Results 1 to 20 of 20
    Established Member Two Rings Bobbyru's Avatar
    Sep 30 2010
    2011 S4, 1988 Porsche Carrera, 2001 A4, 2011 A4, 1974 TVR 2500M
    Morristown, NJ
    Items for Sale
    WD-40 Cleaned my Aluminum trim like new
    I have a silver 2004 S4 Avant with Aluminum roof rails that were milky and spotted looking.
    Tried everything to clean it.
    Can't remember who previously posted this information but well worth repeating....WD-40 made it look like brand new!
    Thank you Audizine forum members...great exchange of information.
    BTW, if anyone is interested I'm cleaning it up and selling this car starting next week.
    Just bought a new Ibis White 2011 S4.
    Established Member Two Rings Merlin00069's Avatar
    Nov 24 2010
    Miami, Fl
    Quote Originally Posted by Bobbyru View Post
    Pics please. I'd like to try also.
    Senior Member Three Rings poop_on_jdm's Avatar
    Apr 22 2009
    Newport News, VA
    WD-40 does wonders on so much especially when it comes to cleaning. I use it at my work to clean up stainless steel and it shines it up real nice
    Account Terminated Four Rings
    Jul 04 2009
    2009 B8 Aruba Blue (discontiuned) 2.0T
    would WD-40 work on exhaust tips also?
    Nov 24 2010
    Miami, Fl
    Just did this. Worked exceptionally well. Lets see how long it lasts and how often i have to do it. Looks brand new. And yes it worked for my exhaust also.
    Active Member Two Rings s_car_go's Avatar
    Nov 23 2009
    Wisconsin
    I've used this on the exhaust tips and it worked great.
    http://www.amazon.com/Eagle-One-1035.../dp/B000CNBI1A
    Established Member Two Rings Sebap3's Avatar
    Sep 22 2010
    B7 S4
    Brooklyn
    Quote Originally Posted by naemcivic View Post
    I use this http://www.amazon.com/BlueMagic-400-...1888261&sr=1-1 for exhaust tips and it works great. You only need a little to get the exhaust shining like new. I bought a can like 6 years ago and still have more than half left.
    2007 S4: SB/Black, 6 Speed, (2011 LED) Nav, DTM Trunk lip, TT-S Steering wheel, (RS4 shifter, brake handle, pedals), KW V3 coilovers, 034 Adj. Control arms, Hotchkis RS4 F/R sway bars, VMR 713 w/ Michelin PSS, RS4 Magnaflow, Piggies, 60% H.O. Ceramic tint, Carbon fiber valance, HID Fogs, Led: plate, interior, tail lights. E-Code head lights, LED city & DRLs, Deval CF Splitter, JHM tune, Apikol rear diff. mount, JHM SS, JHM LW F/R rotors with Stoptech pads.
    Senior Member Two Rings JayNYS4's Avatar
    Oct 06 2006
    New York
    Quote Originally Posted by s_car_go View Post
    I use the same. :)
    2006 B7 S4 Dolphin Gray
    2004 Infiniti G35 Coupe 6MT [SOLD]
    Veteran Member Four Rings SquiddyB6S4's Avatar
    Apr 24 2010
    B6S4, CD5, Gen4 T4R, NA8 aka ugly track slut
    Teh!cks-us
    Petroleum jelly also works to shine many things Especially plastic parts. The petroleum distillates in these products help clean, and the oils in them help keep further corrosion/oxidation at bay.
    -Jason
    2004 B6S4 6MT - Apikol Snub Mount, Piggie Pipes, Magnaflow Cat-Back, JHM Tune with Launch Assist, Squid Rear LSD #01 20lb wheels + Michelin PSS
    2013 Veloster Turbo 6MT - For sale
    1996 Miata - DE car; every moving part new or rebuilt, almost stock
    1995 Accord Wagon - Beautiful, stock, DD Duty, trip-mobile, track day support wagon
    LifeWithSquid
    Veteran Member Three Rings feelgood156's Avatar
    Dec 01 2010
    San Diego
    Quote Originally Posted by SquiddyB6S4 View Post
    would it work on taking wax off plastic pieces?
    ibis white S4 avant | piggies | stasis catback | jhm tune | pss9s
    Veteran Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    Anyone else tried this? Any pics of before or after. I'm at the point where I'm about to vinyl wrap my chrome trim b/c I'm sick and tired of how it looks.
    Current: 996TT
    Sold but not forgotten: 2005.5 S4 MT6 l JHM Parts: Stg 1 S/C, LTH, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I.Exhaust l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Chicago, IL
    If the oxidation is heavy, WD40 won't work.
    now: 2011.5 BMW M3 sedan ZCP
    past: 2005 Audi S4 sedan, 2011 Audi S4 sedan
    Registered Member Four Rings B6JoeS4's Avatar
    Sep 13 2008
    Chicago NW Burbs
    Quote Originally Posted by feelgood156 View Post
    use peanut butter to remove wax of plastic. im not kidding it works. it's an 'ol detailers trick
    Also, the OP said he cleaned his roof rails which are bare aluminum as far as i know. this wd-40 trick will NOT work on the window trim. this is because the window trim is clear-coated and the aluminum oxidizes under the clear coat. to remove the oxidation on the window trim, you must first strip/sand away that clear coat and then polish and re-clear it. or just leave it bare and polish as needed
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Quote Originally Posted by B6JoeS4 View Post
    giving that a try soon, my window seals are all waxed up >:(!
    Apr 24 2009
    Chicago, IL
    What you're doing is using oil to remove oil. This is an old cosmetics trick.
    Apr 24 2010
    Teh!cks-us
    Okay, to correct what I'm 99% sure is misinformation of various sorts:
    The aluminum trim on this car, and indeed many, many cars on the road, is not "clear coated". A clear coat typically implies a paint of some sort. The aluminum trim is anodized with a clear layer. This is why it lasts so well, this is why it's so hard to remove the finish and get to polishing, and this is why it looks like it does when it starts wearing out. The clear anodized layer is very hard, which makes it hard to remove. But the material underneath is thin, so going at it rough is necessary, but it takes a sharp eye to know when you've removed the anodized layer and have started removing aluminum. And the microcracks in the anodized layer are why it looks like it does when it starts looking bad. You may put some surface treatment on it, like an oil, to help fill the cracks, but the cracks are still going to be there. The only real, honest fixes are to replace the trim with new or used in good shape (very expensive), strip the anodized layer and reanodize (very expensive), strip the anodized layer, polish, and seal with something less permanent than anodizing (high-maintenance), or continue applying bandaids.
    Now, maybe the band-aid method works for a long time, and that would be great, as I'm sure many of us have or will have this problem before long, but I'm just preparing you for the long term. Pretty much all shiny trim pieces these days are aluminum, not chrome, and are hard anodized clear, and not "clear coated" with some form of paint or sealant.
    -Jason
    LifeWithSquid
    Apr 24 2009
    Chicago, IL
    Probably easier to just remove the clear anodizing and let it be bare metal. It would require some regular maintenance (polishing), however, or it will tarnish.
    Dec 24 2009
    UK
    WD40 and fine grit wet and dry sandpaper. I used to polish my motocross exhaust with it and it came up like a mirror.
    Use gloves though, that black residue crap stains, especially your nails
    Established Member Two Rings Moisesa4's Avatar
    Jul 14 2010
    2006 VW Touareg v6
    Central Jersey
    sweet
    Oct 26 2009
    S4, TR6, J10, X5
    va
    funny, the day before you posted this I was washing my avant and commented to myself about the hard water stains on the anodized trim and rails.
    and I remembered that wd40 thread you make mention of. I remember it because the guy was kind of abrasive in his 'I know best' sort of tone about it. but he did.
    After reading your post I went out and hit it with a rag and some wd40... and viola... like brand new. no elbow-grease... just wipe it down.
    If you don't have it all ready, go buy a $4 can of WD40 and try it for yourself. yeah, you'll probably have to go over it every month, but who cares it take literally 45 second to go over all the trim. It even cleaned up my side mirror caps.
