Results 1 to 30 of 30
    Feb 07 2008
    00 stg 3 6mt a6, 91 f150 4x4 5mt
    DIY: Headlight Removal, TSXR lenses & Painted Cutoff Shields (Pre-Facelift)
    Here goes. To start with, get some masking tape and tape off your bumper to help prevent scratches.
    Next you will need a t30 socket, a long thin extension, and ideally a tool to magnetize the torx socket. There are 3 bolts to take out the headlight, two on top, and one way down through one of the holes to the left.
    To get a bit more access, I took this solitary screw out of the plastic cover and bent it to the side.
    On the inner side of both headlights, there is a "post" that needs to be pried out of its retaining clip like so -
    Here is a better picture of the clip - the white piece in the picture -
    From here you will maneuver the headlight out of its home, which is not an easy task. This gives you an idea of how to angle the headlight to get it out -
    From here, you will take out the projector by taking out the three 7mm nuts in this picture -
    Ideally you want an extension and a swivel socket like those in the next picture, and magnetic sockets don't hurt either.
    The next part is tricky, what you are going to do is spin the projector assembly around and separate the reflector housing from the fresnel lens assembly. Basically you will take out one of the three screws (T20 I think)and then rotate the whole assembly around until you can get the next one out and so on.
    The lens assembly comes out easy, but the reflector house could only come out at this angle and with a small amount of bending the headlight opening -
    To replace the lenses, you will need to bend the tabs on the housing outward, until the lens and retaining clip slide out. Once you slide the tsxr lens in, bend the tabs back to their original location over the retaining clip.
    To paint the cutoff shields, I did it the easy way. I bought some engine enamel in a can, sprayed it in to an empty soup can, and used a foam brush and did 5-6 coats. Alternatively you can take out the cutoff shields and spray bomb them.
    Once reassembled, it will look something like this from certain angles -
    Reassembled in the headlight housing -
    That's it
    -dre
    Being different means nothing if you don't have taste
    WTB: 2001 4.2 A6 Transmission code FBC
    Veteran Member Four Rings A62TURBO's Avatar
    Apr 18 2007
    I'm still trying to figure out what this mod is suppose to do.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    Greg
    C5UNION
    Feb 07 2008
    Which part? The painting is appearance-only. The lens replacement is supposed to give off a lot better output, and give a sharper cutoff too.
    -dre
    Senior Member Three Rings jmgraham78's Avatar
    Jan 19 2010
    2004 Acura TL, 2000 A6 2.7T MT, 2001 Allroad
    I love lamp?
    Nice work man! The after looks nice...
    2000 A6 2.7MT - currently gutted, a few parts left, PM me if you need anything.
    Senior Member Three Rings patrick23's Avatar
    Dec 09 2009
    2004 Audi A6 S-line, 2001 Nissan Pathfinder SE, 1999 Subaru Legacy Outack Limited
    val-des-monts quebec
    no pics with the lights back on the car?
    04/A6/2.7t/S-line
    STAGE II+ ///
    -Patrick-
    patrick@dipyourcar.com
    http://www.facebook.com/dipyourcarcanada
    Feb 07 2008
    Quote Originally Posted by patrick23 View Post
    My car is immobile in my garage right now :(
    -dre
    Veteran Member Four Rings Nor_Cal_Driver's Avatar
    Jan 03 2005
    Needs a lift
    530, California
    Now why did you paint that? Won't it reduce light output?
    01 S4 Sedan MTM tune
    Gone:
    01 S4 Avant APR tune
    02 A4 3.0 Sport
    01 A4 Celebration Edition GIAC tune
    99 A6 Avant
    Veteran Member Three Rings streetsoffire's Avatar
    Jan 04 2007
    North Jersey/Hawaii
    Great stuff......too bad I'm gonna hafta pay someone to do this.......
    Die Perfekte Verbindung Aus Sportlichkeit Und Asthetik
    C5 S6
    Street
    http://i47.tinypic.com/974oj5.jpg
    Feb 07 2008
    Quote Originally Posted by Nor_Cal_Driver View Post
    Painting is purely an appearance mod.
    Painting the front side doesn't affect light output whatsoever. Some people paint the back side with a matte paint, but I don't see the point.
    -dre
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    2005 allroad & 2004 B6 A4
    Penna
    Looks good man.
    He did not paint the glass. He painted the cut off that sits behind it... the piece that keeps the headlights from blinding oncoming drivers.
    -John
    "get the biggest of everything you can. always. that's a winning combination. everytime. just ask the military." -Dan[FN]WTF
    Senior Member Four Rings Vinchenzo51's Avatar
    Jan 31 2010
    S-Line A6
    East Haven, CT
    ^ correct, the cutoff shield is there to block the light regardless, so painting it is irrelevant in regards to changing the light output
    i did like Dre said and painted mine with matte paint in an attempt to create less blurring/discoloring along the edges of the beam, which i believe i've accomplished (see my thread about this)
    the main idea of this mod is to create a unique looking projector setup, and by changing to clear lenses during this process, you also gain better light output
    04 2.7T S-Line A6 6MT
    (Build Thread) <-Click
    (Featured Article) <-Click
    My Photo Gallery - MyPhotoStash.com <-Click
    Originally Posted by 8520
    You're in high school, and chipping a 2.7t is like poking the bear with a tazer.
    Feb 07 2008
    This.
    -dre
    Active Member Two Rings nm3210's Avatar
    Sep 04 2008
    '99 A6 2.8L
    Haha, maybe you should take a picture from the opposite side of the lens to clear this up for people. I'm afraid that someone is going see your post without reading and paint their lens!
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Quote Originally Posted by nm3210 View Post
    Jan 19 2010
    ^^^ LMAO........ someone will indeed do this...
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Quote Originally Posted by jmgraham78 View Post
    lol and i can't wait to see the aftermath
    if someone modifies their car without actually reading about what they're doing... they deserve what they get lol
    Active Member Two Rings AudiGman's Avatar
    Apr 24 2009
    Minnesota
    Curious, could this same TSXR style lens modification be made to the the driving/fog lights on a pre-facelift A6?
    Tom G
    Feb 07 2008
    Quote Originally Posted by AudiGman View Post
    Tom G
    If you can disassemble the fogs, then yes, you could paint the cutoffs. I remember looking at my foglights before and they seem to be a very sealed enclosure so it might be quite the project.
    -dre
    May 30 2008
    Penna
    Where did you source the TSXR lenses?
    -John
    Feb 07 2008
    Quote Originally Posted by EErie B6 View Post
    theretrofitsource
    -dre
    May 30 2008
    Penna
    theretrofitsource
    -John
    Senior Member Three Rings Debow's Avatar
    Nov 28 2010
    2000 A6 2.7t, 1978 chevy k10, 1956 farmall 140 ; )
    Southington ct
    heres a question? can i just scrap the cut off and just go with out it b.c i think the a6 headlights are not that brite and i have shit for out put and like no arc of light and i have 6000k and 6000x fogs so just courious if i will get more light out of them..
    Feb 07 2008
    Quote Originally Posted by Debow View Post
    No. Without the cutoff, your projectors will effectively be high beams only. It is likely that the finish on your reflector housings is burnt off. Are you using 55w or 35w ballasts?
    -dre
    Nov 28 2010
    Southington ct
    actualy i dont know what ever came stock in a 2000 a6 2.7 does it make a diference because thease lights are bad i usealy have my hi beams on cuz i cant see with my hids probaly wors i have seen and my lenses arent foged or anything
    Veteran Member Four Rings GQ//S4's Avatar
    Jul 25 2007
    VW Touareg V8, '01.5 S4 Stg III, F-150 4x4, (Former '00 S4 6-speed)
    Mukilteo, WA
    If you're running 11 year old bulbs, you're in need of replacements
    - Michael
    Fact: I'm Awesome
    Call my car Bruce Banner, cause its like the freaking Hulk
    My logic is infallible. Always.
    Grammar Nazi #1
    "I'm too close for missiles, I'm switching to guns!!!"
    Senior Member Three Rings allroadstomtl's Avatar
    May 25 2009
    '12 Avant P+, '00 328ci
    Montreal
    I know it's a noob question but what is the difference between A6 to Allroad lenses?
    '12 A4 Avant P+, S-Line 3 Spoke, S-Line Stone Guards, Tints ...
    MontrealAudiClub
    Feb 07 2008
    Quote Originally Posted by allroadstomtl View Post
    No idea honestly.
    Slight update, got these in the car today. No ecu so not output pics yet.
    -dre
    Feb 07 2008
    -dre
    Sep 11 2009
    NE
    I have no concrete data but allroad lights are considered an upgrade to C5 A6 beams since they are better. This is the reason it is almost impossible to obtain used allroad lights for decent price.
    May 25 2009
    Montreal
    Where can I get a set?
    MontrealAudiClub
