Results 1 to 40 of 42
    Active Member Two Rings amar26's Avatar
    Feb 23 2011
    Oakville, ON
    led license plate + resistor
    did this the easier / cheaper way ..
    pretty simple, got a 100 ohm 1w resistor and some heat shrink, wrapped the heat shrink around the resistor and tied the 2 prongs around one of the license plate bulbs and bingo no more bulb out warning.
    i know what you're going to say what about the HEAT! the bulb actually is generating more heat then the resistor is after 20minutes of driving so not too worried at this point and because of that I moved the resistor directly ontop of the bulb so that theres a heat shrink barrier between it and and anything else.. guess time will tell to see how long this lasts. pics below.
    and also decided to clean my rims.... (orange blast rim cleaner + megiuars tire wet)
    Active Member Four Rings Mc Suly's Avatar
    Aug 20 2010
    UPS TRUCK/AUDI B7
    MONTREAL, QC, CANADA
    WOW!
    You couldn't put this up earlier?
    haha, hope it works out.
    Black is beautiful
    APR HPFP|AWE FMIC|AWE Exhaust|RAI Motorsport 3"DP/HFC|145Bar Rail Valve|Stasis Coilovers|Meth Injection Kit|RS4 Rear Sway Bar|JHM SS|034 STUDS|S4 BBK|STOPTECH SS LINES
    Unitronic: Stage 2 HPFP
    Flat White Enkei PF01
    Montreal Audi Club
    Feb 23 2011
    Oakville, ON
    was busy haha, and didn't really think of it until the only better alternative involved peeling back the entire trunk liner and sticking a massive resistor inside there
    i'll probably re-do this in a week or so when the temperature gets a bit warmer outside and I have some motivation to solider the prongs properly as well as the piss poor job I did on the heat shrink (I was working with a pretty poor lighter that was running out of fluid!)
    Senior Member Three Rings Mr. Merk's Avatar
    Sep 20 2007
    08 A4 S-line Titanium
    NW Arkansas
    just one bulb right? if this works I may be doing it tomorrow
    02 S4 2.7T Stage 2+ | VAST | Penske | Stasis | Hotchkis | Stoptech | Neuspeed | XSP | IPP | JHM | Stern | Avalon | ASP | VMR | Podi | 034 | AEM | SDR
    08 A4 2.0T S-Line Titanium Stage 1 | VAST | ST | Koni | VMR | Forge | 034 | BSH | Omori | AFE
    87 S-10 383ci | th-375 | Slicks & Skinnies
    05 Sierra 5.3L SLT Crew | Bone stock
    DUH! an Audi
    los angeles, CA
    interesting, i went the larger resister for the trunk...never had a problem since, this seems much easier though!
    -randy
    Feb 23 2011
    Oakville, ON
    yup, you just need to put the resistor on one of the bulbs.
    i might trying something similar to this for the DRL's later this week
    Senior Member Three Rings RJMars's Avatar
    Oct 18 2008
    Minnesota and NJ and MI
    mmmm Tire Wet...... I'm doing an all day detailing session next weekend, can't wait to have my tires shinin like that.
    Light Silver Metallic 2005.5 A4 2.0T, Quattro, MT, CPO
    Audi Sport rubber mats | red LED footwell & courtesy lights | pure white LED interior & rear plate lights | BMW Shadowline matte vinyl trim | de-badged | dark smoked blinkers | Brilliant Black S-line valence & mirror housings | City Lights w/ fogs mod | Lamin-X Gunsmoke tails | Cupra Lip | glossy black trunk rings | Bosch Icon wipers | "17 USP wheels w/ Nankang SV-1 snow tires | "18 BBS RX wheels w/ Michelin Pilot Sport PS2's
    Veteran Member Four Rings Jer's Avatar
    Sep 17 2004
    Supra, Tundra & A6
    Colorado, USA
    I'm curious how this works long-term. I bought one of those 50w 6ohm resistors that's a giant aluminum heat sink'd beast and that thing got SO friggin' hot. I didn't trust mounting it and leaving it. We threw some drops of water on it and the water was literally jumping of and instantly turning to vapor it was so hot. We were guessing the temps somewhere in the ~350deg f range. I pulled everything out and put it back to stock because of that. Sucks too because I had a pretty bad ass backup cam/LED replacement for the left license plate light. Now I have to drill the plate and trunk to mount a stand alone cam.
    2004 Chevy Silverado SS AWD
    2007 Audi A4 2.0T Quattro
    2007 Toyota Camry Hybrid
    2007 Suzuki GSX-R1000
    =-----> DO NOT SHIP W/DAS (DEPENDABLE AUTO SHIPPERS)!! <----=
    Senior Member Three Rings Adub-Drew's Avatar
    Feb 07 2010
    Wilton, CT
    So this WILL work with a Color DIS?
    Team ACE - CT
    Sep 20 2007
    NW Arkansas
    Quote Originally Posted by Adub-Drew View Post
    the OP has color
    Senior Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2006 A4 S-Line, 1990 944 S2
    big props to you! why do you only have to put the resistor on only one of the bulbs? please post pics of the re-do when you get to it. thanks
    How to sell an item in the classifieds:
    10% off- Brand new in box from authorized retailer on special
    20% off- New, never used, private seller, box optional
    30% off- Used but in great condition, all parts present
    40% off- used, may be damaged or missing parts
    50% off+ Handyman's ''dream''
    Feb 23 2011
    Oakville, ON
    because if you notice when you are changing the bulbs from stock to led when you replace one light theres no bulb out warning, when both are in you get the bulb out.. so you only need one of them to get the annoying warning off...
    i'll try to get some better pics up later this week - it's not much different from what I did above but i'll be solidering the prongs to the resistor instead of just coiling them around
    and yes it work with a colour DIS.
    the bulb gets hot more so than the resistor does - if anything long term the bulb might burn out but that's why I got some cheapie 2dollar ones in there.
    Sep 20 2007
    NW Arkansas
    the car monitors total resistance of the license plate lights as a pair, if it changes it only knows that at least one bulb is out, but not which one.
    Dec 20 2009
    Calgary
    Im gonna try this soon, were did you get the heat shrink from
    Sep 20 2007
    NW Arkansas
    did this last night, worked great
    Feb 23 2011
    Oakville, ON
    Quote Originally Posted by bk10 View Post
    any store will sell some heat shrink - radio shack, etc.,
    Senior Member Three Rings Rahbey's Avatar
    Feb 08 2010
    2006 A4 3.2 | 2008 Acura RDX
    cool cool, now it's finally time to order some LEDs and get this done!
    Thanks OP, I have color display too and I'll post my results when finished.
    -b7 A4 3.2 Premium-
    Registered Member One Ring zoocoin's Avatar
    Mar 15 2011
    SWEDEN
    Does anyone know what type of resistor I need for this DRL bulb?
    SMT Tower
    44 High Powered Wide Angle SMT LEDS
    These Bulbs have Advanced Surface Mount Technology LEDS + Advanced Patented Circuitry
    36 high powered SMT side facing LEDS - 12 high powered SMT forward facing LEDS
    High Powered 3 Chip SMT Leds - Outfitted with Canbus Bulb-Out Warning Cancellation Chip
    Designed to eliminate most electronic bulb-out warnings in BMW, Mercedes, AUDI, VW, Volvo, and most others.
    -link: http://autolumination.com/1156_1157.htm
    I still get a warning signal in my DIS, even do it's CANBUS Bulb-Out Warning Cancellation Chip.
    Thanks/
    __________________________________________________ ____
    Link to my: -Audi A4 2.0Tdi quattro 170hp -08 /Suzuka Grey Edition-
    Mar 19 2008
    i tried this an it doesnt work. bought ddm festoon bulbs. using 1 resistor like the one listed only illuminates one bulb. using two does the same. using none illuminates none. any help?
    Active Member Two Rings titanium08's Avatar
    Aug 14 2010
    Northeast
    Quote Originally Posted by amar26 View Post
    This worked thank you
    Did u try the drls yet and if so can u show us how and what resistors u picked out
    Feb 23 2011
    Oakville, ON
    no haven't done the DRL's yet... again been lazy.. gf is visiting but maybe this week when the weather gets better.
    Feb 23 2011
    Oakville, ON
    Quote Originally Posted by RedS-line View Post
    bad bulbs?
    Active Member Three Rings Schweini's Avatar
    Sep 12 2011
    '08 VW Golf
    Hamilton, Ontario, Canada
    Got it to work the first time around, then went to cover the resistor with heat shrink tubing for permanent use, I added the resistor back to the bulb it wouldn't work. Couldn't get it to work ever since... very annoying
    EDIT:
    The resistor I used was a 100 ohm .5w .... I'm gonna guess it burnt out only having a .5w rating thus not working anymore...
    2008 A4 2.0T S-Line
    APR Stage 1, ST Coilovers, Sonic Tuning Rs4 Reps, BOSCH F5DP0R spark plugs, V12 Ventus Evo's 245/40/18, H&R 8mm spacers (rear), 034 HFC, N80 valve updated, RS4 Grille, K&N, VAG, 6000k HID fogs, Fog Light Mod, CC Mod, City Lights GONE, Apikol Snub, 20% Tint...;
    Sep 12 2011
    '08 VW Golf
    Alright well, I hate to beat a dead horse and keep reviving this topic, but I've been tinkering around with this to see what's the best possible method to get this working and I've come up with the conclusion that putting one 100ohm 2 Watt resistor on each of the license plate bulbs will eliminate all DIS errors. Having one resistor on one light would work for a bit, then while driving I'd get the error to come back on. So for those who never got it to work, try this and I'm sure you'll get it.
    The lights don't dim, and since the resistors are rated for 2 watt, you don't need to ever worry about overheating. I'd still recommend using some heat shrink wrap like the OP stated, just to enclose and keep the light circuits safer.
    Here's the resistors I used: http://www.ebay.com/itm/230719186583...84.m1497.l2649
    dirt cheap, and you get 10 of them. I tested all of them once I got them and they all measured 100 ohm's on the dot.
    2008 A4 2.0T S-Line
    Senior Member Four Rings fly300kts's Avatar
    Oct 16 2008
    South Florida
    Goal preventing a fault code with a led setup is to calculate a resistor value that, added to the LED draw will equal the same draw than the original bulb. The value I am referring to is the Ohms of course since the watt value is only for power dissipation.
    Now, how did you came up with our conclusion that this resistor will get rid of ALL errors codes? And it would be nice if you could post the math as well.
    As for now, because all the LED have different draw,my our conclusion is totally false
    Phil
    Sep 12 2011
    '08 VW Golf
    My mistake Phil. I didn't take into account that others would be using different LED bulb set-ups. I suppose I was just excited to finally get this working after a lot of trial and error on my part. You are right though.
    I'm using the LED's off Ebay from Zeus group http://www.ebay.com/itm/170516746686. I noticed with these LED's, you can get the fault code to go away with using one resistor, but for me it inevitably always came back wether it was 1 day or 1 weeks time. I decided to use 2 resistors, one for each LED and it's taken the problem away so far. I've been driving for a few weeks now and all seems to be working great.
    So in other words, if you're using this set up, this method should work for you. If you have different LED's and you're getting a fault still, give it a try.
    2008 A4 2.0T S-Line
    Active Member Two Rings A4turboSs's Avatar
    Aug 02 2008
    Action Heights, IL
    So i presume from what I have been reading no one at all sells license plate bulbs that will work straight from the box. I hear some people have luck others dont. Its like hit or miss.
    Sep 12 2011
    '08 VW Golf
    Quote Originally Posted by A4turboSs View Post
    It seems to be hit or miss, yes. The ones off Ebay that I bought from Zeus Group are advertised as Error Free, but they sure as hell aren't. I complained and got my money back, then bought some .99 cent resistors and fixed the issues
    2008 A4 2.0T S-Line
    Aug 02 2008
    Action Heights, IL
    Quote Originally Posted by Schweini View Post
    Hahaha. That makes sense and interesting I wanna get some bulbs but truly dont wanna deal with this nonsense anymore I am surprised a vendor has not found a complete solution for this and sold them.
    Sep 12 2011
    '08 VW Golf
    If I'm not mistaken, you can purchase error free LED's that come with a built in resistor that actually do work, but you're paying a pretty penny for them. I think the majority of people here just buy the cheap ass Ebay lights and simply add a resistor for 1/4 of the price.
    2008 A4 2.0T S-Line
    Active Member Two Rings midnight407's Avatar
    Oct 21 2011
    Chicago, IL
    seems to me, in my reading experience, the error free LEDs still throw an error if you have Color DIS but somewhat work if you have Red DIS
    midnight407 | 2005.5 A4 2.0T quattro AT6
    Brilliant Black | Ebony
    Premium/Audio/Cold Weather/Sport Packages
    Chicago, IL
    Feb 07 2011
    B7 Avant S-Line, W211, LC100
    Oxnard, CA
    Did this 8 months ago and never had issues. I put one resistor per bulb.
    Aug 02 2008
    Action Heights, IL
    Yea i can imagine the pricing on it. Makes sense I'm gonna just do that and get the same ones you did and see what happens if the bulb out comes on I will just do this resistor mod and go from there. I have the Red Display so I hope it doesn't even go off for me lol
    Active Member Two Rings blazeblunts4's Avatar
    Jan 29 2011
    Cali
    The bulb out will go for sure without a resistor. You can code it out in VAG-com, or add the 100ohm, both will fix it 100%
    The Audizine N00b
    Active Member Three Rings jmarch1122's Avatar
    Mar 13 2011
    MA, USA
    how 15 bucks this is worth trying.
    Mauritius Blue 2.0T quattro
    GT3071R, AutoSpeed Tuned, VAST S3 Clutch w/ LWFW, HPFP.com S2, RS4 injectors, V-Flow intake, Hallman MBC, DO's W/M, Forge 008, KW V3, H&R Sway Bars, Neuspeed, AWE, JHM
    DTM front, Deval rear and sides, JL HD750/1, JL 10w7
    Sep 12 2011
    '08 VW Golf
    I have the red DIS also, let me know if it works! Good luck
    2008 A4 2.0T S-Line
    Sep 20 2007
    NW Arkansas
    Quote Originally Posted by blazeblunts4 View Post
    The bulb out will go for sure without a resistor.You can code it out in VAG-com
    WRITE UP?
    May 21 2007
    07 A4 Ibis White/S-line/Ti/2.0T Q
    Northshore, MA
    Quote Originally Posted by Mr. Merk View Post
    WRITE UP?
    x2....i feel like litterally everyone would have already done this if it was either A)possible or B) common knowledge. all the license plate light threads ive read through and this is a first.
    -Nate
    07 Ibis White A4 S-Line Ti Package
    GTRS'd 04 6SPD 1.8T A4 Quattro SOLD
    http://www.cardomain.com/ride/3037832
    B7A4 Build Thread: http://www.audizine.com/forum/showth...58#post7310258
    PM me with youre H&R Parts needs!
    Oct 16 2008
    South Florida
    Principals have been addressed here
    http://www.audizine.com/forum/showth...oblem-Solution
    Phil
    Dec 01 2010
    Chicago fool.
    2005.5 with color DIS. I needed one 100 ohm 1W resistor PER BULB for the leds I purchased but they are working great with no codes!
    thank you. thank you. thank you!
