Page 11 of 15 FirstFirst ... 910111213 ... LastLast
Results 401 to 440 of 571
  1. #401
    Jan 11 2007
    SLC,UT
    Yeah, I was thinking more along the lines of upgrading the springs, or if one is not upgrading the springs, then not having to disassemble at all, just plop them on.
    ** GT2860R-7 S4 Build Log--
    FOR SALE (click me):
    --FIKSE FM10 - 3pc LIGHTWEIGHT WHEELS - 17x9 et55 & 17X8 et57 - 5x130 - WORK ON AUDI W/ ADAPTER**
    --JHM DELRIN SHIFTER STABILIZER BUSHING (LATE STYLE)**
    --RS4 AIRBOX--
    LOOKING FOR:
    --BROKEN SPIDER HOSES
  2. #402
    yeah I don't be upgrading the springs with the stock exhaust valves, it seems that is a no-no for sure which can cause failure.
    Again for the rev limit I am going to set/keep I doubt it would be doing me any good to upgrade.
    I did find a set of heads locally though, so that is good news.
  3. #403
    Jan 25 2006
    Audi S4 2.7T, A4 2.0T
    MD
    Quote Originally Posted by NOTORIOUS VR View Post
    Well I can't really say for sure about the failure rate of the stock sodium filled exhaust valves, but you rarely hear of failures in stock heads so why would it be any different in the 2.8 heads if my revlimit stays the same at 7200 rpm?
    That's my thinking anyway.
    Sent from my phone via the interwebs
    They failed on Guruman's first 28rs setup..
  4. #404
    Jun 21 2005
    B6 Avant
    Milton, Ontario, Canada
    I hear the 2013 R35 GTR is getting sodium-filled valves. Just sayin'
  5. #405
    Quote Originally Posted by Don Supreme View Post
    He had uprated springs on the stock sodium valves
  6. #406
    Senior Member Four Rings TweetsS4Estate's Avatar
    Mar 30 2008
    Rocheste MI -> NYC April 1st
    I ran upgraded springs on stock valves.. If you want to keep it sock, just keep it simple. You will never want to spin it past 7k anyways... E85 will help it come in faster with more timing. You will love it! ... Assuming that's what you're doing..
    Big thanks to jason@AMD
  7. #407
    Quote Originally Posted by TweetsS4Estate View Post
    I will one day run E85, it's just not available up here without pulling a mission so it's not on the priority list yet.
    Simple is the name of the game for sure.
    slight porting on the 2.8 heads (more just cleaning then porting), transfer exhaust valves and springs from 2.7 heads, new lifters and valve stem seals, lap the valves into the existing seats and that is it.
    Rev limit will stay as it is now @ 7200 rpm (maybe go to 7300 RPM is need be for shifting, etc).
  8. #408
    Mar 30 2008
    I don't think you will want to spin it to 7300.. honestly. Even now, look at your logs, you run out of steam after 6700. I'd shift at 7k
  9. #409
    Jan 11 2007
    SLC,UT
    Quote Originally Posted by SleeperAvant View Post
    I"m not talking about the technology, rather hearing of specific instances with Audi sodium filled valves.
    --RS4 AIRBOX--
    LOOKING FOR:
  10. #410
    Stage 3 Forum Advertiser Four Rings Max@034's Avatar
    Jan 13 2009
    Fremont, CA
    Alright boys and girls... time to start collecting parts...
    The shopping list:
    X ATQ/AHA heads
    - Rods
    - ER or AMD SMICs
    - RS4 Airbox (top)
    - RS4 Y-pipe (maybe, might just have one made out of aluminum instead)
    - Extra IM for modding (porting and increased plenum volume)
    - 3" DPs to new exhaust system (either dual 3" or single 3.5", still undecided)
    - 2.0T coil conversion
    - 710N DV's
    - V8 rear brake upgrade parts
    - HPX MAF and housing
    Make sure you hit me up Sascha. About the ER's too.
    Also, having now disassembled a bunch of 2.7 and 2.8L heads, they've had the EXACT same valves. I've yet to see this so-called difference, and I think you are doing way to much work to just swap over to stock valves. Inconel aren't very expensive in the long run, and if you are swapping valves, you'll probably need to redo the guides anyways.
  11. #411
    I would take my current logs with a grain of salt...
    Quote Originally Posted by Max@034 View Post
    For sure I will Max.
    As for the valves, I am almost certain they are a different part no. in ETKA.. I will have to look again though to be sure.
  12. #412
    Jan 13 2009
    Fremont, CA
    It is a different part number in ETKA, but not in physical construction from what I've seen. Like your logs, take what I say with a grain of salt; Audi is famous for changing production runs mid model year without telling a single soul. But we've disassembled a fair amount and they've been identical in their construction, material, etc. There are also more then a few instances of folks running the stock 2.8L valves without issue on big turbo cars.
    However, I think it is time for me to cut a 2.7L valve in half, and cut a 2.8L valve in half, to finally put this to rest!
    You only need 12 exhaust valves, inconel are like $30 or less each.
  13. #413
    That would be a very interesting test Max..
    I also don't see what the whole hoopla is about with the "sodium filled" valves... look @ how many VR6's are boosted on stock hardware not to mention countless other European cars that were originally NA that are boosted with stock parts. You're right I might just leave the valves in provided they're not bent (the heads are coming from an accident car).
  14. #414
    Veteran Member Four Rings Issam@INA's Avatar
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    I'll keep that in mind, but I am trying to souce the heads locally first as shipping the heads will be pretty expensive on it's own. AMC has a set of heads FS at this very time, but like said shipping costs
    Rods are not on the list because I think the bottom end is strong enough as it is.
    Not building the heads wither, just going to do a slight port job and refresh all the seals, replace the lifters and drop in the 2.7 head exhaust valves.
    AMC heads are the chinese replica units .
    Danny has some 2.8 heads as well and I have a pair here if you want. Let me know if you need any help.
    INA Engineering Inc.
    APR distributor FOR OTTAWA | HULL | GATINEAU | HULL | KINGSTON
    THE NEW VR6 B5/B6 FAQ
    Email US | Facebook US | Call US : +1.510.275.4775
  15. #415
    Senior Member Four Rings Mantis's Avatar
    Aug 04 2007
    I honestly didn't know that there were replica heads available.
    I don't think I care anymore
  16. #416
    Feb 26 2006
    Earth
    Quote Originally Posted by Mantis View Post
    AMC is a Spanish company that manufactures OEM replacement heads for alot of different brands (not sure if its the same AMC Sascha is talking about) but when you get the box it says "made in spain" but thats the box... ;)
    the heads are manufactured in China (and you can see them plaguing ebay).
    Your best bet to ensure a good head is obviously to look @ the casting for the made in germany stamp. AMC heads wont have a stamp on the heads - just the OEM part # (for identification purposes).
  17. #417
    Jan 11 2007
    SLC,UT
    You learn something new everyday. The AMC he's talking about is forum member AMC, I'm pretty sure.
    I've got some 2.7 and 2.8 valves, maybe next time I'm at the shop I'll dremel some in half ha.
    But yeah, that's basically what I was saying, taking the heads completely apart just to put other stock hardware that isn't necessarily any better seems like wasted effort IMO. If you do want to take them apart, go a tiny bit big (aftermarket exhaust valves) or go to your grandmother's house.
    --RS4 AIRBOX--
    LOOKING FOR:
  18. #418
    Feb 26 2006
    Earth
    OEM valvespring & retainers accompanied with intake valves are great
    just change the exhaust valves really.
  19. #419
    Veteran Member Three Rings fatezero's Avatar
    Feb 12 2004
    EPL Tial 605 S4 Avant, 2011 S4, 2001 A4 Avant K04
    Orange County, CA
    There is no difference between the 2.8 exhaust valves and the 2.7. You will be 100% fine Sascha, without a doubt! I know people running 600+hp on bone stock original 2.8 heads without any issues...for years now
    2001 S4 Avant 3L Tial 770
    2004 Allroad 6spd EPL Stg 3
    2001.5 S4 Avant AWE/GIAC Stg 3
    2011 S4 6spd Suzuka Grey Pearl with GIAC Stg 1
    2006 S4 Avant SOLD
    2001.5 A4 Avant K04/Jeff Moss Hammer File SOLD
    2001 Porsche 996 Turbo - SOLD
    2001.5 S4 AMS Stg 3 - SOLD
  20. #420
    thanks Adam, good to know that you're in agreement with Max...
    So then now I just have to hope all the valves are good in the heads!
  21. #421
    Mar 30 2008
    I guess you will see what I'm talking about when you put it together. Good luck with it all!
  22. #422
    Just FYI, my FMIC setup with custom piping is for sale... everything you need to put the FMIC on your car is included.
    PM me for info, will be posting in the classifieds soon.
  23. #423
    Senior Member Three Rings Cadiburns's Avatar
    Feb 17 2010
    Chicago
    ERs or AMDs?
    B5 Casa S4 Avant | Tial 605s | EPL | Aquamist
  24. #424
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    If you do upgraded exhaust valves, do ferrea and not SUPERTECH inconel. A bunch of 1.8T guys have learned this all too well
  25. #425
    Quote Originally Posted by Cadiburns View Post
    ERs or AMDs?
    ER's
    Probably won't though, stock will do just fine for my 7200-300 rpm limit.
    Sent from my thingamabob over the internetz....
  26. #426
    scratch that FMIC is SOLD
  27. #427
    Oh HAI!
    Thanks to Max...
  28. #428
    Jun 14 2007
    Connecticut
    Sick! Wash out the metal shavings
    VAST Performance Stage 3 B5 S4 | Videos
  29. #429
    I'll make sure they're spick and span inside and out.
    Sent from... you don't even wanna know.
  30. #430
  31. #431
    Senior Member Three Rings Jason:addict's Avatar
    Oct 14 2007
    01.5 S4, 86 4KQ, 83 UrQ, 04 Cayenne S
    Woodinville,WA
    Quote Originally Posted by fatezero View Post
    Just for the record guys while both are sodium filled the 2.7 valves have a lower keeper groove location which preloads the spring more at installed height. This is done because there is pressure in the exhaust manifold on the turbo set-up.
    Audi Tuning Hatemonger
  32. #432
    Quote Originally Posted by Jason:addict View Post
    good info Jason, thanks...
    so in your opinion it is still worth while to swap in 2.7T ex. valves to the 2.8 heads?
  33. #433
    Oct 14 2007
    Woodinville,WA
    I use Supertech solid stainless exhaust valves - they're cheap and won't break. Stock intakes.
  34. #434
    Alright I'll keep that in mind
  35. #435
    Today I finally got around to installing my ER's that I got from Max... after a few people posting that they're such a pain in the ass to install I was expecting more, but they went in without a hitch.. little to no mods needed and got it the old FMIC out and the ER's in, in under 3 hours.
    I'll be honest.. I was expecting more... people talking about pressure drop and all that jazz, but I noticed no increase in boost at all after switching to ER's.... I'll have to wait until the weather gets warmer to take some logs that I can compare to but from what I can tell there is no difference between my FMIC setup and now the ER's except that the car is even more stealth now with no pipes showing through the grills.
    Would I do it again, go from FMIC to ER's? Probably not unless I see a huge difference in temps which I also doubt I will see.
    Anyway on to some pics...
    ER's...
    Buddy stopped by w/ his 996T:
    How I mounted the dryer...
    ER's installed...
    Driver side...
    Pass. side...
    Clearance between dryer and IC... lots of room...
  36. #436
    Feb 12 2004
    Orange County, CA
    You are not going to see a huge difference in temps if its just one run in the winter. Where the ER's shine is multiple back to back runs and IAT's in the summer. It takes a lot of heat to get them heat soaked
    2006 S4 Avant SOLD
  37. #437
    For sure... But many were also always saying how much the fmic has pressure drop and the ER's have very little. So I was expecting to see at least something in terms of increase in boost. But nada.
    Sent from my Galaxy Nexus using Tapatalk
  38. #438
    Dec 14 2008
    Finland
    Soooo many times has it been mentioned they are "identical" and yet they arent... Here's pics just for the record how much they differ. Rosten exhaust valve vs N/A (from 2.4 head but the same as 2.8)
    N/A exhaust valve
    Rosten Stainless (same dimension as S4)
    Now the question:
    Exhaust springs are also different (intake springs are the same) according to part numbers from ETKA but how they are different and can they take the extra pressure and heat?
  39. #439
    Jan 11 2007
    SLC,UT
    The MAP sensor is post intercooler, so the 'increased boost' would be the decreased pressure drop across the IC's, meaning that the turbos don't have to work so hard for a given requested boost.
    --RS4 AIRBOX--
    LOOKING FOR:
  40. #440
    Quote Originally Posted by jibberjive View Post
    I'm running a fixed DC on the N75... and it's reference is from the compressor covers of the turbos. I should have seen more boost if there was a larger pressure drop
