Results 1 to 38 of 38
    Established Member Two Rings Krys-RS4's Avatar
    Mar 09 2011
    Chicago
    Burning Smell After Driving - Please Advise
    Eversince it got warmer in Chicago occasionally I smell weird burning smell after driving and getting out of car. I can't locate the source of it,sometimes I think it's from the engine and other times like it's from the back of the car (exhaust)... So far it happened only few times in the past 2 weeks. Should I be concerned? What and where should I be looking for if I wanted to check what it is???
    Active Member Two Rings 08RS4's Avatar
    May 13 2011
    88 Mustang
    Texas
    What kind of driving are you doing? How long are you driving? Does it smell anything like hot brakes or like burnt oil or like boiling anti-freeze? Maybe something got on your exhaust or headers? Something got loose and the shielding/insulation/something is burning on any number of hot items?
    AKA: Slainte
    Mar 09 2011
    Chicago
    Normal driving,15-30min intervals. City driving.
    The smell reminds me "burning plastic"... To be honest I don't know how burning oil smells like :(
    I popped the hood today and I've noticed that one of the containers with liquid is slightly below MIN-I think it's the cooling liquid tank. Sorry I don't know the right terminology...
    Could that be the case? No controls on dashboard whatsoever...
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Chicago, IL
    If you want more help, I suggest you change your thread title to something better like "burning smell after driving".
    now: 2011.5 BMW M3 sedan ZCP
    past: 2005 Audi S4 sedan, 2011 Audi S4 sedan
    Apr 24 2009
    Chicago, IL
    Quote Originally Posted by Krys-RS4 View Post
    That is the coolant overflow tank. Top it off with some water until it's just below the max line.
    Veteran Member Four Rings rs4 tony's Avatar
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by dparm View Post
    that and fill it up in the morning when the car has been sitting for the whole night
    2007 Audi Rs4 Daytona Pearl/Carbon Fiber Trim/Navi/Lambo Verde Ithaca Pearl Painted Calipers/H&R Springs/JHM 93 Octane Tune/K&n Drop In/Apikol Red Rear Diff. Mount/StopTech S.S. Lines/Michelin Super Sports 275-30-19/H&R 8mm Front Spacers/MTM 10mm Rear Spacers/JHM Intake Manifold Spacers/SPEC Stage 3+ with LW Steel FW/JHMCatless Downpipes/JHM 2.75" Non-res Catback Exhaust/JHM Lightweight Front & Rear Rotors/034 Torque Mount/
    Instagram: @rs4_tony
    Mar 09 2011
    Chicago
    Good point. How do I do that?
    Mar 09 2011
    Chicago
    Thank you for the tips guys!
    I am just curious.Why water? Wouldn't it be better if it top it off with the coolant liquid?
    Veteran Member Four Rings Silver B6 S4's Avatar
    Dec 08 2008
    2003 PT Cruiser GT Stage 2
    Petaluma, California
    If you use water, use distilled water.
    Sep 13 2010
    Long Island, NY
    its a 50/50 mix ratio. but used distilled water. for that small amount, it wont make a difference
    Apr 24 2009
    Chicago, IL
    It's just easier to use water. You won't be adding enough to significantly impact the boiling or freezing points. If anything, too much pure coolant is bad.
    Veteran Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    RS4
    eh?^ turbo?
    RS4 : K&N : HPS & Stop Tech : DTH Cover : 30% Tint : Tubi Rumore (SOLD!) : Audi Sport Rubber Mats : H-Sport Sways F/R : Stern UCA's : JHM L/W FR & RR : JHM I/M Spacers : JHM LWCP : JHM FULL 2.75" : JHM 3R & LWFW : JHM Tune : JHM Cross Rod : JHM SS : 034 MAF & USM's : 034 Trans Mount : USP Slave & SS Line : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : HOEN H11 Fogs : LED : MTM 10MM : F Plate Delete : CC Mod
    Mar 09 2011
    Chicago
    Thank you!
    Mar 09 2011
    Chicago
    Do you think this (slightly low coolant) might be the cause of the burning smell?
    May 16 2011
    Los Angeles, Ca
    sounds good.. didnt bother reading up on your model so didnt realize...
    ps:who trolls on forums.. FAIL..
    Apr 24 2009
    Chicago, IL
    Doubtful. As it is that is just the overflow tank. The level will rise and fall as you drive the car anyways.
    Burning smell = something is literally burning or melting.
    Oct 12 2010
    Keswick, Virginia
    Get close and smell your brakes and tire area next time you get out...
    Established Member Two Rings JuniorAra's Avatar
    Apr 06 2010
    '07 RS4
    GTA
    During the warmer months I have noticed the same smell. It only happens when my S button is active and on cold start. I don't know why but I have shrugged it off and I plan on keeping an eye on it as soon as the weather gets warmer.
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by JuniorAra View Post
    I know why. as the weather is warmer, our motors responsiveness and power gets messed up the slightest bit and were used to the winter driving so when u hit sport mood we actually ride the clutch a little more then we used to. long story short, weather change affects everything in the car. coolant will expand more and maybe over flow
    Mar 11 2008
    RS4, 190e 16v, e46 M3
    While your smell could be lots of things without you pinpointing it's location... The coolant reservoir can develop cracks that only materialize under high-heat/pressure and go away once cooled down. If you're slightly loosing coolant, and your expansion tank is starting to look old, this could be your issue. But again, we need more details on exactly where its coming from...
    FRRG AZ Ring
    Apr 24 2009
    Chicago, IL
    Quote Originally Posted by zmon View Post
    Dragging brakes have a very unique odor. Same for rubbing tires.
    Mar 09 2011
    Chicago
    Interesting that you brought that up,I actually DO have a tiny crack on the tank that I've noticed last time I looked under the hood. It's just a white mark on the plastic that is noticable to the touch but DOES NOT LEAK... And I have located the soucre of the burning smell-it's coming from the left front wheel,does it mean its the brake?
    The smell only stays for few minutes and then goes away...
    Senior Member Three Rings 4rings-rs4's Avatar
    Feb 28 2008
    Long Island, NY
    I had a similar mysterious burning smell once and it turned out to be a plastic bag caught on my downpipe was literally carmalizing from the heat. By the time I realized what it was, I couldn't do much but wait for it to burn off - took about a month or so of having to live with that smell.
    ◊ 2007 Mugello Blue with Ebony interior, CF trim, Prem. Pkg
    Unitronic Stage 2 | JHM 2.75" Downpipe w/ HFC & Resonated Matte Black Exhaust | Hardwired V1 w/ LI-S4 Concealed Display | Black optic front grille | TTRS perforated leather flat-bottom MFSW w/ silver stitching | MY2010/11 RNS-E w/ black optic bezel & silver knobs | Euro Style LED Tail Lights - Smoked Red/Clear | E-codes w/ Ziza LED city lights, 6K LED DRL, Chrome OEM turn signal bulb | Apikol rear diff mount
    Oct 12 2010
    Keswick, Virginia
    i think it could just be warm brakes/tires...but thats just me ill let others comment... and its just the left? have you smelled the others up close?
    Mar 09 2011
    Chicago
    Yes,just one wheel (front left).
    Apr 24 2009
    Chicago, IL
    Get under the car and check for anything bent or rubbing.
    Mar 09 2011
    Chicago
    I've found some PRESTONE coolant in my storage from couple of years ago,is it still good? Can such thing expire/go bad? :)
    Mar 11 2008
    ^ Do NOT use that... only G12 from the dealer...
    FRRG AZ Ring
    Sep 13 2010
    Long Island, NY
    just use water. its only a little amount. and i know i ran over dog shit once somehow.... hahaha
    Mar 09 2011
    Chicago
    Ordered OEM coolant from ECS tuning, $13 ;)
    Sep 13 2010
    Long Island, NY
    niceeee. now remember, it's a 50/50 mix ratio. so if it needs a half cup of coolant, add a half cup of distilled water..... do it in the morning too when the car is dead cold.
    Mar 09 2011
    Chicago
    Quote Originally Posted by rs4 tony View Post
    Thanks Tony. I did not know that!
    So should I mix the coolant and water in a separate container before purring it into the coolant tank?
    Sep 13 2010
    Long Island, NY
    just do this, get 2 red plastic party cups, fill 1 cup of coolant half way and mark it with a market on the outside, then with the other cup fill it with distilled water to the same level(it doesn't have to be dead on perfect). after your 2 cups of fluid are the same volume, pour it into the coolant tank individually or put it in a Chinese soup container then pour it in.
    Mar 09 2011
    Chicago
    Question:
    Can the smell be from the tires? I just recently changed my tires to summer pilot sports (new-slightly used last summer)-that's the only thing I changed...
    I checked under the car,there is nothing loose,rubbing or stick to anything,it's clear. The coolant tank doesn't leak,it's little above MIN level-but this is being fix tomorrow when the G12 coolant arrives.
    I still get the smell after driving and now I am NOT sure if it's coming jut from one wheel-it's very hard to tell. I smell it the most when standing near the car and when there is a little wind...if I try to come close and smell the engine,wheels or exhaust then I really can't smell it that good...
    Apr 24 2009
    Chicago, IL
    No, the tires will only smell if you have been racing (literally on a race track).
    Just take it to the dealer.
    Sep 13 2010
    Long Island, NY
    smell like rubber? a electric wire burning? a strong smell? water solution smell?
    Mar 09 2011
    Chicago
    Quote Originally Posted by 4rings-rs4 View Post
    That's it! That is exactly what it was! A plastic bag that melted over the pipe :) I can't believe how I missed that when looking under the car... It still smells a little but definitely fading away..
    Just wanted to let you guys know in case someone else get similar smell-look for plastic bags cought under your DP's :)
    Dec 05 2006
    So. Cal.
    Items for Sale
    Like 2 fricken peas in a pod. I can't believe you guys are turning a low coolant issue into a monumental task. A Chinese soup container? ROFL. Maybe add, boil the coolant and water in a wok before adding it to the tank.
