Page 2 of 2 FirstFirst 12
Results 41 to 80 of 80
  1. #41
    Registered Member One Ring B72.0Tq's Avatar
    Mar 14 2011
    Right now i run 18x8 OEM S-line wheels with et43 offset fine with no spacers. I bought new rims, 18x8 with et45 offset. The new rims did not clear the brakes in the front so i purchased 5mm spacers thinking they would make the wheels fit correctly. et45 wheels with 5mm spacers make the offset et40 right? Yet the spacers did not help clear my brakes. How do i run et43 offset fine but et45 with 5mm spacers still does not clear my front brakes?
  2. #42
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    Depends on the specific wheel sometimes. Pics of it rubbing?
  3. #43
    Active Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by .Mad Hatter. View Post
    THIS. I was going to make the same comment, this needs to be changed in the above post as I see it far too often and it's simply not the case; diameter of a stretched tire is the same when not stretched.
    example:
    http://www.willtheyfit.com/index.php...&Submit=Submit
    edited to reflect correct misinformation :-D
    Scott
    I don't even have an audi....i just love me some 'zine
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
  4. #44
    May 07 2007
    Word up. Excellent thread by the way, LOTS of great info!
  5. #45
    Jul 08 2010
    tucson
    danbury
    yea im hoping to have it stickied and not lost ya know...i think it can maybe reduce the amount of "will these fit?" threads ya know
    as for certain wheels clearing brakes and not clearing brakes....this is kind of a case by case basis and really depends on the wheel.....for example i am very interested in the linea corse lemans (bbs lm reps cuz im poor) and at et 35 they will not clear the brakes....i think i need a 5-10mmm spacer (5 clears it but very close and anything over 10 is too much poke for me)
    and i know there are wheels out there with et 45 and clear the brake just fine, and thats really up to the spoke/face of the wheel design and whether or not its going to work....but alas, now you know that adding spacers can make it work now its just a matter of playing around with it to see ya kno?
    Scott
  6. #46
    Senior Member Four Rings jimrobbington's Avatar
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    I edited my original post with better representative pictures of ET35, and pictures of rubbing issues with my 245 width tires.
    05.5 A4 2.0T 6spd, REVO Stage 2, Vast Stage 3 clutch, VMR test pipe, custom 2.5" Techtonics exhaust, Borla mufflers, wastegate adjustment, 034 catch can, BKR7E, JHM Short Shifter, KW V1's, 19" V710's, Podi boost gauge, 640 Mod, 18% tint.
    Dyno proven 221 whp/302 wtq!
    Driving Style: Strategic Aggressor
    Eric Paul Young: "I just tore down my old boy and slapped the internals."
  7. #47
    Senior Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B5 A4, B7 A4 2.0T/6mt SLine Ti
    Doylestown, PA
    Great write-up. This needs to get stickied.
    Justin
    2.0T A4 S-Line, Titanium, 6MT
    Brilliant Red
  8. #48
    Registered Member Two Rings
    Sep 30 2010
    Ontario
    can you please add suspension and how much drop you used when posting pictyures?
  9. #49
    Jul 08 2010
    tucson
    danbury
    people have been posting ftg's that should give you an idea
    Scott
  10. #50
    Senior Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
  11. #51
    Active Member Three Rings A4_Ti's Avatar
    Mar 15 2011
    Fantastic writeup and responses
    2007 Audi A4 | 3.2 | S-Line | Titanium | 6MT
  12. #52
    Senior Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria/Calgary, Canada
    Just a suggestion, you may want to add for the noobs that there is a screw at the 12 o'clock position of the front fender that can possibly cause rubbing, and that you can remove this without any ill-effects.
    Other than that, awesome write-up.
    -Cam
    2008 Phantom Black A4 2.0T Quattro Titanium
    REVO / Koni FSD / Eibach Pro / Adam's Rotors / Hawk HPS
    Huper Optik 30 / RS4 Bits / EuroGEAR Carbon Fiber
  13. #53
    Senior Member Four Rings a4darkness's Avatar
    Dec 01 2007
    West Sonoma County <-> SF, CA
    Massive. Effing. Props OP.
    - Thomas - latest pic | Engine Strengthening-Reliability Project | RogueEuro
    -> Revo Stage 1, Forge TIP, ER Sport FMIC, NGK BKR7EIX Plugs, Mitsu Evo DV, Valeo SMFW 228mm Clutch, 034 HFC <-
    WTB: H&R Front or Hotchkis S4 Sways
  14. #54
    Senior Member Four Rings JEENYUS's Avatar
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    this is greatness. i vote for sticky in both the B7 and B6 forum.
    "...definitely tits!!" - old guy
  15. #55
    Active Member Two Rings Philthy's Avatar
    Nov 10 2010
    Wildwood Mo
    Bravo
  16. #56
    Senior Member Three Rings A 4 Awesome's Avatar
    Mar 07 2009
    CA
    Great Write-up!
    Thanks for the extra effort to post this
    Neuspeed * 034 Motorsports * KW V2 * EBC RED * RS4 Rear Sway * "D" * MR118 18x8 * VAG'd and a bunch of other stuff ...
    Non S-Line Club Member:006
  17. #57
    Oct 23 2010
    Va
    After looking at the hot asses thread, I reallly like the widened out look of spacers on the rear tires. However, I do not want to mess with my suspension, get new wheels, or get new tires. Would adding some space to the back be detrimental on an all-stock setup?
  18. #58
    Dec 01 2007
    Quote Originally Posted by Guitarmageddon View Post
    Not at all. And actually, it might improve handling a bit. Just remember a few things... hub-centric spacers, lug nuts to match your wheels (OEM = ball seat) which are appropriately sized length.
  19. #59
    Senior Member Four Rings pw211's Avatar
    Dec 14 2008
    C55 AMG, 90 Passat
    Louisville
    Quote Originally Posted by a4darkness View Post
    Good call. Don't run the risk of running bolts that are too short. Always order longer bolts with new spacers. contact chris@fifteen52, he can get you some spacers and bolts
    Pat
    ///AMG
    F.T.W.L.T.B.D.W.I.C.T.W
    "Stop being so butt hurt" -eskimopunk
    "Gary Coleman's brain cells have more stretch than that set up" -Checho
    "I have a carriage drawn by 780 horses, Clydesdale's to be exact. yeah it boogies." - Dangler
    "My wheels don't fit. Issues: rear rubs, front rubs, i hit everywhere, i break everything :) " - Geoffafa
    trolllololololol
  20. #60
    Senior Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    Quote Originally Posted by A4A4A4 View Post
    mmm this ^ should deff. be added in there
    QG B7 Ti. A4 / S-Line / HID Fogs / Carbonio CAI / ECS Smoked Side Markers / Dark Smoked Side Fender Blinkers / LED License Plate Lights / 034 Turbo Inlet Hose / RS4 Rear Sway Bar / CC + Blackout / LED DRL's / VAG-COM'd / Forge DV / A.W.E Vent Pod Boost Gauge / REVO STG 1
  21. #61
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    2008 Audi A4 Avant SE 2.0T 6spd Titanium Edition
    Fontana, CA
    Awesome write up!
    -Anil
    Garage:
    '98 Integra GS-R Sedan, White/Black
    '08 A4 Avant SE 2.0T, S-Line, Quattro, Manual, Ibis White/Ebony, Titanium (Delivery - June/2008)
  22. #62
    DUH! an Audi
    los angeles, CA
    how did i miss this? why does no one pm me useful links to add to the FAQ! fail on you all
  23. #63
    Jul 08 2010
    tucson
    danbury
    im hoping to get it stickied up next to yours i feel like it would get lost in the faq
    Scott
  24. #64
    DUH! an Audi
    los angeles, CA
    everything gets lost, if we keep referring people to this it will never be forgotten!
  25. #65
    Jan 22 2007
    Fontana, CA
    Quote Originally Posted by Quattro View Post
    I will send you a PM in a second with a link to this thread.
    EDIT: PM Sent. Feel better?
    -Anil
    Garage:
  26. #66
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    Quote Originally Posted by pw211 View Post
    Thx Pat
  27. #67
    New Member One Ring
    Mar 31 2011
    Akron
    Smile
    first.. Great freaking post
    last summer i picked up some Stern St7 wheels for really cheap. they are staggered 18x8.5 front and 18x9.5 back with ET35 both..the tires that are on the wheels are super bad and they need to be replaced. these are the tire sizes that are one the wheels right now 245/40/18 front and 265/35/18 back. this summer i wanna put the wheels on my 00 b5 and i also wanna get coils.. bc i didnt know about the staggered problem on the quattro i picked up some 245/40/18 this winter. now i would like to keep this 245 on the front and i really dont know what to get for the back. i used that calculator and if i use the same tire size 245/40 front and 265/35 back i get -1.6% if i put the 265/35 in the first box and 245/40 in the second box i get 1.0%.. my question is which one is right? as i said i wanna keep the 245/40. the best percentage i could get on that calculator was .3% with 215/45/18 front(1st box) and 245/40/18 back(2nd box).. do you guys think that sounds right?
    sorry for the long post and thanks in advance
  28. #68
    Senior Member Three Rings RJMars's Avatar
    Oct 18 2008
    Minnesota and NJ and MI
    Well done ryanworth Nice look. Are your callipers orange? You ever think of painting your s-line badges' little red part, orange? That would be a cool little touch.
    Great thread OP. I love the clever title, linking your thread to the most epic AZ thread of all time.
    Light Silver Metallic 2005.5 A4 2.0T, Quattro, MT, CPO
    Audi Sport rubber mats | red LED footwell & courtesy lights | pure white LED interior & rear plate lights | BMW Shadowline matte vinyl trim | de-badged | dark smoked blinkers | Brilliant Black S-line valence & mirror housings | City Lights w/ fogs mod | Lamin-X Gunsmoke tails | Cupra Lip | glossy black trunk rings | Bosch Icon wipers | "17 USP wheels w/ Nankang SV-1 snow tires | "18 BBS RX wheels w/ Michelin Pilot Sport PS2's
  29. #69
    Senior Member Four Rings MCT9891's Avatar
    Jul 06 2009
    2011 evo x
    Staten Island, NY
    amazing write up!!
    RIP: '06 2.0T 6MT Stage 3 GT3071R
    Currently Driving: '11 Evo X GSR
  30. #70
    Active Member Two Rings ChipsöfSix's Avatar
    Nov 28 2010
    SomePlace, Ontario, Canada
    Amazing thread! TONS of info for ppl to learn on, Hopefully end tire and suspension threads ( not likely tho ) and awesome pictures! how can you go wrong!
    2008 A4 S-Line 2.0T Quattro 6 Speed / Forge DV /K&N Drop-in/
  31. #71
    Senior Member Three Rings audi8844's Avatar
    Jun 17 2009
    Kent Island, MD
    I was wondering about all of this, and searching brought me here. Wonderful information! This clears up all of my questions... STICKY definitely!! And more member pics with their setups!
    Jordan
    2008 A4 2.0t Quattro - Unitronic Stage 1+, K&N Drop-in, KW V1s, VMR V701 19x8.5, RS4 Rear Sway, 034 Snub, Zimmermans & HPS, Podi Boost
    Nothing else right now... saving up for GTX
  32. #72
    Senior Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    1992 VW GTi 16v
    Miami
    Well let me see if I can help this post out. I have had a few different fitments over the years.
    Current:
    18x9 +24 with a chunky 215/40
    18x10 +18 with a chunky 225/40 *you will need to pull to run this
    -3* camber all around.
    22 7/8" front FTG
    23.5" rear FTG
    This is the rear loaded down. id say about another half inch or so (ideally where i want to sit)
    This was a spacer test fit on the front, FTG is about 23.25 there and the final offset is +14 on my same 18X9 215/40 setup stock front fenders
    This is my fender pull, i did it myself with an eastwood and a hammer. I cut the tab on the quarter panel that folds inward and allows the bumper to screw on to it (not pictured) but luckily enough the bumper doesnt mount where you need to cut, so i didnt need to relocate bumper tabs. once i cut that tab i was able to heat the metal up and bang it out with a rubber mallet to match the pull. the after, i heat flared the bumper to match (sorta)
    after i did this, car went in for repaint and the body shop smoothed out the rear quarters.
    its hard to capture the after effect on camera, because the smoothing consisted of removing the waviness of the pull, not the original crease of the quarter.
    My previous setup
    18x8.5 all around with 205/40 toyo proxes4
    +40 front offset and +32 rear
    FTG here is about 22.75 front and 22.5 rear
    F.T.W.L.T.B.D.W.I.C.T.W.
    pw211: Here's how you calculate a reasonable amount of poke/stretch:
    (Offset and tire size Audizine VMR fanbois recommend + Offset and tire size fafa recommends) / 2
    mr shickadance: i guess the forth category is fafa, his car is so low that he should be in form>function....but he also has a big turbo and breaks his undercarriage like once a week
  33. #73
    Aug 31 2007
    1992 VW GTi 16v
    Miami
    Did a little more messing around tonight with some spacers.
    Pics below are same camber spec and ride height as previous post
    18x9 +17 (previous was +24)
    18x10 +13 (previous was +18)
    Need to get rid of these hankooks. Wayyy to chunky. Theybhaved lasted me forever though. Never have I had almost 30k out of a set of unrotated tires.
    Apologies for the horrific shots. Lighting in my garage sucks and I was forced to use the phones flash.
  34. #74
    Oct 23 2010
    miami
    i rolled up next to you one day in doral, white b7 on LM reps, car looks nice man, im lookin to go lower soon hopefully
  35. #75
    Senior Member Three Rings bloodstar57's Avatar
    May 15 2007
    07 A4 2.0TQM TI, K6 GSXR 750
    Queens, NY
    Cool
  36. #76
    Senior Member Four Rings VegasAIV's Avatar
    Feb 25 2009
    B7 A4
    Las Vegas
    waitin on spacers for front and for rear. 12mm all around.
    Turbo lag is just foreplay...
  37. #77
    Forum Moderator Four Rings kristokes's Avatar
    Jan 03 2007
    NNJ
    Moved.
    Stokes|Moderator - PM me with any questions/concerns
    [ 2007 ] SLOWHTE
    [ 2005 ] RAVEN R1
    [ 2001 ] TT COUPE
  38. #78
    May 11 2011
    Middletown, DE
    Has anyone run a 19x9.5 with a +42 offset? If so what size tire did you run? Fender roll/pull?
  39. #79
    Active Member Three Rings glissoar's Avatar
    Oct 16 2010
    Beach cruiser
    virginia beach
    Quote Originally Posted by surfpunk View Post
    yes I am, I have a 235/35/19 on them and no rubbing at all
  40. #80
    Active Member Two Rings 4Ring's Avatar
    Oct 08 2010
    Sector 9
    so thankful i came across this thread. im hopin this discovery has excluded me from the noobzz lol
    German Engineering
