YES I think I'm going to pull the trigger on coil over sleeves this summer. Ik i can lower the fronts pretty good but if the rears don't go down that much I'll just shorten the bottom part of my struts. Cheaper than buying coils and will most likely ride better than cheap coils
You're quattro right? I'm going to be working on shortened upper shock/spring mounts, so they will be 2 inches higher. Hopefully it will be something I can sell to people that want to be low with having to completely bottom their coils like I have right now.
Brilliant Black B5 ..... 15k on Street Built Engine
Strictly Pleasure/Zero Clearance/Stretch Your Legs
Alex
Yeah I'm quattro. That's a good idea, I'd send mine to you if you were close but I'd probably just have one of the local weld shops do it for me.
Double DIN swap, pioneer avh4000, TONS of suede, 15% tint, Forge 007, apr/vdo, rs4 grille, GIAC chip, Depo ecodes with 55w 5000k HID's, ST Coilovers, 034 street density motor and trans mounts, 034 snub w/ bracket, 034 aluminum subframe bushings, valeo single mass cluth/flywheel setup, new control arms and axles, evo ms CAI, powderoated snazzy stuff, euro trunk, multi colors, Shaved exhaust cuttout with hidden turn down tips (in progress... again)
Clutch, timing belt, rear main, turbo all replaced at once.
Winter mode :
2000 Santorin A4 1.8TQM, Test pipe/turbo back exhaust/Eibach springs/clear corners/Single mass flywheel/APR Turbo Inlet Pipe
Soon to come : IE Rods/JE pistons/FMIC/maybe even a turbo/wheels/get some head....work done
What fluid did you sacrifice to the pavement gods?
I wish I lived that close to a panera. Mmmm bread bowls.
LOL I didn't even notice that in the picture, good eye! Unfortunately, even though it appears to be within walking distance, I would have to frogger my way across 8 lanes of highway to get there without driving. Meh. The fluid is coolant, Lower radiator hose cracked and popped off the radiator about 4 blocks from my house. Wasn't a bad job to R&R, longest part was driving to MD to get a new one. Incidentally, I had to drive my girlfriend's TT up there and I realized how much I don't like driving it.
I think there is a Panera by my house. What is it they offer? I am thinking of going in there and trying it out, since you mentioned it.
I hate it when my car acts like a little bitch, treating me like the bitch
FS:Brand New K&N Air Filter RU-3700 (3" inlet, 5" base, 4" tall, 4 5/8" top), Brand New 3" Injen (Amsoil) Dry Filter Setup with Heat Shield, Brand New OEM 06A Oil Pump, Used Greddy Intercooler...throw me some offers
