Page 1 of 15 12311 ... LastLast
Results 1 to 40 of 571
    NOTORIOUS VR's Stock 2.7T TiAL S605 Build
    For future updates look here: http://schnell-engineering.com/blog/
    Well today is the day things start to happen....
    Started @ 2pm.... working by myself, so I'm taking it slow since I never pulled a motor from an S4 before... RONDAL's thread has been my goto thread for pics of tricky situations like the damn AC compressor , took me almost an hour to find the 3rd bolt in the rear, but after that it's been pretty smooth...
    Front end is off...
    Damn AC compressor finally out...
    The engine harness all pulled and such form the firewall and tied to the top of the motor... Power steering, fuel and evap lines all disconnected as well.
    at that point did a few more small things like disconnected the heater core, took out the axle bolts from the hubs... and then decided it was break time and went to get a good old Combo #1 from McD's.... and create this thread...
    Next up, get the axles out completely then drop the exhaust from the DP's and drop the drive shaft, shift linkage and loosen all the mounts. Hopefully by then I'll be able to lift the motor and pull it out a bit to get the slave and anything else in the way out and get the motor out onto a pallet by tonight. Might have to wait till a buddy will come by for that not sure if I feel like risking to break anything by trying to pull the motor on my own.
    Active Member Three Rings csosnowski's Avatar
    Sep 05 2010
    00 A4 Avant 1.8TQM, 77 Chevy 4x4 454, 88 Pathfinder
    Bend, Oregon
    looks good man, keep the photos comin. always love a good engine pull/build thread. keeps me inspired.
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - APR Stuff, Piggies, Darintake, 710N's, 034 Track density stuff, Vogtland - GONE
    2000 A4 Avant Sport 1.8TQM - Silver - Black - GIAC, Darintake, H&R / Bilstien
    russianguy.2007 - "Oh tight! thats the S4, A-Line"
    Senior Member Two Rings Fiyacracka's Avatar
    Feb 13 2008
    Where in toronto are you doing this??? Sounds exciting!
    Senior Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Looks good notorious. That's good news. Keep the updates.
    Senior Member Four Rings gearhead1186's Avatar
    Mar 17 2009
    02 S4, 06 GTO, 69 Camaro, 73 Cuda, 68 Torino
    Queens, NY
    excellent. subscribed.
    Veteran Member Three Rings RusS4's Avatar
    Nov 14 2006
    2000 Audi S4,1980 VW Caddy,05 R1
    VA
    I have the same setup you have and you are going to love it man. It pulls like a freight train just off the base tune. Whose fueling kit did you go with. I went with EPL and it is going great.
    Tial 605's EPL Tuned
    Lots of other goodies.
    Veteran Member Three Rings michael66899's Avatar
    Oct 26 2006
    00 S4, 01.5 S4
    WA
    Looks like fun, should be sweet set up. Are you going to tune it all yourself? Also I wouldn't worry too much about actually pulling the motor out yourself, there isn't too much you can mess up. I've done it numerous times, in and out by myself no problem.
    - 00 Nogaro S4 - Single Turbo Project / 01.5 - Silver S4 - Stg. 3 / Five other B5s that have all been sold
    -Girodisc-BW EFR-Fikse-AMD-Stoptech-Stasis-034-JHM-Stern-Neuspeed-Dahlback-Eurogear-CPP-Group 2-
    WWU Formula SAE - 600cc's and 450lbs = Lots of fun
    Quote Originally Posted by Fiyacracka View Post
    Mississauga... Dixe/Derry area.
    Minor update since I have to clean up my hands and replace the broken gloves before dropping the shifter... it's like real time updates LOL
    Exhaust is out, and Drive shaft is disconnected....
    Time to go drop the shifter and undo the axles from the tranny... tune in for more updates
    Quote Originally Posted by RusS4 View Post
    I'll be self-tuning actually
    Quote Originally Posted by michael66899 View Post
    Yeah, but I'll be using a forklift so a little more finesse will be required.... We'll see how I feel about it lol.
    Jun 24 2010
    NICE!
    glad to hear i can help.
    if you have questions shoot me a PM
    Out she comes!
    Safe and sound..
    Senior Member Three Rings tosh2.7's Avatar
    Sep 12 2009
    stg 3- 00' S4 GF 2010 civic
    new york
    looking good
    Vast tested. Driver approved
    Hi my name is Ray and I'm a douche bag
    R_DSheridan on twitter: Get at me
    Active Member Three Rings Angular's Avatar
    Oct 25 2010
    2002 S4 Avant
    Area code 253 (WA)
    Quote Originally Posted by NOTORIOUS VR View Post
    That is absolutely my plan for next month when I start ripping apart my S4. Now I have a feeling I'll be referencing this thread as well.
    For taking it slow, you're making incredible progress! Nice work.
    Jun 24 2010
    i wish i had a forklift..........and a heated shop
    Senior Member Three Rings Vegas34's Avatar
    Mar 04 2008
    2001.5 Nogaro/Alcantara/6speed
    Kansas City
    Quote Originally Posted by csosnowski View Post
    Ditto, I need to do it soon and threads like this help my shitty motivation to be less shitty. Looks good man
    Rob B. - Kansas City, MO
    2001.5 Nogaro S4 | 6 speed | Alcantara | DD with no major mods
    2008 A4 2.0T | Wife's car
    1998 A4 Avant Tip 210k | Work Car
    Senior Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5 S4 stage 3
    ky
    bro, youve bragged for so long about your hot stage 2 setup. im so happy to see you ready to go stage 3. im so prepped to see the outcome. gl..
    stage 3+ dyno-tuned by EPL
    AWE smic, OEM RS6's, CM Fx850 twin
    JHM ss, linkage, DTS, Devils Own Meth
    034 anchors everywhere, custom 4" single
    www.teameurotrash.com
    Active Member Two Rings yuriy's Avatar
    Jun 18 2010
    Nice, looking forward to seeing the finished product.
    Ive seen you around a few times, beautiful car man.
    01 Casablanca White 1.8t 5 Speed APR Chipped, 3" Test Pipe , Cone filter+ Heat shield, Forge Splitter, GodSpeed FMIC.
    Sep 10 2010
    Woody Ontario
    Starting this exact same build this week, will be referring to this thread as well/shoot you some questions if they arise.
    Last update for the day.... tomorrow it's back to business though!
    Driver side turbo out:
    DS Turdbo (actually still looks good and no excessive play:
    As RONDAL said, you will be cursing every known word to get this stupid 19mm out... agghhhhh!!!
    Passenger side out:
    PS Turdbo (also looks good with no play):
    I have no idea why my turbo(s) sounded like they did, they really seem fine in regards to play and all the fins are there with little to no chipping... strange... but on to bigger and better things!
    Quote Originally Posted by Angular View Post
    I'm not doing too many detailed steps because if you really need help RONDAL's thread is pretty much all you will need along with some common sense and patience.
    Quote Originally Posted by RONDAL View Post
    Yeah I hear ya, working in a cold garage is no fun. Been there done that many times, so I feel your pain man!
    Quote Originally Posted by bigern45 View Post
    hehehe... well I had to be proud of what I had... but now it's time to show what a 2.7T can really do
    Jun 24 2010
    some of these pictures take me back haha.
    god those bolts SUCK
    Senior Member Three Rings judeisnotobscur's Avatar
    Apr 22 2009
    --2001 s4 **
    nj
    You are so lucky, access to a shop and forklift. I have a dirt driveway and i hate rolling around in the dirt.
    good luck.
    Timing is Everything
    //J-Fonz tuned b5 s4
    Senior Member Four Rings mikehawk666's Avatar
    May 17 2010
    Colorado
    making great time, good luck should be a beast.
    stg3- iy b5s4
    slow mk2 gli
    WTB (ONE)b5s4 rear vmaxx coilover& spanner tool (shot in the dark I know, USPS lost one of my rears in the mail) PM me!
    WTB85mm MAF
    Active Member Three Rings Dutchsider's Avatar
    Aug 19 2010
    NEPA
    Nice work Notorious. You get things done quick. Detailed pics certainly aren't necessary as Rondal's thread is hard to top. The forklift lift certainly is interesting. Have fun cleaning up all of those heat shields and the bay :)
    Senior Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Black 2001 Audi S4 6MT
    Toronto, ON, Canada
    Very nice - good luck with everything!
    Brilliant Black 2001 S4 - 6MT <3
    3" Gutted Vibrant Catback | X34 Intake | Stern Soft Engine Mounts | JHM SS | 710N's | 17" RS6 Wheels | AWE Boost Gauge
    Registered Member Two Rings philly-s4's Avatar
    Jan 15 2011
    Philly
    This looks awesome!!! Good luck and can't wait to see more updates.
    Senior Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    00 6MT S4, 04 6MT Cooper 'S'
    Toronto, Canada
    NVR, I'm surprised you are going Stage III, you had one of the strongest Stg II+ cars out there.
    I guess this means you aren't selling any more?
    What's your ETA for this? I'll be in Mississauga next Sunday if you are still at it.
    Mar 18 2010
    Ottawa
    Hmmm, this might require a trip to the GTA to see a Tial 605 car. Good job, sounds like a relatively painless process.
    Are you using the Maestro software to tune?
    Jun 14 2007
    Connecticut
    Nice man, good luck with the project.. Can't wait to see your results.
    How many miles on your engine?
    VAST Performance Stage 3 B5 S4 | Videos
    Sep 12 2009
    new york
    I really cant wait to see the number you pull out of your ass with your tune on theses babies. GL meng
    Quote Originally Posted by CONTROL ONE View Post
    Don't be surprised... Stage II will only hold you off so long until you get the itch
    I pulled the car off the market a long time ago when I realized that all I was going to do is give away my car that is really clean and needs nothing and buy someone elses headache lol.
    Quote Originally Posted by Ribbie View Post
    Nope... pure tuning with WinOLS or tunerpro.
    Under 93k Miles on the engine/chassis.
    Quote Originally Posted by tosh2.7 View Post
    Once I fully break in the clutch and get my tune some what dialed in I will hop on the dyno for all to see
    Senior Member Three Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    Good luck with the build! Looks like you know what your doing !
    Pm'd you
    Current: S4 Avant by Mihnea 386whp
    Sold: M3 E46 SMGII ESS VT450 S/C 380whp
    Senior Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Parts
    Your Computer Screen
    Those 19mm bolts can go to hell!!!
    Quote Originally Posted by Audi_S4 View Post
    Pm'd you
    Replied
    Quote Originally Posted by DiscoPotato View Post
    Yes, yes they can. How my friend changed his K03's for K04's without taking the motor out after seeing what kind of f*$kery is needed to get that one bolt out is boggling my mind.
    Senior Member Three Rings DonnieDark0's Avatar
    Mar 02 2009
    bs 54
    north america
    this thread is awesome! dude goodluck and the progress looks great! Bookmarked along with RONDALS thread.
    ACE
    CELison - "would you rather go fast or have your car look stupid when you park?" - hahahaha
    Sep 19 2008
    Toronto, Canada
    How do you like that new Molson beer? Saw it on sale at the Beer Store on Friday.
    Molson M is actually very good... smooth and doesn't bloat you
    Senior Member Three Rings s4nicetry's Avatar
    Nov 29 2007
    02 S4, 99 A41.8tq
    Calgary
    Interesting to see you dropped the whole shifter box, saves you from the PITA of realigning everything though. You should replace the spider hose while everything is out if you haven't already and double and triple check all the turbo's fittings are torqued down before you drop the engine back in. Looks good though just take your time and it will all work out nicely, and polish up that engine bay.
    Senior Member Three Rings flyingfish2626's Avatar
    Nov 23 2008
    2000 Chevy S10 ZR2
    Colorado
    Good luck with the build....Tial 605's FTW!
    2008 A4 Avant Spec. Ed/Ibis/Oynx/Sport/6-speed
    2001.5 S4 Avant/Pearl/Oynx/Tial 605/6-speed......Sold
