Page 16 of 30 FirstFirst ... 6141516171826 ... LastLast
Results 601 to 640 of 1163
  1. #601
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    Quote Originally Posted by zillarob View Post
    That makes it easier, thought I read somewhere they used different style pins.
    Keep us updated, Ill be watching this like a hawk. lol
    they actually use the same 10 pin connectors, but different 17 pin ones. Pins should still work though I think
    - Clint
    New Ride: White '04 S4 2.7T - Already Stage 2
  2. #602
    Registered Member Two Rings
    Jun 17 2011
    2003 A4--2.7t, 1966 Porsche 911 w/ 996 swap, 1969 corvette, 1967 Camaro
    NH
    On mine when I was wiring it I had to splice the matching body harness plugs (from 1.8t motor) to my 2.7t. I was going to repin but noticed that some pins were wider then others. Im sure it can be done by maybe trading spots on the chassis side for the couple times it occurs I just chose to go for a splice.
    Also as for a pigtail into ecu box I think it will fit if you loop it down past where the chassis plugs are and back up.
    Im just waiting for coils and an exhaust and Ill be on the road good looks and more picssssss
  3. #603
    Senior Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    03 Audi A4
    Columbus, Ohio
    You have any wiring info on what you did Wide? Cause we are both 03 A4's. Next week I'm going to getting into mine. What did you do for front mount sunb?
    Hahaha...dood! If the movie director wanted the car in the next fast and furious, I'd definitely submit the car! :-P - BoostBeeyatch
  4. #604
    Jun 17 2011
    NH
    Basically I used 2 Bentleys one for A4 and one for A6. My car was 03 1.8t CVT and the donor drivetrain was 02' A6. Only diff is mine is a Tip so some minor wiring differences. Im trying to work them out but have some customer cars that come first i am doing a tranny in a A3 DSG right now so im tied up for a bit. I can gather the scribble up so it makes sense maybe but I don't have a perfect cheat sheet yet. I do have have an extra set of body plugs and harness plugs im going to do up so some lucky winner can get that. For my snub I used the stock A4 1.8t one and modified the metal by cutting off the ends of the tube used for the intercooler. I then cut a small piece where it nubs up, fitted and marked the aluminum piece and drilled holes and tacked in some nuts. There is a pic on my FB page under stuff. heres a link http://www.facebook.com/photo.php?fb...type=3&theater
  5. #605
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    2010 A4, 2000 S4, 2003 A4 Avant, 2007 Dodge Caliber
    Falcon, CO
    I can't till I get my my turbos, I am so ready to get started on this.
    2010 A4 Meteor Gray ~ DD.
    03 A4 Avant ~ Polar White ~ 2.7TT Swap/Build thread
  6. #606
    Oct 29 2005
    Ft. Lauderdale, FL
    Got my spare 2.7T harness. Gonna bring the car down next week
    - Clint
  7. #607
    Veteran Member Four Rings AudiHere04's Avatar
    Nov 21 2005
    East Coast
    let me know when your in the dirty jersey...hehehe
    Buy My Parts!
    K03 w/ lines & OEM manifold - $300
    OEM FlyWheel - Best Offer
    Snow Performance Meth Kit - $400
  8. #608
    New Member One Ring
    Feb 05 2012
    Waterloo Ontario
    Hey i have a 2002 a4 i have recently started a b7 DTM bumper facelift, i plan on doing proper fender splicing to keep the b6 lines and match up to new b7 front, i also have sold my 1.8 and purchased a complete 2.7 engine, i plan on doing rods, rings and bearings. i am also outfitting frankenturbos and direct port nitrous with supporting mods. so far as far i have
    01e tranny rear diff and axels
    2.7t engine
    hood,fenders,OE DTM bumper
    rs4 flatbottom wheel
    b5 s4 front brakes
    044 fuel pump
    nitrous kit
    from what i read you can use a b6 3.0 front rad support, so i will need to use a b7 rad support for the conversion i would assume im looking for the 3.2 rad support? i have seen another b7 conversion and it happens to have a 3.0 ( http://forums.thecarlounge.com/showt...-ny&p=72693423 ) so would it be safe to assume the 3.2 support is what im looking for?
  9. #609
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    02 A4 1.8TMQ 5 speed Avant, 08 Candy White R32
    NorCal (Fabulous Yuba City)
    Clint, get a move on. I want to get working on swapping a 2.7t into my latest 3.0 A4, but I'm waiting for some wiring diagrams and directions cause I don't want to figure it out myself.
    -Tim
    '08 VW R32, Candy White - stock
    '02 A4 1.8tmq Avant, Dolphin Grey - engine swap in the future
    Buy my KW Variant 1 coilovers!
  10. #610
    Active Member Two Rings Mautino09's Avatar
    May 11 2011
    2004 Audi S4, 2006 Ninja 650R
    Bethlehem, PA
    Quote Originally Posted by sandspeed View Post
    Dragon Lady Avatar and Yuba City Location, you wouldn't happen to fly U2s at Beale would you?
    Also, I agree, I want to see this rolling.
    '04 Black S4 6MT - Piggie Downpipes, AWE Catback Exhaust, K&N Filter, Apikol Snub, 30% Tint
    FS: APR Downpipes
  11. #611
    Jan 30 2007
    Falcon, CO
    That is the very end Tim. Get all the hard parts bolted and finish the wiring last. The harness will be hooked up to the engine when it goes in. I will be more than happy to contribute to the wiring effort, but I need to get my turbos and downpipes in. I need to put those on first before I stab the engine and tranny in.
  12. #612
    Mar 13 2007
    Quote Originally Posted by Mautino09 View Post
    Nope, I'm a crew chief and was in charge of all the mechanics that fixed them. But you do have the base correct.
    -Tim
  13. #613
    Mar 13 2007
    Quote Originally Posted by nefkntym View Post
    That is the very end Tim. Get all the hard parts bolted and finish the wiring last. The harness will hooked up to the engine when it goes in. I will be more than happy to contribute to wiring effort, but I need to get my turbos and downpipes in. I need to put those on first before I stab the tranny.
    Fixed.
    Yeah, I'm trying to decide which direction to go with the turbos when my tax return comes in. Frankenturbos?
    -Tim
  14. #614
    May 11 2011
    Bethlehem, PA
    Very cool, my dad flew U2s at Beale until '99. I was actually born there and grew up in Yuba City. Someday I will move back for sure.
    FS: APR Downpipes
  15. #615
    New Member One Ring
    Feb 05 2012
    Waterloo Ontario
    Fixed.
    i am undecided aswell, my friends father who makes custom TIG manifolds and intercoolers for rally cars has offered to build me manifolds for a VERY fair price, but if i can get more people on the bandwaggon it would just make the deal better, if i go this route i am thinking about the gt28rs's or i may just end up with frankenturbos its a win win.
  16. #616
    Mar 13 2007
    Ok, so what ECUs can be used for this swap? Anybody got a list of part numbers and some advice? I've heard that the A6/Allroad ECU is the one to get to maek this swap easier, and the A6 motor might be the preferred version too, since it may have different sensors than the B5 S4 one.
    -Tim
  17. #617
    Stage 3 Forum Advertiser Four Rings Sales@RAI's Avatar
    Jun 22 2009
    Dundalk, MD
    Any B5 S4/C5 A6 ECU
  18. #618
    Mar 13 2007
    There's no difference between the auto and manual ECUs?
    -Tim
  19. #619
    Jan 30 2007
    Falcon, CO
    Physically no, you can take any auto ecu and have it flashed with a manual file or vice versa.
  20. #620
    Oct 29 2005
    Ft. Lauderdale, FL
    Down to RAI Motorsport with the sun shining on it!
    - Clint
  21. #621
    Jan 30 2007
    Falcon, CO
    Nice
    ...914?
  22. #622
    Active Member Three Rings DNasty777's Avatar
    Aug 01 2010
    '69 Plymouth Valiant
    Rochester NY
    What's under the car cover?
    2003 A4 1.8TQM
    [Tein S.Techs][Bilstein Sports][RPM 505s][RAI TP][Milltek DP][TT225][Uni Stg2][Magnaflow 16601][Hyperboost DV]
    --Dave--
  23. #623
    Oct 29 2005
    Ft. Lauderdale, FL
    66 Rustang
    - Clint
  24. #624
    Nov 21 2005
    East Coast
    ahhh i didn't know you were up here...i would have came to get the boot.
    Buy My Parts!
  25. #625
    Active Member Three Rings bondar1989's Avatar
    Oct 16 2010
    03 B6 A4 TQM
    Long Island, NY
    What are you getting done at RAI clint?
    198WHP / 248WTQ stock engine. stock K03. APR Tune. AWE Tuning Exhaust w. Testpipe. K&N Cone Filter. Forge DV. B5 A4 1.8T Trans. JOM coilovers. B5 S4 Wheels. 11mm Forge spacers. Painted Lowers. 4500k HID's. Track density engine mounts. APR Snub mount. Apikol Trans/Rear Diff mounts. Engine Refresh(cylinder hone/piston rings)
    BT Build Coming Soon...
  26. #626
    Active Member Three Rings vteckiller2000's Avatar
    Jan 22 2011
    2011 Mustang GT, 2008 ZX6R
    Iowa City
    Quote Originally Posted by bondar1989 View Post
    IIRC he works there again.
    2011 Mustang GT 5.0 - 419/378
    2003 B6 A4 TQM - 187/232
    --14.168@94.16 mph STOCK K03--
    2008 Kawasaki ZX6R - ?
  27. #627
    Oct 16 2010
    03 B6 A4 TQM
    Long Island, NY
    Quote Originally Posted by vteckiller2000 View Post
    Yea I heard he works there again. what does IIRC mean? and Im just asking what is he going to do to the car when it gets to the shop.
  28. #628
    Jan 22 2011
    Iowa City
    If I Remember Correctly
  29. #629
    Jun 22 2009
    Dundalk, MD
    Finish the wiring and put it back together. I couldn't do much with the car in NJ when I wasnt there
  30. #630
    Oct 16 2010
    03 B6 A4 TQM
    Long Island, NY
    Quote Originally Posted by Clint@R.A.I. View Post
    Oh nice are you planning on getting it running?
  31. #631
    Jun 22 2009
    Dundalk, MD
    never
  32. #632
    Jan 30 2007
    Falcon, CO
    never
    Yep, Clint and I were talking on Thursday. We decided that Flintstone-ing it would be far easier and cheaper.
  33. #633
    Mar 13 2007
    Just park it somewhere and make it look cool. You can tow it to all the shows.
    -Tim
  34. #634
    Jun 22 2009
    Dundalk, MD
    I'm all about the look
  35. #635
    Senior Member Four Rings vintagespin's Avatar
    Sep 15 2008
    NJ, unfortunately
    lol is this question serious?
    -dc
    2005 Dolphin Grey A4 1.8T Quattro 6-speed Sedan
  36. #636
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    2004 Audi A4 1.8T Ultrasport
    Nu Jerzi
    There are shops that have cars strictly for this lol. A whole bunch of parts, no dyno, and they never start it, but it's at every show lol
  37. #637
    Senior Member Four Rings viceprp's Avatar
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    ATW 1.8TQM | SCAT | FX400 | GTcougaR | AEM Standalone | Meth
    PM ME: Parting out all Stage I parts
    STEVE
  38. #638
    Senior Member Four Rings BUSAfREAkA4's Avatar
    Dec 17 2009
    Busa has a 1.3L engine so ill call it a small compact
    NJ All Day
    I loled
    -Nick
    REDRUM
    seph: who's ricky and why were you at his place with all those dildos?
  39. #639
    Oct 22 2010
    central florida
    ^lol at the video
  40. #640
    Oct 16 2010
    03 B6 A4 TQM
    Long Island, NY
    Quote Originally Posted by vintagespin View Post
    I think I was asking when is he trying to get it running. mistyped
