Results 1 to 10 of 10
    Senior Member Two Rings vietxnam's Avatar
    Feb 25 2007
    Massachusetts
    Items for Sale
    zf vs koyo steering rack?
    My steering rack has been leaking. I put in an order for a koyo rack from discountsteering. Had it shipped all the way from the west coast to the east coast, to find that on the rack it says zf branded on the rack near the top mounting hole. Ive read they are not interchangeable. My question is, has anyone used a zf when your rack was koyo?
    nvm may have found my answer.
    life
    Jun 30 2008
    Erie, Pennsylvania
    Pretty sure this was a 4cyl vs 6cyl difference from the factory. I think the 1.8T's got the Koyo's. Anyhow, I don't think there will be any problems. The steering may have a slightly different feel. I think the V6 rack was dampened a bit more, or some such. Don't quote me on compatibility, as I haven't done the interchange myself.
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, 4.11 Final Drive, APR 93, R8 coil packs, Labree HFC & DP, 2.5" Exhaust, ST Coilovers, 034 RSB, A8 Brakes Front & Rear, 18" RS4 Reps
    "You need to know what you are doing...Its like a rainbow jungle in there." - Redline380
    Feb 25 2007
    Massachusetts
    Items for Sale
    Thanks for the reply. I'll be putting it in tomorrow, should be alright. I believe just the inner tie rods are different. As long as the new rack came complete with inners I should be golden.
    Veteran Member Three Rings RoadRage's Avatar
    Feb 09 2008
    '16 Allroad, '99.5 B5 A4 1.8T *sold, '66 Cl160, '70 CT70, '81 Vespa PX80
    Chicago
    Hey viet,
    I'm about to do the same thing as you. Did you get this installed? Were there any problems with the rack?
    Feb 25 2007
    Massachusetts
    Items for Sale
    Something came up the other day. I will be doing the install today after work. I will let you know if I run into any problems.
    life
    Aug 13 2008
    Indiana
    as long as it bolts in I wouldn't worry about it. I know mine used to have an internally dampened rack and now it's got the externally dampened but I didn't install the dampener. Gave it a more responsive feel.
    -Nic
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    They're interchangeable, I had a Koyo rack put in place of my ZF rack. However you may get boned on the core charge which will set you back. Also, the tie rods may be different, I'm not 100% sure.
    Feb 25 2007
    Massachusetts
    Items for Sale
    Yeah the rack is in. Only problem I had was getting that damn 22 banjo bolt on. Took me over and hour trying to start it. I had to replace my outer tie rods even though the ones on my old rack were meyle hds I put in less than 6 months ago. In the end the job wasn't too bad took me about an hour to unbolt and remove an about 4 hours to install.
    life
    Feb 09 2008
    Chicago
    Good to know. My outer tie rods are almost brand new, I just did my control arms last fall. Looks like I'll be ordering a new rack today.
    Aug 15 2008
    Morgantown WV
    You guys that have changed to the zf, how does it feel compared to the koyo. Mine needs replaced an i have access to 3 zf's.
