Page 5 of 30 FirstFirst ... 3456715 ... LastLast
Results 161 to 200 of 1163
  1. #161
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    HUGE shoutout to judeisnotobscur, a B5 S4 guy, for GIVING me this power steering line to see if it fits, and it does!
    Anyways, got the line on, fits just like I thought but now the other one is giving me some trouble...
    The bolt in the back is 19mm, but you have to take the front bolt off first (for the PS cooler) to get to the back one and because the front one won't fit anymore.
    Here she is with the B5 S4 PS line. I also cleaned up the subframe although I scratched it a bit. You can also see my busted axle
    Farther back shot
    Here is the problem with the B5 S4 line vs. the B6 S4 PS line. The arrow shows where the end needs to fit up to the rack, but the circle shows the problem with the lines running into the same spots.
    And here is the old PS line from the S4. So much extra junk on the S4 I'm happy to clean things up
    - Clint
    New Ride: White '04 S4 2.7T - Already Stage 2
  2. #162
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Take the lines to a hydraulic shop and have them replace the rubber hose and swap the ends.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
  3. #163
    Senior Member Four Rings Dan[FN]6262's Avatar
    Sep 12 2008
    02 A4, 94 GMC, 06 450R
    South Central Pa, Dundalk MD
    Quote Originally Posted by dirtybrd View Post
    X2
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
  4. #164
    Senior Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    03 Audi A4
    Columbus, Ohio
    So are you saying for it to be a bit easier an A6 power steering line might be a better idea? I tried to call you the last two days, but we must miss each other. Are you going Soundbend again on the clutch or doing the FX400? I want a stock like pedal, but I want it to last and hold the power. I've got good deals on both I feel, but wanted to see if you can help find a better one I'm game.
    Hahaha...dood! If the movie director wanted the car in the next fast and furious, I'd definitely submit the car! :-P - BoostBeeyatch
  5. #165
    Sep 12 2008
    I can't wait until you guys figure this out and its essentially a drop in solution. then bye bye 1.8T
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
  6. #166
    Oct 29 2005
    Ft. Lauderdale, FL
    no need when the B5 lines are already done perfectly. I just need a B5 front line
    - Clint
  7. #167
    Oct 29 2005
    Ft. Lauderdale, FL
    Quote Originally Posted by IVRINGS View Post
    stock for now, no $$$. Went down the beach this week and Beer>Clutch
    - Clint
  8. #168
    Mar 27 2009
    03 Audi A4
    Columbus, Ohio
    Well live your life with my money, not like I have a lot but I do have clutch money since my 01E swap plans went away ;) What clutch would you get? Just remember from time to time my wife will be driving the car so I don't want it to be an on and off switch, but stock like feel that will still hold the power. I think the FX400 would be nice, but do you know the life span of a FX400 being a 6 puck be ok? I also kinda want to try the VAST clutch, but paying for my flywheel to be redone for the clutch doesn't seem very fair.
  9. #169
    Mar 27 2009
    03 Audi A4
    Columbus, Ohio
    So we just need both lines from a B5? You think anything from an A6 with a 2.7T would work also?
  10. #170
    Mar 27 2009
    03 Audi A4
    Columbus, Ohio
    Hey I just wanted to ask if you know if I order up a S4 Exhaust if it will bolt to the car in the right spots? I just don't know if there are extra hangers I need or buy or not since I've not looked under the car in a while.
  11. #171
    Senior Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    Quote Originally Posted by BCsniper View Post
    well I stand technically corrected. I was (and still am) under the impression that the pass. side aux rad was to cool the oil cooler and that this was it's only function unlike the drives side one which is used for other purposes. So it is used in the oil cooling process, but no not an actual oil cooler, that is the other part of the system taking out when using this JHM piece. However none of this is that import here and has nothing to do with the OP........so now on with more pictures Clint!
    It would have to be a separate system with its own reservoir and pump to be 'for oil cooling only'. VAG OEM prefers using the engine coolant to regulate the oil temp for many reasons, and most of them are pretty good. The transmission 'cooler' on 01E and auto equipped cars works in a similar fashion, too. The B6/B7 system of 3 radiators was done for space and efficiency reasons. The mk4 VW VR6 also uses an aux radiator.
    **This post was meant to be informative, not argumentative. Take it as intended**
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
  12. #172
    Jan 11 2007
    SLC,UT
    Cool project. Having owned a USP and a B5 S4 at the same time, I've had some thoughts about a swap. This will be sick
    Quote Originally Posted by williamr91 View Post
    Damn good catch, no more drunk posts :P but stage 2+ should put about 350 down (a strong stage 2+)
    Strong stage 2+'s don't put down 350whp (assuming you're talking whp, like you were in your previous post), more like 280-290whp.
    ** GT2860R-7 S4 Build Log--
    FOR SALE (click me):
    --FIKSE FM10 - 3pc LIGHTWEIGHT WHEELS - 17x9 et55 & 17X8 et57 - 5x130 - WORK ON AUDI W/ ADAPTER**
    --JHM DELRIN SHIFTER STABILIZER BUSHING (LATE STYLE)**
    --RS4 AIRBOX--
    LOOKING FOR:
    --BROKEN SPIDER HOSES
  13. #173
    Oct 29 2005
    Ft. Lauderdale, FL
    A6 lines might even be better, and yes the S4 exhaust will fit fine
    - Clint
  14. #174
    Mar 27 2009
    03 Audi A4
    Columbus, Ohio
    Hey what about clutch if you where having to get one? I know you are not getting one now, but why not give me your idea's, and if you know someone to give me a deal I can't pass up I would love to talk to them. Otherwise Hood or my local company will get my order today/tomorrow.
  15. #175
    Senior Member Four Rings Haenszel20v's Avatar
    Oct 05 2008
    08 Rabbit, 2000 A4 VR6T Avant, 2004 R32 Turbo
    Buffalo, NY
    FYI, most hydro shops won't do power steering pressure lines..... a liability issue.
  16. #176
    Oct 29 2005
    Ft. Lauderdale, FL
    CM FX400 sounds good for you and the wife
    - Clint
  17. #177
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    Quote Originally Posted by Haenszel20v View Post
    That's when you find a good 'ol boy and get him to modify the lines like he does with his construction equipment.
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
  18. #178
    Oct 29 2005
    Ft. Lauderdale, FL
    Looking sad in the garage on a rainy day.
    - Clint
  19. #179
    Mar 27 2009
    03 Audi A4
    Columbus, Ohio
    I made some great headway today ordering up the FX400 Clutch and I got two NEW EGT's for $106 Shipped! It took some calling around today to find them, but it paid off for sure.
  20. #180
    Oct 29 2005
    Ft. Lauderdale, FL
    good deal. If u need to call me I'm around all day
    - Clint
  21. #181
    Mar 27 2009
    03 Audi A4
    Columbus, Ohio
    I tried to call, but it was just to BS. If you get free give me a call. If I'm not with a customer I'll be able to talk for a bit. Later
  22. #182
    Oct 29 2005
    Ft. Lauderdale, FL
    Ok found out some more about power steering lines. The ONLY line you need is the one from the rack to the motor. The stock one for the PS cooler fits fine you just have to angle it in, I didn't know this before.
    Pic for reference of BOTH lines installed correctly for the 2.7T
    and the heater core hoses installed...
    S4 Hoses (the old ones)
    And finally some test fitting before the throwout bearing gets here tmrw...
    - Clint
  23. #183
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    2010 A4, 2000 S4, 2003 A4 Avant, 2007 Dodge Caliber
    Falcon, CO
    looking good.
    2010 A4 Meteor Gray ~ DD.
    03 A4 Avant ~ Polar White ~ 2.7TT Swap/Build thread
  24. #184
    Oct 29 2005
    Ft. Lauderdale, FL
    thanks dude. Motor should be in for good tomorrow but there are a lot of wires and things I need to figure out
    - Clint
  25. #185
    Saint Cloud, Fl
    Nice to see this build moving along.
  26. #186
    Dec 03 2005
    connecticut
    If the glove fits you must acquit.
    -Doug
  27. #187
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    2004 Audi A4 1.8T Ultrasport
    Nu Jerzi
    Nice bro, can't wait to see this thing in person
  28. #188
    Feb 25 2004
    02 A4 1.8t BT / 03.5 M3
    B-more, MD
    You are my HERO. lol make a plug play kit so everyone can swap....
    02 A4 1.8T fwd
    Maestro tuned and built by RAI.... bottom end, some head work, 3071 for now, custom RAI FMIC, and bunch of other stuff that I gotta find receipts for.
    my gallery
  29. #189
    Mar 27 2009
    03 Audi A4
    Columbus, Ohio
    Are you going to do the timing belt stuff while it is out?
  30. #190
    Senior Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    better hurry,you only have a week till you need to be at my place :P
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
  31. #191
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    02 A4 1.8TMQ 5 speed Avant, 08 Candy White R32
    NorCal (Fabulous Yuba City)
    I thought it was "if it does not fit, you must acquit"
    -Tim
    '08 VW R32, Candy White - stock
    '02 A4 1.8tmq Avant, Dolphin Grey - engine swap in the future
    Buy my KW Variant 1 coilovers!
  32. #192
    Mar 27 2009
    03 Audi A4
    Columbus, Ohio
    This is for Tom...
    Plug n' Play? Nice
    Where is mine? Body harness from a B5 S4 right?
  33. #193
    Senior Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 USP, 68 Camaro, 00 Cavalier
    Lancaster, PA
    Quote Originally Posted by black99.5a4 View Post
    I might be there with the B6 :)
    -Andrew
    2005 Dolphin Grey Ultra Sport
    HTA3582R 1.8L
    AEB IECVA1
    Agtronic Motorsport
    PARTS FOR SALE
  34. #194
    Jun 26 2008
    00' Noggy Stg2
    Quote Originally Posted by Wet0willy01 View Post
    You better be there. You live like 20 mins away!!
  35. #195
    Oct 29 2005
    Ft. Lauderdale, FL
    Shit, not gonna happen. I'll bring the bike.
    It's from a 2000 Passat. Got some more pics hang on
    - Clint
  36. #196
    Oct 29 2005
    Ft. Lauderdale, FL
    OK. Happy Father's Day everyone! Anyways, I did some digging today at the junkyard and guess what was there? a 3.0 B6! I've never seen a B6 there so needless to say I was quite excited and I picked up these bits
    If you don't know what ^ those are, I apologize, it's a terrible picture. I snagged the fuel return line and fuel pump cap for $10 total. Not bad huh? So, I will be doing a full writeup on how to convert from returnless to return the OEM way for cheap!
    Those plugs took care of the pigtail>car, but I still needed the 2.7>pigtail side, so I snagged these from a Passat! All set to make my adapter harness now.
  37. #197
    Saint Cloud, Fl
    what color is the interior on that car. Im looking for a black interior.
  38. #198
    Senior Member Two Rings Shenanigans's Avatar
    Jul 14 2009
    CO Springs/ Peterson AFB
    crazy rays? I'm originaly from Columbia
    Stage 2.5+
    ko3/ko4 hybrids/ AWE downpipes/ JHM FMIC/ Forge DV's/ greddy catback/ RS4 clutch/ Fidanza Flyhweel/ ARP / EBC red pads/ neuspeed sway bars / ST's/ Vast Meth
  39. #199
    Mar 13 2007
    I like where this thread is going.
    Quote Originally Posted by 7speed View Post
    Wanna have some parts shipped? I have most of a black interior I'd be willing to sell. Not sure how easy/cheap it will be to ship all this stuff though.
    -Tim
  40. #200
    Saint Cloud, Fl
    Pm me what you have available
