Just picked up some NGK BKR7EIX's. Hoping to put them on sometime tomorrow. If I run into any issues I'll let you guys know. When I checked I think the gap is close to 0.030"
07 Audi A4 2.0T Tip Quattro S-Line: Titanium Package, Premium package
Stage I APR | Adam's Rotor's | StopTech Pads | CityLight /Fog | Diverter Valve - Rev D | RS4 Sway Bar | Snub Mount | Vag'd
^^^people.... PUSH IN.....then pull out take a lesson from sex, the screwdriver will sometimes break off the tabs and it sucks....but if you push in then with your finger push down on the tab while pulling out it will slide right out
......omg what did i just say?
Scott
I don't even have an audi....i just love me some 'zine
America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
Just to clarify - according to the NGK website (ngksparkplugs.com) they recommend the PFR7S8EG Laser Platinum plug as a direct replacement in the 2.0T. If you look at their part number fact sheet (http://ngksparkplugs.com/docs/tech/partnumberkey.pdf) the '7' indicates the heat rating number, so I'm assuming that would mean that their BKR7EIX plug mentioned in the first post is also now in the recommended heat range?
Would seem to be backed up a little bit by an article that I found on the GTI forums (http://changegears.wordpress.com/201...-ngk-pfr7s8eg/) - take it for what it's worth I guess... EDIT: Just noticed that ECS also lists the BKR7EIX plug as a replacement for our cars....
I just purchased a set of NGK BKR7EIX-11 and after reading this im not sure if it will work with my car, they are gaped at .40 I believe. Should I exchange these out, (bought from amazon) or can I make them work?
2006 A4
Apr Stage 2 : AWE Quads : Test Pipe : AEM Cold Air Intake : 6000K : Cupra Front Lip : H&R Springs, Bilistein Struts : 19" ST160's : Autometer Boost Gauge : ECS Clear Sidemarker Set : S1 License LED : 35% Tint : Front Plate Filler
If possible, exchange them for NGK BKR7E-8.
Stokes|Moderator - PM me with any questions/concerns
Just installed some NGK BKR7E copper plugs and I must say they are soooooo much better. Had my old plugs in for 44k miles..these new plugs are great. Car rides smooth starts up fast pulls harder an even holds more boost on shifts..highly recommend these plugs
BBS CK,ST coilovers,Vast Stage 2,Custom 2.5in ESP turbo back exhaust non res with AWE Mufflers, Black RS4 grill, Painted BB LP filler plate, RS4 Fog Grill mesh, Cupra R Lip painted BB, S4 Door Blades,Votex 3 piece trunk lip, Votex rear sport Valance, D/S rotors, Matte Silver mirror caps, Adaptive European Headlights, 8k HID headlights&fogs, LED city light&DRL, Custom intake, Forge DV spacer
2008 with milltek and APR looking at these NGK BKR7E copper plugs....any opinions? good choice?
I use them they are very good. Holds boost very well. Peppier sounding engine. Just they have to be changed more regularly only downfall
