Results 1 to 13 of 13
    Jul 27 2009
    North Andover, MA
    Symptoms of bad motor mounts
    Specifically, what are the symptoms of either bad motor or tranny mounts? How much vibration could bad mounts cause? What is the life span of the stock ones and how quickly can they go downhill when they go bad?
    Thanks for the info
    2002 A4 1.8t Tiptronic
    APR stage 1+, forge hybrid dv, TT 225 injectors, NGK copper plugs, pro dry filter, test pipe, borla cat back, 35-20% tint
    Oct 06 2008
    Los Angeles, CA
    I second these questions as well
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    Pasadena, CA
    Items for Sale
    Just did a write up on this. Essentially, they probably need to be swapped and certainly if they're leaking.
    http://www.audizine.com/forum/showth...=1#post6287352
    EDIT: Review is a few posts down from this ^^ which should adequately explain most of the differences.
    Thomas
    | Chronicles | Threads | IG
    // A U B A
    Apr 01 2007
    2017 Mustang GT Performance Package, 1983 Chevy Silverado
    houston texas
    if you let off the gas and the shifter knocks around then you probably need to replace your mounts
    2005.5 6 speed with the Premium, Lighting, Sport, and Cold Weather packages
    PPT Brute 144mm rods, Pag Parts Turbo EFR 6758 Turbo kit, Pag Parts custom FMIC (500hp garrett core), Pag Parts custom TIP (retains stock airbox), S3 injectors, RS4 PRV, Modified LPFP, APR HPFP, Water/Meth, Turbosmart kompact 50/50 DV/BOV, Turbosmart IWG actuator, Eurodyne Boost Manger Plus, Eurodyne Tune - Pag Parts
    Senior Member Three Rings Rirruto's Avatar
    Dec 09 2009
    Ocala%2C%20FL
    Quote Originally Posted by dmansr25sd View Post
    Does your car give you a nice massage at idle? If so, you might need motor mounts.
    Quote Originally Posted by texasboy21 View Post
    This too.
    Have you visually checked all of your mounts?
    -Bryan
    05 DG S4 - Lots of JHM goodies.
    Dec 01 2007
    Pasadena, CA
    Items for Sale
    If your B6 has anywhere near 70k, swap em. Done.
    Thomas
    // A U B A
    Sep 15 2010
    massapequa ny
    Items for Sale
    I think my engine mounts are shot. Car has 66k 05 1.8. Should u be able to move engine around with yur hands? I can hold onto engine and move engine a little. I don't think it should be that easy to move?
    Apr 01 2007
    houston texas
    Quote Originally Posted by juttin3 View Post
    R U cereal?
    Dec 01 2007
    Pasadena, CA
    Items for Sale
    Thomas
    // A U B A
    Sep 15 2010
    massapequa ny
    Items for Sale
    Yes I'm cereal. Maybe I should post vid.
    Dec 01 2007
    Pasadena, CA
    Items for Sale
    Smart ass comments as aside, I think that would be an excellent idea. Please do. I'm all on this motor mounts kick. Everyone run out and change them now!
    Thomas
    // A U B A
    Veteran Member Three Rings 1.8Turbo4me!'s Avatar
    Jun 10 2009
    S.F, CA --> Houston, TX
    thomas,
    unless i missed it, but why a b5 s4 motor mount than a b6 a4?
    Dec 01 2007
    Pasadena, CA
    Items for Sale
    For the most part it was cost. There's absolutely zero reason why the B5 S4 MM's can't be used in a B6 A4 and the standard mounts for our cars usually run $80 - $150 each. No muy bueno bitches. Shop smart, shop s-mart.
    Secondly, and only b/c I had no means to confirm it, my assumption is that the MM for a 6cyl Audi engine would be slightly more robust than a 1.8T. Makes sense, right? So, that was also a factor of consideration.
    Now I have no hard evidence to back this theory and have read in buried threads here on AZ saying that there is both no difference and that they're 30-40% stiffer. So, we'll call that one a draw. Still no proof.
    But if there's one thing I've learned about these cars over the years, it's that Audi engineers do make subtitle tweaks here and there between models and their parts so who knows? Maybe there is some validity to it.
    Now that's all niftybeans and whatnot, but the bottom line is that for ~$100, the driving characteristics of my car have been vastly altered for the better. So whatever MM option you choose (standard B6 A4, B5 S4, B5 RS4, or even aftermarket) it'll be a positive difference.
    Thomas
    // A U B A
