Hey everyone. Finally put my motor back in my car after two years of being apart. Before I pulled the motor (2.8 30V), it was running really rough, rpm bounce everytime it gets up to 1500ish rpm, then clears up after that. I figured it was a timing issue.
While the motor was out, the following parts were replaced:
-Clutch (southbend stage 3)
-Flywheel (singal mass billet)
-Timing belt, water pump, thermostat, idlers, and tensioner
-motor, trans and snub mount
Got it back in yesterday. Same rpm bounce. ABS light on solid, e-brake light flashing. Also once I get the rpm above the bounce range from 1500-2000 rpm, it feels like the throttle wont go above 30%.
All the reading I've done is pointing to the ABS module, but for some reason I can't communicate with the ECU... I've also heard that the ABS module can effect other modules downstream and choke them out, but I thought the ECU would be upstream from the ABS module.
Should I disconnect the ABS module and see if I can re-gain communication to the ECU?
Any help would be appreciated.
