Results 1 to 12 of 12
    Mar 10 2011
    Mesquite, TX
    Won't start, starts, won't start.
    Okay. The other day I start to head to work and the car won't start (kinda sputters and tries to start but won't stay running). I took the truck and when I got home tried to start it again. It did the same thing but I lightly pumped the pedal like it was a carb'd motor and got it to run. I had to keep the motor at 2K+ rpm otherwise it would do the sputter and die thing again. After holding it there for about a minute I slowly let the rpms drift down to normal and it idled out at about 850rpm (normally about 950rpm). I took it around the block and it ran fine. I got back and shut it off and then restarted it and it fired right up. This morning I went to start it and it won't start again. Same symptoms. It kicks over well and doesn't show a CEL. The car was running fine when I parked it initially and then the starting issue just showed up. Any ideas? The gas gauge says 3/8 of a tank but I've heard there were some issues with gas gauge accuracy with some of the audis so I'm going to get some gas and see if that is the problem.
    2001 Audi A4 Avant 1.8T Tiptronic
    2001 VW Jetta TDI 5spd
    Mar 10 2009
    il
    I do not know what it specifically would be called, but on my car I replaced the Engine Speed Sensor when I had symptoms exactly like yours. The problem I believe is these sensors go out intermittently for some time before they crap out completely. What makes it more difficult is the code shows up and gets erased when your car doesn't start/starts.
    Mar 11 2011
    N.E. Ohio
    I would start with changing your coolant temp sensor, they are only $12-15 and easy to change.
    could be this sensor, or could be the crank sensor but usually the car stalls and won't run when it gets warm. also could just be bad gas, best to check and pull some codes.
    Mar 10 2011
    Mesquite, TX
    Well I got it start again. Still no CEL. I've unhooked the MAF to see if it would run in limp mode but there wasn't any change. I don't see how it could be bad gas since I've put over 200 miles on this tank. I wish I could pull any codes that might not cause a CEL but no VAGCOM here. I'll see if any of the local stores have a coolant temp sensor.
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    I'm going to have to second the engine speed sensor aka crank position sensor.
    Ive seen this happen quite a few times and its ended up being the culprit.
    We have replacements available for the 2.7T, 2.8 and 3.0 models
    Jason
    Veteran Member Four Rings A6Avant's Avatar
    Mar 09 2010
    T4 Eurovan 2.5L 5spd (Currently under construction). MKII Jetta (GLI in the making :)
    Salmon Arm , B.C. CANADA
    I third the above comments regarding the crank piston sensor...
    HOWEVER.... The last time I had thins happen it actually turned out to be my cat fell apart internally and a piece became wedge and did not allow proper flow.... no cell but that was the issue. Gently tap on your cats and see if there is any movement...
    Mar 10 2011
    Mesquite, TX
    Well I replaced the coolant sensor and the car started up just fine but since it was still warm from when I got it running again this evening I'll hold off on saying it's fixed until tomorrow morning. Hopefully that's it so I don't have to spring for the crank position sensor. If I do I'll definitely be taking a look at the ECS stuff.
    Senior Member Two Rings SpooldYou's Avatar
    Jul 17 2007
    2005 s4 IMOLA 01 a6 2.7T (daily) Vespa Scooter w/ Jet Engine. (1.9 FATS)
    Boston
    If you have access to VAG COM or similar unit. Check the on board computer diagnostics. It'll give you a real time reading of what your cars doing. Mainly it'll tell you your outgoing coolant temp and voltage. and Crank position sensor voltage too. Cross check with Bentley manuals to ensure everything is ok.
    Mar 10 2011
    Mesquite, TX
    Coolant temperature sensor was the problem. Car started up great this morning. Thanks for all the replies.
    Mar 30 2011
    Springfield, MO
    I have similar problem: when car is cold it starts right away; and when its warm (after a short trip) i have to crank for 2-3 times before its starts. Once its starts it works fine, I drove over 3k miles with this problem, but it gets annoying. And there are no CEL.
    it is 97 A6 2.8 v12
    Apr 09 2012
    Edmonton/AB/Canada
    Audi A4 2.8L Quatro; Splutters but won't Start, won't Run
    Quote Originally Posted by jschick View Post
    YES!!!
    Coolant Temperature Sensor - was the reason! Changed out (not easy to see or access) but relatively simple to do. Engine started and ran perfectly.
    Tips:
    -You need to remove the Air Supply lines to ACCESS the area between the Block and Firewall (passener side, below a cylindrical canister relay).
    -Tie a thread to the horseshoe shaped spring clip that holds the sensor in the housing, before attempting to reinstall (took 45 minutes to find it when dropped).
    -You can TEST before totally removing old sensor, by connecting the electrical connecter on the new sensor and starting engine. Engine will Start but only run for about 5-10 seconds then will stall. However after reconnecting all Air Supply lines engine should run continuously.
    Thanks Very much for the solution! $32 Cdn was a cheap repair :)
    Sep 25 2009
    B5 A4 2.8q, 2010 Jetta TDI
    Boise
    This thread saved my sanity.... It was so frustrating to have it not starting, then starting and running fine when warm, then finally not starting at all. Coolant temperature sensor was the solution, word to the wise though, if you have to buy one make sure you look at yours first, Autozone and Napa both tried to give me the longer green circular one, and were convinced I was lying, but mine required the short square blue one which I had to get from the dealer($40).
    My tips:
    -You don't necessarily need to remove all the air supply lines, all I removed was the air box and with a bit of contortion I managed to get it out
    -Make absolute sure that you get the original o ring out, its buried aways down in there where you can barely see it, once you get it out put the new o ring in then the sensor and press the sensor firmly with your thumb while you press the retention clip back in. Wiggle lightly to make sure its tight in(you should actually be able to see the retention clip over the sensor) otherwise you'll be out of coolant in minutes.
