Last night I took off the old oil cooler sandwich from the old block, cleaned it up a bit and put it on with the mocal external cooler sandwich.
After I was done, I did a quick mock up of the fmic and the mocal oil cooler. The general idea right?
This morning when I started back up again, I went to work on the IC. I was going to weld custom brackets. I had some extra angle brackets, so I used them instead of reinventing the wheel. They are strong enough to hold up my garage opener...
Next up was mounting the oil cooler, I was stumped. There is really no good way to mount it. So, now I went custom. I cut up some scraps of aluminum and well...
Clears the hood just fine.
I also cut the first few pieces to make my down pipe, but I am also finishing the intake manny. I can't started welding up the down pipe because I would to change the Tungsten from Pure to Thoriated for welding stainless. I should be finished with the manny and starting on the down pipe tomorrow afternoon.
