Four Rings
apikol LW front rotors
i doubt this is a repost but if it is my bad. but in the newest eurotuner i found these and figured id share
2011 S4,6MT,phantom black,panda leather,carbon trim,prestige,B&O,sport diff,titanium package,alu-optics,MMI 3G+.5,APR 93 flash,APR pulley,APR CPS,APR intake stg1+2,Miltek Valved full res,Eurocode headers,Eurocode shifter,Eurocode stabilizer bar,Eurocode sways+end links,clutchmaster fx400,KW V3 coilovers,ST-60's 380mm,P3 boost gauge,E-code's,TT-RS wheel,ETMS piano black trim,VNSmedia tv simulator,RS4 pedals,Deval CF lip,deval rear CF diffuser,HRE P43SC 19x9.5 tinted clear finish,RS4 grill
Forum Moderator
Four Rings
Looks promising. Never heard of Apikol.
Senior Member
Three Rings
went to the website and couldn't find the rotors, but they do make the porsche brake kit like ecs does
2010 Phantom Black S4 Prestige 6MT | Nappa Blk/Sil | 30% Tint | Painted Front Plate Delete & Grill | Hoen H11 Enduro Fogs | Red SC'd Badges | Rear Plate LEDs
Forgestar F14 18x9.5 | H&R Coils re-valved | JHM SS | SS Lines & RBF600 | AP Racing Rotors & Carbotech XP10 | GMG F/R Sways
VAG'd | Milltek non-res w/ DPs | Stratmosphere Hyperflow | APR 93 Tune | Future: Pully & Switching mode please!
Senior Member
Four Rings
Me either, though with StopTech ST-60 I lost 5.4 lbs per rotor...
Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
StopTech ST-60 BBK - Stratmosphere intake - APR Stage 2 w/pulley + exhaust
**** Have USB HEX-CAN Vag-Com cable if you need someone local to mod you ****
My Fuelly mileage
Four Rings
i had a rear diff mount for my rs4 from them. they do a lot of racing stuff so im sure this would be a quality part
Registered Member
One Ring
They have a facebook page. They say they save 5lbs over stock. Look like they've been available for 2 months. Couldn't find them on their website.
Senior Member
Four Rings
2013 Daytona S8,B&O,Bk alcantara,Solar,360 camera, adaptive cruise,
0-200km/hr 13.1 secs
Motortrend test- 0-60 3.5sec, 1/4 mile 11.8@118.3mph, dyno 479awhp at k&n dynojet facility
Senior Member
Four Rings
Just got off the phone with them. Price is 799 for both, fully floating and directional. Apparently our stock rotors are directional but only in one direction so one runs hotter than the other. The replacement rings are going to be around 200 and the hardware kit that they reccomend is going to be around 35 a corner. So it looks like initially it might be a little more expensive but it'll pay off in the long run with the rings being so much cheaper. Weight savings is 3lbs a corner. I'll be giving them a call when I'm in need of new brakes.
Forgot to ask about different finish options and patterns.
Senior Member
Four Rings
So which is it 3lb or 5? The Stoptech rotors alone save 5, are directional and replacement rotors are about the same - they might even source from the same place. The entire BBK saves 10lbs per front corner (pads included) once you swap out the caliper too.
My Fuelly mileage
Senior Member
Four Rings
I called and was told 3, he may have been mistaken but thats what he said
Forum Moderator
Four Rings
Well, I can assure you that StopTech definitely makes their own. I was lucky enough to take a tour of their Compton, CA facility when I was down there to lend my car for R&D on the ST-40 kit. It was pretty incredible being able to witness the process of making rotors from raw materials to the final product. Definitely a first class operation, from engineering all the way to packaging!
Senior Member
Four Rings
Good to know (both that they make their own and that they are in COMPTON?!)
My Fuelly mileage
Forum Moderator
Four Rings
It's not as bad as it sounds. Compton today is not like it was in the 80's. Many of the "projects" were torn down to build large industrial buildings. Sure, the surrounding area is no Beverly Hills... but it's not like the rap songs would have you believe either.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
