Results 1 to 40 of 64
    Forum Moderator Four Rings kristokes's Avatar
    Jan 03 2007
    NNJ
    The B7 A4 Spark Plugs Replacement Guide
    DIAGNOSIS OF A USED SPARK PLUG
    Normal
    Light grey or tan deposits and slight electrode erosion
    Carbon Fouling
    Dry, soft black carbon on the insulator and electrodes
    Symptoms:
    • Poor starting
    • Misfiring
    • Faulty acceleration
    Causes:
    • Faulty choke - over rich air/fuel mixture
    • Delayed ignition timing
    • Bad ignition leads
    • Plug heat range too cold
    Pre-Ignition
    A melted or burned center and/or ground electrode, blistered insulator and aluminum or other metallic deposits on the insulator
    Symptoms:
    • Loss of power causing engine damage
    • Pre-ignition occurs when combustion begins before the timed spark occurs
    Causes:
    • Plug insufficiently tightened
    • Engine insufficiently cooled
    • Ignition timing too advanced
    • Plug heat range too hot
    Over Heating
    An extremely white insulator with small black deposits and premature electrode erosion
    Symptoms:
    • Loss of power at high-speed or during heavy load
    Causes:
    Mechanical Damage
    Bent electrode and a broken insulator, dents often present on electrode
    Symptoms:
    • Misfiring
    Causes:
    • Plug nose is too long for engine head
    • Foreign object (bolt/nut) in combustion chamber
    Oil Fouling
    Wet, oily black deposits on the insulator and electrodes
    Symptoms:
    • Poor starting
    • Misfiring
    Causes:
    • Wrong piston rings, cylinders, and valve guides
    • Fuel mixture oil content too high
    Broken Insulator
    Insulator is cracked or split
    Symptoms:
    • Misfiring
    Causes:
    • Severe detonation
    • Incorrect tool/torque applied during installation or removal
    • Careless gap setting
    Torched Seat
    Melted in the thread and seat area of the plug housing
    Symptoms:
    Causes:
    WHICH SPARK PLUG IS RIGHT FOR ME?
    Auto makers built their cars to be maintenence-free, and no prudent consumer in their right mind would buy a car with plugs that you have to change every 3000-5000 miles these days (unless it was a hand-me-down used car). Most modern day vehicles will use iridium, while most are using platinums.
    Platinum plugs (and Iridiums) were introduced to provide longevity (60k-100k+) to vehicles compared to copper plugs which foul after 3000-5000 miles, but they do NOT dissapate heat fast enough (which leads to pre-ignition/detonation) and do NOT provide a "better spark" like they have claimed...with their "fine-wire electrode" (which only causes problems).
    Copper is one of the best conductors of electricity and heat, but they just plain dont last. Using Platinum and Iridium plugs, the center electrode (fine-wire) thin, that under high boost, they get so hot, they will begin to "heat glow" and cause premature ignition in the combustion cycle (pre-ignition => detonation) unless they were properly designed to pull the heat. This is a problem for all of us turbo guys running high boost. Copper on the other hand, has a much thicker center electrode, on top of that, the copper material is able to dissapate heat from the combustion chamber fast enough to keep the combustion temperatures lower. Coppers use thicker electrodes simply based on the fact that they can easily jump the spark, whereas platinum and iridiums will require a fine wire to better direct the spark to prevent missfires.
    Remember the two primary functions of a spark plug:
    1) To efficiently ignite the A/F mixture without mis-fires (Gap, etc)
    2) To pull heat from the combustion chamber into the head, where the cooling system should dissapate that heat. (Heat Range)
    With those two in mind, coppers will work much better in these environments. For those thinking: "What If I just simple use a colder Platinum plug?" Well, for the kind of boost our A4's make with the Krispy-Kreme K03's, we will reach EGT's of over 900 degrees C (keeping in mind that pre-ignition can start to occur at around 870 degrees C). Once those colder platinums reach preignition temperature, it will take them FOREVER to dissapate that amount of heat (with the details about the material/design I mentioned above). A platinum/Iridium plug in a colder heat range usually runs just as hot as a copper in the standard heat range when under high stress. So many people will use a Platinum/Iridum plug TWO steps colder to counter that. But using a plug that is 2 steps colder, will lead to two things:
    1) More prone to carbon-fouling on "normal driving" where EGT's are kept low. (Plugs must stay above 550C Deg to burn off excess carbon deposits to "self-clean")
    2) As a result, loss of horsepower from a less efficient/inhibited spark.
    You need a plug that is actually "hot enough" to ignite the A/F mixture as hot as possible to get the most efficient combustion, as well as burn off carbon-deposits (~550C deg), and yet cold enough to prevent pre-ignition when compression is high (< 870C Deg).
    HOT - NGK #6 (OEM Range)- Stock car with stock boost/timing, or mildly-tuned car in cold climates.
    Recommended plugs in this heat range:
    • NGK BKR6E (Copper)
    • NGK BKR6EIX (Iridium Version of the same plug above)
    • Denso K20R (Copper)
    • Denso IK20 (Iridium Version of the same plug above)
    • NGK PFR6Q (OEM Platinum) - If you're planning to stick with stock boost
    COLD - NGK #7 (One Step Colder) - Cars with basic performance upgrade (chip/intake/exhaust) - k03, k04, etc.
    • NGK BKR7E (Copper)
    • NGK BKR7EIX (Iridium Version of the same plug above)
    • Denso K22R (Copper)
    • Denso IK22 (Iridium Version of the same plug above)
    COLDER - NGK #8 (Two Steps Colder) - Cars with bigger turbos will benefit from these, whereas a regularly chipped car may foul these.
    • Champion C63YC (Copper)
    • NGK R5672A-8 (Copper, Non-Resistor plug)
    • NGK BKR8EIX (Iridium)
    • Denso IK24 (Iridium)
    • Bosch FR5DTC (Copper)
    • Bosch F5DPOR (Platinum/Side Fire)**
    ** - Many members have found real good luck with the Bosch F5DPOR's, this is why:
    Despite all the "con's" about platinums (poor conductivity, poor heat dissapation qualities), the engineers at Bosch has managed to engineer the F5DPOR's so that they are still able to fire the A/F as well as pull away enough heat. The F5DPOR's unlike conventional plugs, use a "Side-Fire" technology, where instead of a standard "projected" electrode into the combustion chamber, the ground electrode was placed on the edge of the plug so that it fires closer to the flame kernel. By doing so, the F5DPOR's are able to still keep a thick center electrode (to pull heat away faster) without having to go with a smaller electrode in order to fire. The F5DPOR's heat range is also equavalent to that of a NGK #8 (TWO steps colder than stock), in order to give the same effect as a #7. But because it is a platinum plug and not copper, they will not foul "as" easily where a copper would have. Because of these two important attributes, Bosch was able to use these plugs to both last like other platinums (up to 60k), while still function under more extreme environments. Platinums however, still do not compare to iridiums in longevity, as well as heat/electro conductivity.
    Quick cross-reference guide for all the plugs listed above in heat range:
    (VW/Audi Factory heat range in bold)
    NGK - | 5 | 6 | 7 | 8 | 9 |
    Denso - | 18 | 20 | 22 | 24 | 27 |
    Bosch - | 8 | 7 | 6 | 5 | 4 |
    Champion - | 11,12 | 9,10 | 7,8 | 61,63 | 59 |
    QUESTIONS & ANSWERS SECTION
    Question:
    How cheap are the copper plugs? Can you actually feel a difference in performance?
    Answer:
    Quote Originally Posted by kristokes View Post
    I got mine for $3 each so $12 for a set of 4.. For that price, it's worth trying them out yourself
    Question:
    Also, do you recommend a .028 gap on the coppers?
    Answer:
    I gapped the plugs from it's specs (0.028") to 0.032" (do not go over). The minute I fired up the car, the exhaust tone became a LOT deeper. So I took the car around the block, then on the highway doing some 0-100MPH pulls - the car became a LOT smoother! The powerband of the turbo will now make boost past 5000RPM and the spool-up became noticeably quicker. The hesitation I used to experience at 5000RPM disappeared and the idle became a lot smoother.
    By simply switching spark plugs, I would say that my "butt-dyno" pretty much felt another 5-10hp difference in power.
    Question:
    Quote Originally Posted by matthewb2795 View Post
    Stock gap is .028 right? .032 is recommended for tuned cars. Or is the opposite true?
    Answer:
    Well it depends on what you mean by stock but coming straight from the factory, our OEM spark plugs are actually UNDER-GAPPED at 0.027". Since OEM spark plugs were made for longevity (~50k+ miles), they were set at a lower gap because the gap will eventually get bigger through time and wear on the electrodes.
    IMHO from personal experience, I believe a 0.032" gap is optimal for our cars.
    Since I currently use NGK spark plugs on my B7A4 and quite familiar with them, let's go over what to look for and what to set the gaps at when using NGK as an example (the same concept can be applied to other brand spark plugs)
    This is how NGK's numbering system typically works:
    Most NGK spark plugs you find at your local auto parts store end with a (-xx) after the part number; which signifies a pre-gap.
    For example, if you got a set of BKR7E-11's (although those are very hard to find), the -11 denotes a 1.1mm or 0.044" pre-gap. A BKR7E-8 would be a 0.8mm or 0.032" pre-gap, and so forth.. However, part numbers that do NOT have a (-xx) such as BKR7E will indicate the default gap of 0.0315" (basically a 0.032"). So do NOT get that confused.
    Many people who use the BKR6E's often buy the BKR6E-11's instead since it's OEM recommended for many vehicles, which comes with a HUGE gap of 1.1mm or 0.044". In order for it to work properly with the gap you want (0.032"), you need to bang the crap out of the ground strap just to make 0.032". But by then, the strap is already crooked and bent. This will lead to more mis-fires and pre-mature wear. You typically want a spark plug that's pre-gapped as close as possible to your desired gap - best way to keep the center and ground electrodes parallel.
    A general rule of thumb:
    Always stay within a +/- 0.008" gap range when re-gapping. Basically, a 0.032" plug should be gapped no less than 0.024" and no more than 0.040". (This applies to most plugs using a single ground electrode strap. Multi-electrode straps are a different beast that I'm sadly not familiar with.)
    Stokes|Moderator - PM me with any questions/concerns
    [ 2007 ] SLOWHTE
    [ 2005 ] RAVEN R1
    [ 2001 ] TT COUPE
    Senior Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    thanks Stokes, yet again another great write up man keep em comin!
    QG B7 Ti. A4 / S-Line / HID Fogs / Carbonio CAI / ECS Smoked Side Markers / Dark Smoked Side Fender Blinkers / LED License Plate Lights / 034 Turbo Inlet Hose / RS4 Rear Sway Bar / CC + Blackout / LED DRL's / VAG-COM'd / Forge DV / A.W.E Vent Pod Boost Gauge / REVO STG 1
    Nov 23 2004
    Boston
    Great stuff here. Thanks for taking the time to put it together for us!
    APR Stg 1 93/Carbonio CAI/O34 Inlet Hose/RS4 RSB/18" BBS CHs/OSIR CF mirrors/DTH Side Skirts/AWE Vent Boost Gauge/Passport 9500ix/
    Senior Member Four Rings beantown's Avatar
    Jul 27 2009
    '07 A4 2.0T Quartz
    Guess...
    Thanks for the write-up; great stuff as usual.
    Sep 27 2008
    Phoenix
    Great info. Does anyone here actually use copper plugs? It seems like a lot of work changing your plugs every oil change.
    Jan 03 2007
    NNJ
    I use copper plugs (NGK BKR7E) and change them every oil change.
    [ 2007 ] SLOWHTE
    [ 2005 ] RAVEN R1
    [ 2001 ] TT COUPE
    Senior Member Four Rings jimrobbington's Avatar
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    05.5 A4 2.0T 6spd, REVO Stage 2, Vast Stage 3 clutch, VMR test pipe, custom 2.5" Techtonics exhaust, Borla mufflers, wastegate adjustment, 034 catch can, BKR7E, JHM Short Shifter, KW V1's, 19" V710's, Podi boost gauge, 640 Mod, 18% tint.
    Dyno proven 221 whp/302 wtq!
    Driving Style: Strategic Aggressor
    Eric Paul Young: "I just tore down my old boy and slapped the internals."
    Jan 03 2007
    NNJ
    [ 2007 ] SLOWHTE
    [ 2005 ] RAVEN R1
    [ 2001 ] TT COUPE
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    Active Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    nice write up, i plan on doing a nice little service to my car next oil change
    plugs, gear oil, complete sea foam, oil change, and maybe control arm switch
    Scott
    I don't even have an audi....i just love me some 'zine
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Jan 10 2007
    2005 A4 USP
    Ashburn, VA
    Just a note on choosing between a copper and irridium plug. The coppers are 3-4 times cheaper, but the irridiums will last 5-6 times longer...so even though coppers are cheaper to buy, the irridiums are the better value overall. I have ran both the plugs below and did not notice a difference in performance, smoothness, idling, ect. Got about 5k out of the coppers, 30k out of the irridiums.
    NGK BKR7E (Copper)
    2005 B6 A4 Ultrasport 1.8TQ6M
    USP CLUB MEMBER #46
    GIAC FX | Stasis Streetsports | 345mm Brakes | 034 DV | Carbonio | Podi | Forge | APR
    Feb 01 2008
    Miami
    I ran the NGK BKR6Es in my VR6 on low boost and fouled them allll the time which wasnt surprising. I have the BKR8Es now and they have been awesome. Probably need to change them every couple of months but it takes all of five minutes so no big deal.
    || Britalman Quad tip || Custom Britalman downpipe || H&RCoilovers|| 19" HRE 540R || Hardwired Valetine One || Two tone Alcantara seats|| Podi Boost gauge||
    ||DTM front/Rear||S6 LEDS||VR6 12V Precision GTS 76 w/ 6spd swap 427AWHP low boost tune for now||
    Active Member Three Rings Jay-Bee's Avatar
    Feb 25 2011
    North Alberta
    That's what I went with on the BKR6E plugs I swapped in. The plugs I pulled out were OEM, probably in there since it was built 92K kms ago! Gap was well over 0.035 and they had hard white deposits on them.
    Made a very noticeable difference obviously.
    -Jon
    2007 A4 Avant 2.0TQM
    Senior Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Great write-up.
    Bosch F5DP0R for me. Really happy with those.
    This thread should be sticky
    A4 B7 1.8T 20v Quattro Project
    powered by ToM's Garage and Etuners
    Mike
    Active Member Four Rings Gil2.0T's Avatar
    Oct 11 2010
    Tampa, FL
    Im going to change mine. I bought the car with 48 and it has 57 now. Who knows when the last time they were changed is.
    F.T.W.L.T.B.D.W.I.C.T.W.
    \ Liquid Blue Metallic B7 \
    Non-Sline Club Member: 007
    Active Member Three Rings vhstejskal's Avatar
    Feb 01 2011
    UT
    Quote Originally Posted by Doctor View Post
    ^2
    Jan 03 2007
    NNJ
    [ 2007 ] SLOWHTE
    [ 2005 ] RAVEN R1
    [ 2001 ] TT COUPE
    Senior Member Three Rings makav3li's Avatar
    May 06 2010
    Ellsworth AFB, SD
    impressive, very informative i wont lie
    Selling Nogoro blue Alcantara door panels. Will fit b6/b7 a4/s4/rs4. In great condition, originally wanted $600 shipped but dropped price to $500 shipped. Check my classifieds for pictures. I want these gone, will include extra door clips if requested. PM me if you want pictures of them installed or anything else I want these gone so make me an offer and we'll talk.
    Mar 07 2011
    Just posting so that I can refer back to this in the future. Thanks for all of the info.
    Active Member Three Rings yayjohnny's Avatar
    Jan 18 2011
    Audi A4 B7
    Central Valley, CA (NorCal)
    Awesome write up, should throw these into the Tech section or else they eventually die off and only to be found via search function :(
    05.5 B7 - Quartz Grey
    APR Stage II - K&N Drop In - Piston DV "D"
    DTM Front w/ Fogs :: Non S-Line RS4 Grille :: 18" BBS RC :: H&R Sport Springs :: Deval Trunk Spoiler :: RAI HFC & Downpipe to Stock Pipes with Magnaflow Mufflers :: LEDs (Interior and License Plate)
    Senior Member Two Rings matthewb2795's Avatar
    Mar 13 2010
    2005 Buell XB12s
    Michigan
    Great write-up! Maybe include something about gapping.
    -2007 Brilliant Black Audi A4 Titanium S-line, 6-Speed-
    STaSIS SS Coilovers / RS4 Rear Sway Bar / Podi Electric Boost Gauge / APR Tune / 034 Turbo Inlet Pipe /18" RS4 Reps (previous owner's mistake, looking to fix this soon)/ H&R TRAK+ Spacers 15f, 20r - Final ET 27f, 22r
    Seeking OEM B7, or B8 Ti wheels, PM me!
    Jan 03 2007
    NNJ
    [ 2007 ] SLOWHTE
    [ 2005 ] RAVEN R1
    [ 2001 ] TT COUPE
    Mar 13 2010
    2005 Buell XB12s
    Michigan
    Great, thanks for the info!
    I put in Bosch 101905631H at the end of the summer. They were pre-gapped to .028. I think I will gap them to .032 this weekend.
    Veteran Member Four Rings Dangler's Avatar
    Dear Mr. Stokes
    I currently have just a carboner intake, exhaust, and GAIC Chip.
    I want to run the NGK Coppers, Currently i have the iridiums, and dont mind changing them more often.
    what is the exact NGK's you use. or better yet, what would you say works best for my setup.
    I also plan on doing rai's test pipe and downpipe. and may one day use my 100oct file that i have, but never have used.
    From you're favorite 1/2 Pinoy.
    Dangler.
    PRIME MOTORING
    Jul 08 2010
    tucson
    danbury
    i vote this, b7 kevin's gear oil change diy, and my post about information about wheels to be moved into the b7 tech section
    Scott
    Jan 03 2007
    NNJ
    Quote Originally Posted by Dangler View Post
    Dear Mr. Stokes
    Dangler.
    NGK BKR7E (copper) gapped to 0.032" - I use the exact same spark plugs on my set-up and change them every oil change (3-5k miles).
    [ 2007 ] SLOWHTE
    [ 2005 ] RAVEN R1
    [ 2001 ] TT COUPE
    Registered Member One Ring g60_corrado_91's Avatar
    Apr 14 2011
    IL
    I wish I had seen this thread before posting in the other one. One more question for you kristokes. What plugs did you have before the BKR7E's? Or maybe to better rephrase it, did you ever have the BKR7IE's and then make the switch to the BKR7E's?
    - Matthew
    2006 VW GTI
    Active Member Four Rings Mc Suly's Avatar
    Aug 20 2010
    UPS TRUCK/AUDI B7
    MONTREAL, QC, CANADA
    NICEEEEE JOB!
    Black is beautiful
    APR HPFP|AWE FMIC|AWE Exhaust|RAI Motorsport 3"DP/HFC|145Bar Rail Valve|Stasis Coilovers|Meth Injection Kit|RS4 Rear Sway Bar|JHM SS|034 STUDS|S4 BBK|STOPTECH SS LINES
    Unitronic: Stage 2 HPFP
    Flat White Enkei PF01
    Montreal Audi Club
    Jan 03 2007
    NNJ
    Quote Originally Posted by g60_corrado_91 View Post
    Prior to using NGK BKR7E (copper), I used the factory Bosch spark plugs until my first oil change at approx. 5k miles. Since then, I've been using BKR7E and replacing them every oil change..
    [ 2007 ] SLOWHTE
    [ 2005 ] RAVEN R1
    [ 2001 ] TT COUPE
    Senior Member Four Rings eastwick897's Avatar
    Jun 26 2008
    New Jersey
    Excellent write up! The B7 forum can use more of these technical posts.
    B7 A4.... 394awhp
    Apr 14 2011
    IL
    Cool, thanks for the info. I actually installed the BKR7E's on Saturday. The engine seems to run a little smoother, but that may be because they're brand new as well. Still, once in awhile, my old NGK BKR7EIX's would cause the engine to misfire for 5 seconds on a cold start. They were all gapped at .032" so I don't know why they were doing that. My original set of BKR7EIX's never caused misfires like that until they had 40k on them. Then at wide open throttle at about 2500rpm (full boost), I'd get one misfire. It was due to the buildup on the plugs though.
    Here are some pictures.
    - Matthew
    2006 VW GTI
    Registered Member Two Rings
    Feb 09 2011
    Waddell az
    I have a 2006 audi a4 non s line with 54k miles. I decided to change the spark plugs and put in the new Pulstar Iridium Series. After I installed them I started the car and it sounded a bit weird like a little knocking sound and I figured the engine is adjusting to the new supposed bigger spark. So I put it in drive and went down the street all of a sudden the car started to jerk and shutter and the check engine light came on. So I went back and checked all of the plugs and they looked fine and the coils were switched and it still did the same thing. Long story short I put back in the stock plugs and car works like a gem. Any comments or suggestions? I was thinking maybe they weren't spaced correctly but they came straight from pulstar.
    Jan 03 2007
    NNJ
    ^ It sounds like your new spark plugs are incorrectly gapped. Purchase a spark plug gapper from your local auto parts store and check the gap on your Pulstar spark plugs.
    Spark plug gapper:
    [ 2007 ] SLOWHTE
    [ 2005 ] RAVEN R1
    [ 2001 ] TT COUPE
    Jul 08 2010
    tucson
    danbury
    just an fyi anyone planning on running these plugs
    factory gaps them at .030
    Scott
    Mar 07 2011
    Every thing in this thread made sense to me until I read this thread.
    http://www.golfmk5.com/forums/showthread.php?t=135855
    Help me I'm confused
    Stage 2 Banner Advertiser Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Linden, NJ
    I know I have a 1.8T, but I swear by the Bosch F5DPOR's. I won't use anything else
    Matt Kapuscinski
    EuropaParts.com, Your Trusted Audi Parts Source
    Phone: 201.777.0005
    Email: matt@europaparts.com
    Twitter: Specials & Discounts
    Help us track our Audizine sales: Enter "MATVEJ" at checkout
    Apr 14 2011
    IL
    Quote Originally Posted by ajax2112 View Post
    I've had both the stock plugs, the iridium one step colder NGK's, and now the copper one step colder NGK's. I did notice a slightly better idle with the NGK iridium's and coppers over the stock plugs, but otherwise, the performance was about the same. I'm on that forum A LOT (over 15k posts) and I've seen people say similar things. Some of my buddies stick with the factory plugs even on K04'd 2.0T's. Either way, IMO it's not a huge difference with the slightly colder plugs, but it's not hurting anything so I stick with them. FWIW, I used them in -15 degree weather with no problems starting or anything.
    - Matthew
    2006 VW GTI
    Active Member Two Rings br8ker21's Avatar
    Aug 10 2009
    Philadelphia
    Awesome tech write! Now time to replace my plugs!
    07 Audi A4 2.0T Tip Quattro S-Line: Titanium Package, Premium package
    Stage I APR | Adam's Rotor's | StopTech Pads | CityLight /Fog | Diverter Valve - Rev D | RS4 Sway Bar | Snub Mount | Vag'd
    Senior Member Four Rings Operator's Avatar
    Feb 06 2009
    Audi A4, Mit. Montero, Escort
    Wellington, CO/Cheyenne, WY
    Changed mine out, a couple days ago. Since then all sorts of strange happenings................. Car doesn't want to start up each time, sometimes one turn others 3-4. Exhaust is smelling pretty foul, and intermittently I'm getting smoke from the exhaust yesterday it was a thick cloud of white smoke, today not as thick, but still smoke present. A simple drive around the block has the car studdering, and possibly going into limp mod (not sure about limp mode as I don't truly know all that goes into it) Before, I changed the plugs to the 7E's I had a few misfire codes. I attributed them to my plugs since the dealership changed out all 4 coils packs last year. Anyone experience coil packs going bad after just over a year? Pretty sure they are gapped right. Any thoughts?
    I plan on dropping it off with my tuner, but any info is welcome.
    K0R-GT Maestro tuned
    Info:
    Build
    History
    Mar 26 2007
    Colorado
    I am putting one step colder NGK in my car next week.... Hope it helps my start up problems
    I ran seafoam through my gas tank about 2 fill ups ago, so that might have had an affect on my stock plugs
    A Fully Catless JHM tuned S4.....
