Results 1 to 22 of 22
    Feb 14 2011
    Leeds England
    Cluster Dial Color Change
    I've changed the colour of my dials again so I thought I'd do a write up for those of you who are brave/stupid enough to have a go!
    First thing you need to do before anything else is take a picture of how your dials are now.
    Tools needed are T10 and T20 torx driver, flat screwdriver, tweezers, soldering iron and solder, solder sucker is handy but not needed. I get my LED's from Farnel but I'm not sure if they have a distibuter across the pond.
    Step one...Remove the dials...
    Pull off the blanking plate that sits between the buttons on the front of your clocks. This will reveal two T20 torx screws. Undo these then pull or push the dials out. Its sometimes easier to remove the fuse box cover and push them out from the back.
    Step two... Stripping the dials down!
    Lay the dials on a soft surface on their front. This will reveal 4 T10 screws. Undo these and the back cover will come off...
    Next you need to remove the front. Just unclip the tabs around the screen...
    You will now see 4 sets of blue wires. All these need unplugging then the dials will drop out..
    The two smaller dials will be left in place. These simply pop out using a screwdriver...
    Now the needles need to be removed. I've found the best way to do this is to use two teaspoons opposite each other. Place these under the base of the needle and push down gently...
    After a bit of gentle persualsion the needles will come away so that you can now remove the dial covers. This will reveal a white plastic section that also needs removing. Undo the two metal clips over the LCD displays at the bottom of the clocks (leave the centre display alone) then prize out the connecting tabs and it will come away from the circuit board. You should now have something looking like this..
    There are 5 LED's for each of the larger dials and just one for each of the smaller that need replacing. Each LED is a PLCC2 and is a nice easy unit to work with.
    You can see the LED's that have been changed illuminated here..
    Step 3... Soldering!
    Each LED has a small notch out of the corner. Its best to mark up where the notch is using a marker pen so you don't get your new ones the wrong way round. De solder the old LED and then re solder in your new LED ONE AT A TIME. This way you have much less chance of getting any the wrong way round. Use tweezers to hold the LED in position as they are far too small to be accurate using your fingers.
    To chech you have done the job properly, its best to plug your dials back into the car and test before fitting everything back together. I have also changed my needles to white. I can do a seperate write up on that if anybody is interested.
    Step 4... put it back together.
    Once you have soldered in all your new LED's and tested you need to put it all back together. Remember the picture you took at the start. This is where that comes in handy. Look at where your needles used to rest and resit them in the same position. Re clip and screw everything back together. Put the dials back in the car and wait for the dark to arrive!
    Last edited by kristokes; 04-23-2011 at 09:25 PM. Reason: Approved for B7A4 Tech sub-forum
    Senior Member Three Rings makav3li's Avatar
    May 06 2010
    Ellsworth AFB, SD
    god damn thats sexy as hell man, i wish i had the balls to do this, i may just have to muster enough nut sack to give this a shot, good writeup man
    Selling Nogoro blue Alcantara door panels. Will fit b6/b7 a4/s4/rs4. In great condition, originally wanted $600 shipped but dropped price to $500 shipped. Check my classifieds for pictures. I want these gone, will include extra door clips if requested. PM me if you want pictures of them installed or anything else I want these gone so make me an offer and we'll talk.
    Senior Member Four Rings BASARAB's Avatar
    Mar 01 2010
    2004 Audi A4, 2004 Saab 9-3
    Farmington Hills,Mi
    well done, thanks for DIY
    R.I.P DG B6. Apr stage 1+,710n DV,Podi boost gauge,e-codes,hardwired escort 8500 x50,single mass flywheel clutch,icelink ipod integration,rns-e
    Stage 2 Banner Advertiser Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    I should have never clicked to read this thread
    Now I want to make my backlighting VW blue
    iPhone 4/4S Vapor aluminum case sale! $40 shipped! -> click here for details
    Active Member Three Rings yayjohnny's Avatar
    Jan 18 2011
    Audi A4 B7
    Central Valley, CA (NorCal)
    Wow, nice!
    Put this in the tech sub-forum! gogo
    Good writeup
    05.5 B7 - Quartz Grey
    APR Stage II - K&N Drop In - Piston DV "D"
    DTM Front w/ Fogs :: Non S-Line RS4 Grille :: 18" BBS RC :: H&R Sport Springs :: Deval Trunk Spoiler :: RAI HFC & Downpipe to Stock Pipes with Magnaflow Mufflers :: LEDs (Interior and License Plate)
    Senior Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    2006 Audi S4
    NYC / Long Island, NY
    Nice DIY, but damn, too much fooking around for me, but it's a nice step towards the extra "touch"
    ____________________________________________
    Current: Brilliant Black 2006 Audi S4 tip / JHM Tuned
    Past: RIP Brilliant Black 2006 A4 2.0T quattro tiptronic
    My for sale ads: Clicky Here
    Senior Member Three Rings XCELR8's Avatar
    Jan 23 2008
    NW Indiana
    How much to ship to England, switch, and ship mine back lol
    Enkei Raijin/H&R Sports/Tint/De-badge/No Wink/Needle Sweep/Lap Timer/Ambers Off
    Active Member Two Rings rjkotler's Avatar
    Jul 09 2010
    2007 A4 2.0T Q 6MT
    Annapolis, MD, USA
    This reminds me of the B5 S4 all red dash. Very cool.
    Good DIY but it might be a bit involved for me to do on my own.
    Jan 23 2008
    NW Indiana
    Wish I could find a spare cluster I could try it on instead of messing up mine.
    Registered User Three Rings ADV.1 Matt's Avatar
    Mar 03 2011
    Miami, FL
    Excellent DIY! Thanks for the writeup!
    Feb 14 2011
    Leeds England
    No probs guys.
    Can't be too much to ship to england!!!
    Jan 23 2008
    NW Indiana
    If I found an extra dash I'd send it to you for conversion :)
    Senior Member Three Rings Boxmods360's Avatar
    Jan 14 2010
    refrigerator, tools, Audi
    Tampa - Florida
    White needles FTW!
    2008 A4 2.0T Quartz Grey - Vag-com - TSW Croft 19" 8.5F 9.5B - 10" Alpine Type R sub w/ PDX-M6 amp in a custom made fiberglass box - AUX mod - smoked reflectors - Plasti dip grill & window trim- 5000K Fogs - Red LED interior - Homemade Carbon Fiber trim - 640 mod - REVO ST1 - APR carbonio - OEM Xenon headlights w/ Phil's LED w/ 6000k Headlights
    My CF trim
    Active Member Four Rings Mc Suly's Avatar
    Aug 20 2010
    UPS TRUCK/AUDI B7
    MONTREAL, QC, CANADA
    NOICE DIY!!!
    Looks really good all red.
    White needles = sexy.
    Black is beautiful
    APR HPFP|AWE FMIC|AWE Exhaust|RAI Motorsport 3"DP/HFC|145Bar Rail Valve|Stasis Coilovers|Meth Injection Kit|RS4 Rear Sway Bar|JHM SS|034 STUDS|S4 BBK|STOPTECH SS LINES
    Unitronic: Stage 2 HPFP
    Flat White Enkei PF01
    Montreal Audi Club
    Feb 14 2011
    Leeds England
    Couple more pics for those interested. The colour looks rubbish but it's just the poor camera on the iPhone 4.
    Needles!
    Clocks at dawn..
    Close up...
    I really need to get a decent camera!
    Senior Member Three Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey Finest
    Impressive DIY & Love the white needles!
    how long did this take you to do btw?
    Sean
    The New
    B7---BBS--DDM--StaSIS SS--EBC GreenStuff --034--more in the werks
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
    Senior Member Four Rings DRAKLORE's Avatar
    Oct 14 2009
    '81 Mk1 VW CADDY rabbit :-) yamaha fz6r
    Robins AFB, GA
    Awesome awesome awesome ! I will be doing this lol
    -Shane Drake
    DRAKLORE/VAST PERFORMANCE BAT B7A4 Built & Tuned
    DRAKLOREs Build
    VAST PERFORMANCE.com
    The Original Hipster B7 \[•]-[•]/
    Active Member Two Rings BMT62688's Avatar
    Oct 12 2010
    2008 A4 2007 ZZR600
    Pittsburgh
    I am looking to do this to my gauges soon but I also want to do the needles I seen you said you could do a separate write up for them if people needed you to I assume you never made one because I can't find one I was wondering are they the same LEDs and what's different about changing them
    Active Member Two Rings jvis08's Avatar
    Jan 23 2011
    East Bay Area, CA
    Quote Originally Posted by BMT62688 View Post
    I changed the background led's for the needles to a bright white as the stock ones were too dim. I used some acetone and gently rubbed off the reddish coloring on the back of the needles and painted it with a white luminescent paint that i bought off of ebay made for the needles.
    2008 Audi A4 2.0t Quattro MT
    -APR Stg 2 and Carbonio CAI -Diverter Valve 'D" revision -AWE FMIC -034 motorsports HFC, Street Density motor mounts, Track density Trans mount, Catch Can and wheel studs -JHM Short Shifter -Adams 'Drill/Drill/Slot' Rotors F&R w/ Hawk Ceramic Pads -ECS snub mount, 7mm rear spacers and Stainless Steel Brake Lines -Stasis Catback Exhaust -VMR V701 18"x8.5, Falken PT722 235/40-18 -H&R Sport Springs
    Senior Member Four Rings airbornerifleman's Avatar
    May 20 2008
    87 Monte Carlo SS
    Toronto Ontario, Canada
    OP: Looks good. Where did you buy the LEDs?
    I will be getting someone to replace my chime speaker in the cluster (the one for lights, keys and warnings. Not the one for seatbelt). While the cluster is apart I wouldn’t mind getting it modded. I really like the VW blue, but with everything else being lit red, would the blue look out of place? I know for a fact (Army) that RED is the best color for night vision and blue is one of the worst. I wouldn’t mind making the dials RED and the needles white like the OP. The guy that is doing the work for me said he might be able to just put a filter behind the dials instead of changing the LEDs. I will post the results here.
    Questions to everyone, what color would you get? :
    Needle color?
    Dial color?
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2
    OEM+ FTW
    Carbon Clean At 155500 KM
    Active Member Four Rings CorneliusRox's Avatar
    Jul 19 2011
    Warrenville, Chicago, IL
    Quote Originally Posted by airborneriflema View Post
    Needle color?
    Dial color?
    So is the needle clear when there are no LED's on it?
    Also I am interested in where you got the LED's. OEM Audi, just from different things on the dash?
    2008 A4 6MT, Quattro, VAST Stage1 Tune, Cupra R Lip, VAGCOMed, Hawk Pads, RNS-E, 10f/15r Spacers, Eyelids, Black Vinyl, RevD DV, JOM C/O's - 24.75" FTG, 255/35-18 Ventus V12's, 80000miles+
    359awhp/K03-GT
    Thumper - 97 12V Cummins
    Lady Killer - 03 600rr
    Active Member Three Rings Ed Gein's Avatar
    Sep 21 2011
    is nonexistant
    Location, Location!
    i really want to do white needles with vw blue dials
    2008 Ocean Blue A4, Turbo, AWD
    REVO stage 2|2.5" test pipe|B8 DV|K&N drop in|NewSouth boost gauge
