Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 441 to 480 of 534
  1. #441
    Senior Member Four Rings Bische's Avatar
    Jun 03 2009
    '02 1.8TQM Wagon, '96 Ford Mondeo 2.0RS
    Sweden, north
    "I feel I want to like, take the engine [artistic pause, hand gesture] out..."
    As documented earlier in my thread, I dropped the oil pan to change the oil pickup screen as preventive maintenance. Everything was looking good, had no sign of leaks but I noticed I started loosing more oil than before. Previously my car burned like 3/4qt oil between oil changes, OCI about 5-6k(about a year for me), but now I had lost little more than half a qt in 4months..
    So decided to give it a closer look to rule out if it actually leaking or if its burning more oil, everything chacked out good. Then I was to inspect my downpipe while the car was on jackstand already, I found this:
    I does not leak anywhere around the pan seal, check. Oh wait, ITS LEAKING IN THE GOD DAMN WORST PLACE OF ALL! Those pics are shot up where the two oil pan bolts bolts INSIDE the bellhousing.
    I worked hard to do the oil pan and pickup on the jackstands, in my garage, thinking everything was good it turned apeshit on me. I was so angry at this point, I would have smacked anyone in the face.
    Sooo, this was last wednesday I found this out. As I was clearly doing the oilpan again, this time im doing it right. I decided that night to take the engine out to rectify this situation, and doing the oil pan this way, I got the opportunity to doublecheck if my new FX400 had been contanimed + get a good visual inspection of the whole engine before the BT swap.
    No time to waste, started out friday night when the kids went to bed
    Front bumper off, working on the core support and getting the steering cooler off:
    With the core support off, I took off the powersteering pump, AC pump and wiring:
    Pretty good friday night progress, engine 2 bolts away from being pulled.
    Saturday morning, -30*c outside. I managed to get this lovely temp inside the garage:
    Fuck that, I had 2 socks, 2 pants, 3 shirts on and a bag of beer
    Went on, unbolted the sucker and pulled it:
    Bolted it to the engine stand:
    Began with clutch inspection, heres the PP outside:
    Clutch disc, 1000miles 50/50 highway/city, about 90% broken in:
    Clutch disc measured 7.87mm's, a brand new FX400 disc measures 8.03mm's.
    PP inside:
    Flywheel, 19lb steel 240mm:
    No signs of oil contamination on the clutch components =
    Cleaned them up and put it back on with some new loctite on the PP bolts:
    -Bische
    2011: 16.16sec@88mph
    163whp/208wtq
    <Bische's Wagon - The thread>
  2. #442
    Jun 03 2009
    Sweden, north
    Then I flipped the engine and unbolted the oil pan, when I got the last bolt out, the pan fell off the engine. WTF?! Usually you have to pry it off with a big ass screwdriver..
    I have no pics of this, but the "sealant" i used was rock hard, I could get it off with my pinky finger. LOL, I was amazed it didnt leak like a river..
    I recommend using OEM sealant, Victor Reinz Reinzosil VAG part# D 176 404 A2:
    Sealed it back up:
    That was it for saturday, I had a heater blowing on the pan over the night for the sealant to do its thing:
    Sunday started with bolting the engine off the stand and cramming it back in the car:
    All bolted down in the car again:
    Put on the accessories, wiring etc. again, ready for the core support:
    Core support, IC, charge pipes and rebar back on:
    Filled fluids and burping the coolant:
    Phew, productive weekend!
    -Bische
    163whp/208wtq
  3. #443
    Senior Member Four Rings boy412's Avatar
    Jul 15 2007
    2003 A4 Avant 1.8TQM Sport
    Mount Rainier, MD
    You make pulling an engine look like cake! How long did that take you in total?
    RAI | MTM Stage II | DSMIC | Fluidampr | FX400 | Vogtlant GT coilovers | B6 S4 brakes | ER TIP | Forge 007 | STaSIS | Stėrn | Apikol | JHM trio | Podi | OEM+
    2.0L stroker build in progress...
  4. #444
    Jun 03 2009
    Sweden, north
    Quote Originally Posted by boy412 View Post
    It isnt too hard, just ALOT of wrenching.. I think I spent about 20hours, there was a few things that took forever to figure out though. But know when I have done one time I can cut at least 5hours off that time. It took about 5-6hours to get out, worked on it about 8hours and it took 4-5 to get it in and buttoned up alone.
    Figuring how to bolt it to the stand, go get the parts to do it and execute took me a good 3hours. Getting the engine to mate with gearbox without one of those lift blocks the line it up took 1-1.5 hours longer than it should have done.
    -Bische
    163whp/208wtq
  5. #445
    Senior Member Four Rings a4darkness's Avatar
    Dec 01 2007
    West Sonoma County <-> SF, CA
    Your thread is a constant motivator for me to do more with my car. Props man.
    - Thomas - latest pic | Engine Strengthening-Reliability Project | RogueEuro
    -> Revo Stage 1, Forge TIP, ER Sport FMIC, NGK BKR7EIX Plugs, Mitsu Evo DV, Valeo SMFW 228mm Clutch, 034 HFC <-
    WTB: H&R Front or Hotchkis S4 Sways
  6. #446
    Jun 03 2009
    Sweden, north
    Quote Originally Posted by a4darkness View Post
    Thanks man!
    I have a 8v VW to put together, but after that im gonna get a move on my camera mount
    + there are one major upgrade in the works
    Im still looking for an elim exhaust housing, please let me know if you know of one!
    -Bische
    163whp/208wtq
  7. #447
    Active Member Four Rings Staz's Avatar
    Jul 03 2010
    QUEENS, NY
    your front mount .. giveth it to meh !
  8. #448
    Senior Member Four Rings itsmatt33's Avatar
    Jul 14 2009
    Pasadena
    Quote Originally Posted by Staz View Post
    i have an almost complete ER comp. fmic for sale.
    Revo stage 2.TT225 injectors.Forge splitter.VMR test pipe with heat shield.ER Comp FMIC.AWE exhaust w/ down pipe.HP2 brakes. Stern Snub Mount.Clutchmasters FX400 240mm Steel FW.AWE boost gauge.S4 Seats.Euro Light Switch.LED Interior.Brushed Trim.5% tint 54% windshield tint.Black grills with sliver paint match rings.single ecodes(6k).Hoen fogs.Rdash plate LED.USP Front bumper.S4 rear bumper with black valence.DTM skirts.Oettinger RS.RS4 sway Bar.Stasis SS coils.19" VMR V710
  9. #449
    Jul 15 2007
    Mount Rainier, MD
    Quote Originally Posted by Bische View Post
    I'll never complain about it being too cold to wrench again!
  10. #450
    Jun 03 2009
    Sweden, north
    lol, I swore when I get my own garage im never gonna complain again doing work to my cars. I have done 2 suspensions outside, 1 exhaust outside in the rain, oilchanges in winter time etc...
    -Bische
    163whp/208wtq
  11. #451
    Jun 03 2009
    Sweden, north
    I forgot to add this little blooper I found while the engine was out:
    It is the coolant flange, if you look close you can see I missed the flange with the bolt LOL! Somehow it was 100% sealed anyway since it was clamped by the bracket for the crankcase breather tube
    And here I did a little pic for you guys:
    -Bische
    163whp/208wtq
  12. #452
    Jun 03 2009
    Sweden, north
    -Bische
    163whp/208wtq
  13. #453
    Senior Member Four Rings Dan[FN]6262's Avatar
    Sep 12 2008
    02 A4, 94 GMC, 06 450R
    South Central Pa, Dundalk MD
    #WINNING
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
  14. #454
    Jun 03 2009
    Sweden, north
    Quote Originally Posted by Dan[FN]6262 View Post
    #WINNING
    Yesss, smallest but most powerful box i have recieved for my car
    -Bische
    163whp/208wtq
  15. #455
    Jun 03 2009
    Sweden, north
    Small box, unlimited performance.
    I had a small box showing up last friday, super excited!
    This little sucker contained one dongle and 4 injectors + adapters:
    These are the Ringer Racing 1000's:
    AND, the wife bought herself a new computer, so I got her old one to tune my car with.
    A beat up, slow as fcuk, dirty as hell LG:
    So it needed some attention, needless to say. I started with opened it up since it would randomly shut off due to overheating:
    Hmm, this crap is not supposed to be in the cooling fan huh?:
    Then I took off that ugly vinyl, cleaned it up, formatted and loaded a fresh copy of windows 7 x64 ultimate.
    Now were talking:
    It is a pretty good laptop, 4gb RAM 1.8ghz dual core Intel, 15.4" screen and numerical keyboard. Now it is soo nice, fast and crisp, all functional
    Now the fun starts
    -Bische
    163whp/208wtq
  16. #456
    Jul 15 2007
    Mount Rainier, MD
    Needs more carbon fiber.
    Really looking forward to hearing from you about Maestro!
  17. #457
    Dec 01 2007
    As am I.
  18. #458
    Senior Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    02A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Good Job there my man
    MODS
    Do u have the Bentley or Dealership Manual & Tools it takes to work on YOUR car properly? Or...
    Are u just going to continue to wing it & keep expecting manna to fall from AZ?
    Apikol>Snub/Diff APR>ExhTIP-TB hoses,Stg3 AWE>DV
    JHM>ShortShift-the works
    Misc> 18x8x9 235/265;HSport S4 barsTT225;Bosch-F6DTC;CarbonioV2+V6Intake Inlet;HFC;Podi-P2;ATP mani;GPopK04;034mounts
    SPEC>Stg3+,LWFW
    STaSIS>328/305mm,40/60,SL
    Personal Motto>Walk Softly Carry a Big Stick
  19. #459
    Senior Member Two Rings mariosa4's Avatar
    Sep 26 2009
    peugeot 106 xr
    Greece - Korinthos-Athens
    my friend you are gonna have a lot of time spent - tuning with Maestro. You better start reading fast!
  20. #460
    Jun 03 2009
    Sweden, north
    lol, BECAUSE RACECAR
    As am I.
    Im super excited about finally getting to row around in my ECU!
    Im currently waiting on my basefiles from Tapp, I hope to get them before the weekend, emailed him the readout sunday. Maestro seems to have come a long way since it was released, more user friendly, more maps added etc.
    You can now select any basefile you want directly in maestro, without having tapp send them to you. But ofcourse, my ECU is not in that list
    Quote Originally Posted by A4SoftWalker View Post
    -Bische
    163whp/208wtq
  21. #461
    Senior Member Three Rings davkav's Avatar
    Dec 04 2008
    Dublin, Ireland
    When the time comes I will swap you my elim housing for your T25
    -Dave
    B6 A4 USP Avant 1.8TQ 6M - 71r - 550s - Revo 550 File - Bosch 005 - ATP TIP - Custom Toyosport FMIC - Spec Stage 3+ - Apikol rear diff mount - 034 Street Trans Mount - APR Snub - RS4 Engine Mounts - ITG Panel Filter - VMR Boost Vent Gauge - THS Testpipe - Milltek CAT back
  22. #462
    Jun 03 2009
    Sweden, north
    Quote Originally Posted by mariosa4 View Post
    Yes, I started reading about tuning Motronic's when Chris (MmmBoost) started the Maestro thread
    Quote Originally Posted by davkav View Post
    Finding an Elim housing was much harder than I expected, I figured there had to be many housings just laying around after people upgraded to fullframe setups but noooo
    Dont rush your build, I have another ace up my sleeve if I dont find a housing soon
    -Bische
    163whp/208wtq
  23. #463
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter GT35r and trailer
    Murrieta
    Yeah you would figure there might be some people with a dead Elim turbo that they could sell the exhaust housing from. Odd thing is that there are tons of China copies of everything else but not 1 single Elim housing copy. lol
  24. #464
    Sep 19 2008
    Few mk1's LHD & RHD and few other German makes
    Seattle WA
    Nice work on the Wagon so far and loving the custom fab work, must get my welder out and start working on few fab pieces myself.
    Good for you for just having a go, and the end results are amazing.
  25. #465
    Jun 03 2009
    Sweden, north
    Quote Originally Posted by M-Hood View Post
    Yeah, maybe im just having bad luck
    Quote Originally Posted by madone_si View Post
    thanks for the kind words! I hope to inspire people with this thread
    -Bische
    163whp/208wtq
  26. #466
    Active Member Two Rings IGottaP's Avatar
    Apr 19 2011
    E Brunswick NJ <-> Brooklyn NY
    your thread is a true inspiration one of the reasons i bought my silver wagon now i just have to learn to start wrenching
  27. #467
    Jun 03 2009
    Sweden, north
    Quote Originally Posted by IGottaP View Post
    Thanks and grrreat choice! Silver is the fastest color also
    A little update on the Maestro
    I provided Tapp with a stock binary for my ECU type, he has to add this type to his collection(even though Hansi and me have exact same ECU?).
    The ECU in my car is flashed with Powerchip stage1, so my file cant be readed fully. And I would not like to have my basefile to be based on another companys flash, impossible to know which maps that have been altered from the beginning.
    I want to start from scratch with a 100% stock binary to keep things sane, build my own stage1 and get that 100% then move on and install my RR1000's. That would be nice practical training before tuning the HTA and B5 S4 MAF.
    I assume Tapp has to dissassemble the binary I sent him(idk, maybe he has written something to help with this, he probably has) which takes some time, but I rather wait a little extra to get a 100% stock base to start from
    -Bische
    163whp/208wtq
  28. #468
    Active Member Two Rings nazisled's Avatar
    Feb 21 2012
    Detroitish
    just audibated to your car. wow. nice work man. such a motivation.
  29. #469
    Jun 03 2009
    Sweden, north
    Desicions desicions...
    Im having trouble now deciding if I should go with Maestro, or if im going to the dark side...
    Maestro has many nice features for me as a novice tuner, has failsafes and is constantly getting updated. BUT, it is restricted with a selection of maps AND restricted to one ECU. If I do it the hard way I have no restrictions what so ever, but I loose some other fancy stuff.
    I have started digging in my own ECU as there is no definition for it on the internet(that I can access), I have defined pretty much all maps that Tapp provides to '02 ECUs:
    There is a few more I would like to add to start with, like accel/decel fueling and coldstart fueling/cranking etc.
    My maestro is not licensed yet and my basefile should be ready next week, as of now I dont know if going to start with Maestro anyway or not. Im a true DIY'er and I know in the future I will go bad boy tuning in hex, but maybe I should start out with maestro anyway to get comfortable tuning my car before going hardcore without failsafes lol!
    Tell me what you think guys/girls.
    -Bische
    163whp/208wtq
  30. #470
    Jun 03 2009
    Sweden, north
    Quote Originally Posted by nazisled View Post
    Thank you sir.
    This thread was made to motivate people to do DIY things and build their car in their own way. I am a true visionary and I love to learn to do stuff, nothing is too hard, it just takes longer time to learn.
    -Bische
    163whp/208wtq
  31. #471
    Feb 08 2011
    Murrieta
    Most likely just best to play with the Maestro for a while before even thinking of going the other way.
  32. #472
    Jul 15 2007
    Mount Rainier, MD
    ...nothing is too hard, it just takes longer time to learn.
    I like your attitude.
  33. #473
    Sep 12 2008
    hex tuning is le scary
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
  34. #474
    Jun 03 2009
    Sweden, north
    You are probably right. The only thing is I feel i might be held back with the selection of maps, I dont know Tapp's standpoint on adding maps. I had the feeling he is not too keen about adding maps..
    If there was no problems to get maps added, I would not think twice about doing Maestro on my car. It is a nice all-in-one package with the logger/flasher and all.
    Yeah it is raw, but when I port in those maps into Tunerpro it is no more scary than altering maps in Maestro. Save it, flash it and log it.
    The Nefmoto flasher has come a huge way, and Tony is updating it as his time permits. He has plans to extend his software even more too, he is putting in a shitload of work for the community.
    Here is a B5S4 M box file in Tunerpro for reference:
    -Bische
    163whp/208wtq
  35. #475
    Dec 14 2004
    Norway
    Tapp has added some maps for the B6 A4 guys, I know MmmBoost has requested and got some maps added.
    I hope you choose Maestro and request maps you find out you need and get them added. I don't see why Tapp would have a problem with that, should only make Maestro an even better option for everyone. It seems to me that Tapp is working hard on improving Maestro, with constant updates, so I think and hope he is forthcoming with adding maps when they are requested. A potential problem with it I guess is that it might become too advanced for beginners (it can be argued it already is), but then he could just make some sort of toggle for advanced options?
    Anyways, my vote goes to starting with Maestro
    2002 A4 1.8TQ 5MT
    - Fully built 2.0T w/ GT28RS, Maestro 7
    - Bilstein PSS9 coilovers
    - B6 S4 brakes F/R
  36. #476
    Jun 03 2009
    Sweden, north
    Quote Originally Posted by Hansi View Post
    If I look up the maps I would like to added with all adresses so he doesnt have to do the hard work, maybe it is easier to get maps added. As for being too advanced, if the number of maps get too large, he could add a list with checkboxes so each person can choose which maps he wants to be visable in the editor, should not be a big deal.
    Something I noticed right away I wanted to be added, is the Bosch abbreviations to each map(like Ignition timing - KFZW etc, like how I named my maps in the screenshot above), I cant believe those are not in there already. That makes stuff 100 times easier to look up.
    Hansi I could not reply to your email, only got delivery fail. I dont know what happened lol
    -Bische
    163whp/208wtq
  37. #477
    Dec 14 2004
    Norway
    I agree, if you do all the hard work he really should just add the maps. Good point on checkboxes on which maps you want displayed.
    I definately agree on the Bosch abbreviations, I'm sure we could get it added. In fact, I'll add it right now to a thread on the Eurodyne forum called feature request
    Hmm, maybe my mail server is acting up again, you could just PM me.
    Like I said, I hope you choose Maestro. The Maestro community needs more knowledgeable people and people willing to share their experiences.
    2002 A4 1.8TQ 5MT
    - B6 S4 brakes F/R
  38. #478
    Jun 03 2009
    Sweden, north
    I plan on documenting my tuning in this thread, leaning towards Maestro IF the basefile is closely matched to my requirements. Either way, tuning in hex or Maestro, it is the same system. The successful/unsuccessful tuning approch will be the same, a good strategy shown on either can be copied to the other.
    Im not afraid to make mistakes while learning to calibrate my engine and posting it here, this is the reason why you dont see any beginners document their first calibration, the fear of being laughed at by more experienced tuners. If someone wants to laugh at me for being a noob, go ahead lol, I will laugh with you
    I always budget some level of failure while trying to learn new stuff, and im never dissappointed at the end. I have come far in the past 2-3 years, this was one of the first threads I made on this forum, and now I am able to indentify maps in a hex binary out of my cars ECU.
    -Bische
    163whp/208wtq
  39. #479
    Jun 03 2009
    Sweden, north
    Still no basefile from Tapp.
    In the meantime I have come up with this:
    -Bische
    163whp/208wtq
  40. #480
    Jun 03 2009
    Sweden, north
    My car is not stage1 anymore
    Here is a log of the "stock" Bische Wagon https://docs.google.com/spreadsheet/...TJWZ2RBMXVDUXc
    I will update with pics 'n stuff when I have time!
    -Bische
    163whp/208wtq
