... especially for such a large injector.
Again, I am not criticizing anyone here.. Just analyzing and thinking out loud.
Four Rings
Great numbers! That's probably not too hard on your system., I mean mayybe mayyyybe hard on your turbos. But hey they're cheap right
Four Rings
Nice numbers, I just got my ECUx untangled, my initial logs are a ways off of yours
Four Rings
Of course. I was just saying the pump is able to do it.
Four Rings
This log is not from a completed tune.
I'm not seeing any signs of there being inadequate fuel. It starts going rich around 5500 rpm and keeps getting richer until I get off the gas at 7000. The IDC maxes around 67%, AFR at the tailpipe is in the high 10's, and airflow is a good bit over 400 g/s.
Any time I make more boost than I had with the 605's I start getting nervous.
Four Rings
My tune was doing the same thing. I switched to M1 and it holds 11.8ish now. I think yours is doing it because of your rising iats.
Boost is going to be different between the two turbos, 27psi is not near the same cfm as on the 605s.
Four Rings
What's an M1?
I'm not following what you're saying about the boost and airflow. If IAT's are the same, rpm is the same, and boost is the same, then the same amount of air should be going into the motor.
Four Rings
False alarm, I just looked at the graph again. I didn't notice that inj on time and duty cycle was on the same graph... Yup you are good on fuel.
Four Rings
What's an M1?
VP M1 Methanol.
27psi on FT != 27psi on 605s. You are barely breaking 400hp calculated, but 27psi on 605s is close to 500whp.
605s flow more CFM than FTs do and I don't think you need to worry about 27psi on the FTs. AMD ran 40+psi on the stock pistons before they had an issue.
Four Rings
At some point I think adding w/m injection would be nice to do. Just not in the plan for the time being.
For similar conditions, the FT's are moving more air (based on MAF values) or at worst equal to the 605's at every rpm that I can monitor, once they both max out the 85mm housing I can't be sure, but based upon the respective boost curves I'd expect the 605's to outlfow the FT's above 5500-6500 rpm. I'm fairly confident below that point the FT's are making more torque than the 605's. It's the low end and mid range torque that is concerning me, not the top end where I can see the FT's fall behind the 605's.
Three Rings
Hey Jeff not sure if I told you but Im going up to EPL next month on the 5th to drop my car off. Cant wait to get it all dialed in and get back so we can see how the cars do against each other.
Senior Member
Four Rings
DC doesn't really mean much... as it could be the injector calibration is skewed from whatever values Tony is using to define them.... But if you look @ the O2 graph, he is going rich(er) by redline which shows the fuel system is not maxed out.
Four Rings
Read my posts after that post.
Senior Member
Four Rings
Yuo, and I meant to quote Adam instead of you... lol... ah well.
Four Rings
Dude You won't make more torque than a heavy hitting k04 E85 car on pump gas. I made 496 ftlbs at 3860RPM to the wheels. My rods didn't even shrink and I put 20k on that car, beating the daylights out of it. I would not worry about FT's blowing out rods, if you ever start knocking, then worry, but how your tune looks.. You're fine. Methanol would be awesome on that setup! do it!
- You may not post replies
- You may not edit your posts
Forum Rules
