Results 1 to 23 of 23
    Jan 16 2007
    1994 Single Turbo RX7
    Los Gatos, CA
    2000 Audi Stage 3 S4
    It has been a good run with the Audi, but I've decided I am actively going to look to sell the car. I have had this car since September 2009 as my daily driver and it is a great car. I am purchasing a home soon and I do not need a 400awhp+ daily driver anymore. Looking at the Classifieds, Stage 3 S4's are ranging from $15,000-$17,000. I will have the car priced to sell at $13,999 FIRM.
    CAR IS NOW PRICED AT $12,999 OBO
    Many on this forum can vouch for my car.
    Cons:
    Needs new sparkplugs and/or coilpacks as it misfires when going WOT - FIXED 4/16/11 with new spark plugs
    Slight body damage that can be seen in video - Not noticeable unless pointed out/up close.
    VIDEO: http://s42.photobucket.com/albums/e3...=VIDEO0035.mp4
    2000 Audi S4
    ~104,xxx miles on the chassis, motor and transmission
    KO4's X 2
    RS4 Inlet pipes
    Ceramic coated exhaust manifolds
    Autospeed Fueling kit (60 # injs, 85mm maf)
    APR Bipipe
    Bosch 044 fuel pump w/ drop in basket
    X1 Carbon fiber intake
    ER intercoolers
    Piggy Pipes
    VAST kevlar clutch
    OEM Resurfaced Flywheel
    RS4 pressure plate
    RS4 Engine Mounts
    RS4 Tranny Mounts
    Snub mount
    OEM Febi Control arm and tie rod end kit
    Borla Exhaust
    710N Div. valves
    DMH cutouts pre cat.
    ST Coilovers
    Drilled and slotted Rotors
    Stoptech brake pads
    RS4 Grill
    Following has about 15K on it:
    New ABS module
    New valve cover gaskets X 2
    New F hose
    New Hitachi MAF sensor
    New N75 Valve
    New 710 N diverter Valves
    New Oil Temp Sensor
    New Coolant temp sensor
    New waterpump
    New cam tensioner seal.
    New Coilpacks X 6
    New ignition amplifiers X 2
    New timing belt
    New accessory belt
    New Fuel Filter
    New Fuel Supply line
    New Fuel Pressure Regulator
    Interior:
    Podi steering column gauge holder
    Vei Boost gauge
    Carbon fabric interior trim
    Remote switch for DMH cutout activation
    Current Cars:
    1997 Dodge Viper: Hennessey 500 Package - 440rwhp/460rwtq
    2012 Mazdaspeed3: Stage 1
    Past Cars:
    2000 Miata:
    1990 Miata: T28 Turbo
    1994 RX7: A-Spec 500R Single Turbo
    2000 S4: Stage 3
    2005 GTO: Headers, cam, suspension, wheels, etc - 423rwhp/387rwtq
    1994 RX7: All bolt-ons for stock twin turbos, suspension, wheels, etc - 320rwhp/290rwtq
    May 31 2009
    CA. USA
    Items for Sale
    Stock wheels, stock brakes, OEM downpipes (piggies), and the year (2000) will prevent you from getting $15k for the car, unfortunately.
    SOLD: B5 S4 Tial 770s with meth @652hp
    Current: B8 S4 Stage 2 034 tuned; RS5 bbk, STs, Xpipe, RocEuro; HRE P40s
    Jan 16 2007
    Los Gatos, CA
    The car is not priced at $15,000. Don't know where you are getting that. Price dropped from $14,499 to $13,999 FIRM.
    Current Cars:
    Past Cars:
    2000 Miata:
    2000 S4: Stage 3
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Items for Sale
    Quote Originally Posted by HardHitter View Post
    well when he posted that comment the price was $14,999
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Jan 16 2007
    Los Gatos, CA
    Quote Originally Posted by BlkdoutA4 View Post
    Don't believe my price was ever $14,999. It started at $14,499. Likely confused the 4 for another 9.
    Current Cars:
    Past Cars:
    2000 Miata:
    2000 S4: Stage 3
    May 31 2009
    CA. USA
    Items for Sale
    I could swear it was $15k when I posted the comment but maybe I misread it, it has happened before. Anyways, good luck with the sale Brian. Hopefully it goes to another good owner.
    Jan 16 2007
    Los Gatos, CA
    Car now pulls 100% at WOT and no misfiring. Replaced the spark plugs today with new ones
    New (left) vs Old (Right)
    OLD PLUGS:
    Current Cars:
    Past Cars:
    2000 Miata:
    2000 S4: Stage 3
    May 31 2009
    CA. USA
    Items for Sale
    You actually put the Bosch 4 plugs in the car?? I am glad to hear they at least fixed your misfiring problem.
    Jan 16 2007
    Los Gatos, CA
    Bosch FR5DTC. Brian's running them and he runs Stage 3 + meth and he's had no problems. It got the job done so I'm not complaining.
    What are you running? the NGKs?
    Previous plugs were NGK BKR7E's
    Current Cars:
    Past Cars:
    2000 Miata:
    2000 S4: Stage 3
    Jan 16 2007
    Los Gatos, CA
    Bump
    Current Cars:
    Past Cars:
    2000 Miata:
    2000 S4: Stage 3
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Items for Sale
    Quote Originally Posted by 97B518TQM View Post
    They are Bosch Tri-Electrodes and I have had good luck with them so far.. car pulls super smooth at WOT. Dan@JHM ran them in his RS6 car with no issues as well.
    May 31 2009
    CA. USA
    Items for Sale
    I thought these were the junk Bosch 4 plugs they sell at Kragen. My bad.
    Jan 16 2007
    Los Gatos, CA
    Bump - Car now has 105,XXX miles and still pulling strong.
    Current Cars:
    Past Cars:
    2000 Miata:
    2000 S4: Stage 3
    Jan 16 2007
    Los Gatos, CA
    Still up for sale
    Current Cars:
    Past Cars:
    2000 Miata:
    2000 S4: Stage 3
    Jan 16 2007
    Los Gatos, CA
    Current Cars:
    Past Cars:
    2000 Miata:
    2000 S4: Stage 3
    Jan 16 2007
    Los Gatos, CA
    Bump to get sold!
    Current Cars:
    Past Cars:
    2000 Miata:
    2000 S4: Stage 3
    Jan 16 2007
    Los Gatos, CA
    A lot of interest for this. Bump back up for a local sale
    Current Cars:
    Past Cars:
    2000 Miata:
    2000 S4: Stage 3
    Jan 16 2007
    Los Gatos, CA
    Still for sale
    Current Cars:
    Past Cars:
    2000 Miata:
    2000 S4: Stage 3
    Jan 16 2007
    Los Gatos, CA
    Bump
    Current Cars:
    Past Cars:
    2000 Miata:
    2000 S4: Stage 3
    Jan 16 2007
    Los Gatos, CA
    SOLD - Thanks Audizine
    Current Cars:
    Past Cars:
    2000 Miata:
    2000 S4: Stage 3
    May 31 2009
    CA. USA
    Items for Sale
    Wow, it's gone?? Was it a decent person that purchased it or some wacky kid that will destroy it in a month? I hope it went to a good home and you got good money for it.
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 24 2008
    2000 S4, 2001 roush stg 2
    Santa cruz
    shows how much we can get for the b5s4. I'm willing to bet it was someone that is new to s4's though. All the beat unserviced ones bring the market down.
    So 034 tuned 605s??? Do tell!
    May 31 2009
    CA. USA
    Items for Sale
    Quote Originally Posted by awd2ks4 View Post
    Haha, soon :). It's all coming together nicely. I am working on my 4 piston rear brake kit right now so that is causing some delays.
